Mondeo mk3 2.0 16v LPG: Starting Issues & High Consumption after Long Standstill (Videos)
Mateuszt5 5787 11
Why does my Mondeo Mk3 2.0 16V LPG only struggle to start after standing for a long time, while it starts with jump leads and then restarts normally after a short drive?
The most likely cause is a bad ground/mass connection between the battery, body, and engine/starter, not necessarily the battery itself [#16367965][#16368007][#16371183] Check all ground straps and cable clamps for corrosion or poor contact, especially the starter ground and the battery-to-body/engine connection [#16367991][#16371183] Clean the battery terminals and verify the battery charge state; one reply also recommends checking electrolyte level and density and charging the battery fully [#16368000] A weak ground can produce the same effect as disconnecting the battery clamp, which matches the symptoms of ticking/no-start after standing and normal starting after a short drive or jump start [#16368029][#16370028]
  • #1 16367952
    Mateuszt5
    Rate: 8
    Hello. I have been struggling with the problem for 2 weeks.
    The car doesn't just start ticking. I attach below two videos. 1 as it is after several attempts and another when it is fresh. The car behaves like this after a long standstill. For sure the battery is ok because I checked it on 3! I will add that it fires from cables or on pride. A professional was exchanging a disc with LEDs in the alcove because the consumption was very high. But as you can see, it didn't work. Another curiosity that if it goes with cables, all I have to do is 1km and then it will start - until the longest stop.
    • 20170323_171236.mp4 (35.46 MB) You must be logged in to download this attachment.
    • 20170323_171426.mp4 (11.54 MB) You must be logged in to download this attachment.
  • #2 16367965
    andrzej20001
    Help: 1578
    Rate: 6669
    No weight for body / engine
  • #3 16367985
    Mateuszt5
    Rate: 8
    Do you think this is ?? It would not always happen ?? and me only after a long break. There are no alarming symptoms while driving.
  • #4 16367991
    andrzej20001
    Help: 1578
    Rate: 6669
    You have a circus with a meter that you start from this. And motor voltage measurements as it works. Meter weight with battery and body.
  • #5 16368000
    manta 5
    Rate: 17
    Symptoms indicate that the battery is in poor condition. It would not hurt to check the electrolyte level, preferably its density and charge it well. Clean the battery terminals, check if the weight is good and it should be OK
  • #6 16368007
    triakw
    Help: 22
    Rate: 57
    You probably have a problem with a lack of weight. Check all ground connections to see if they are corroded. Check battery charge status and clamp status.
  • #7 16368012
    Mateuszt5
    Rate: 8
    Ok thanks for the quick reply. Now the only question is whether the lack of mass can cause power consumption ?? And if so, will the spec know that it's mass ?? Maybe stupid questions but I'm green in it
  • #8 16368029
    manta 5
    Rate: 17
    If there is no mass, it is the same as if you removed the clamp from the battery. Logically thinking as there is no mass, how can the battery discharge?
  • #9 16368119
    Mateuszt5
    Rate: 8
    Gentlemen, this is not wine. It was tested on 3 batteries !!! And my personal was checked by 2 guests and everyone claims to be functional.
    As I speak, hooking up is nice. Yesterday it stood 12 hours on another battery and it worked, I got home, I put the car away and after about 8h again the breakdown ...
    As the electrician says, there is no consumption because he removed the consumption from the altka.
    Besides, if it was consumption it is strange that it can drain the battery so much in such a short time.
  • #10 16369805
    andrzej20001
    Help: 1578
    Rate: 6669
    My buda-time!
  • #11 16370028
    manta 5
    Rate: 17
    It is not strange at all. If the current consumption is even low, it is normal that it will discharge the battery. It is possible that the battery survived its own.
  • #12 16371183
    triakw
    Help: 22
    Rate: 57
    It often happens that it weakly connects the clamp on the wire to the ground. Such ticking is a characteristic symptom of low mass. Check the starter mass.
The discussion revolves around starting issues and high battery consumption in a Mondeo mk3 2.0 16v LPG after prolonged inactivity. The user reports that the car fails to start, exhibiting a ticking sound, despite testing three different batteries. Responses suggest potential causes including poor ground connections, battery condition, and current consumption issues. Several participants recommend checking the battery's electrolyte level, cleaning terminals, and ensuring all ground connections are intact. The user expresses frustration as the problem persists even after professional checks and temporary fixes.
