Huawei P8 lite after the update can not turn on wifi and hotspot
Czeslov 52491 11
How can I fix a Huawei P8 Lite where Wi‑Fi, Bluetooth, and hotspot will not turn on after updating to Android 6.0?
This is most likely a hardware defect, not a software problem: the P8 Lite is reported to have a factory fault in the Wi‑Fi/Bluetooth module or glued chip, so changing ROMs or doing a hard reset usually does nothing [#16297066][#16854033][#16296346] The suggested fix is a warranty repair with a motherboard/mainboard replacement [#16297066][#16854033] If the phone is still under warranty, return it to service or the seller; one reply notes that if Huawei cannot replace the board, you may get written expertise to request a refund from the seller [#16535871]
  • #1 16296298
    Czeslov
    Rate: 10
    After updating the android in the Huawei P8 lite up to 6.0 I can not start wifi, Bluetooth and hotspot and when I press, for example, I do not press and not turn on, bt and hotspot is the same .. upload a new system, room or maybe something else? Help
  • #2 16296346
    KamGr
    Help: 77
    Rate: 203
    You can still check if a hard reset will help you, if not come back to the old system (the one where everything worked).
  • #3 16296612
    Czeslov
    Rate: 10
    Hard reset did not give anything. Return to the previous system as soon as possible?
  • #4 16296651
    KamGr
    Help: 77
    Rate: 203
    What version do you have now? I understand that you did not install the android, it only updated itself automatically?
  • #5 16297066
    plustek
    Help: 176
    Rate: 200
    Wi-fi damage is a factory defect of this model. It's a glued chip, soft here has nothing to do with it. Give it back for a guarantee, exchange it for P9 Lite.
  • #6 16297725
    Czeslov
    Rate: 10
    Yes, auto update
  • #7 16534998
    cyta
    Help: 6
    Rate: 29
    Hello and what's next with this phone they exchanged for. I just have the same thing.
  • #8 16535871
    tonk
    GSM specialist
    Help: 137
    Rate: 57
    Huawei no longer exchanges phones, how they will have it exchanged plate, as they will not have it you will get written expertise to ask the seller to return the cash
  • #9 16825215
    Jacoland
    They "fixed" me by exchanging the motherboard. After less than a month, WiFi again ceases to connect and Bluetooth does not evaporate. Maybe at the third repair it will be ok.
  • Bluetooth only works after enabling Wi‑Fi on P8 Lite
    #10 16853696
    marcinz76
    Rate: 14
    Hello, my bluetooth does not work in my p8 lite. For some time I could not connect with a laptop .... I bought a BT headset today and it does not evaporate. It is strange when I turn on the additional wifi starts to work bt. I installed some program bt connect the same with wifi something then works but it breaks .... Does anyone know what's going on ???? On the infolini they said that the "janosika" wine was uninstalled, I did a hard reset several times, I even changed soft for the older C09B577 was B580. Still the same bt starts to work after it is turned on. wifi
  • #11 16854033
    tonk
    GSM specialist
    Help: 137
    Rate: 57
    P8 lite factory defect, give a guarantee of the main board being removed.
  • #12 16854954
    marcinz76
    Rate: 14
    Hello, just today I learned the module wifi and bluetooth is together unstick the feet ... phone defect .Tell after the warranty one professional in Cz -wie said he does not fix it because 50/50 that he manages to repair if it fails and wifi will run out. The second professional said he did more than once, he always managed to cost 150 zlotys.
    Worth the repair?
After updating the Huawei P8 Lite to Android 6.0, users report issues with Wi-Fi, Bluetooth, and hotspot functionality not activating. Suggested solutions include performing a hard reset and reverting to the previous system version, but these have not resolved the problem for some users. Discussions indicate that the Wi-Fi and Bluetooth issues may stem from a factory defect related to a glued chip, leading to recommendations for warranty claims or exchanges for newer models like the P9 Lite. Some users have experienced repeated failures even after motherboard replacements, indicating a persistent defect. Repair options are available but may not guarantee success.
