Wi-Fi - The phone can see the network but cannot connect. Huawei P8 lite
kmyk0307 4356 2
  • #1 16899358
    kmyk0307
    I have a Huawei P8 lite phone, when I want to connect under the network it is switched off or Saved. The password is well entered and the problem does not appear only on one Wi-Fi network. The phone has root and the Resurretion Remix OS system is installed (the problem also appears on the system from Huawei, Lineage OS, DOT OS.
    Kuzyn
    Help: 21
    Rate: 64
    I don't want to worry you, but you'll probably have a Wi-Fi chip to replace. In this model, this system often sits. If you have an ammeter, measure your phone's consumption with it turned off. If it has more than 0.28 mA, it is 99% wi-fi replaceable.
  • #3 16899691
    kmyk0307
    I was hoping that it was not a network card but it did not work out and I will return it to the website for this topic. Thanks for the answer
