E-declarations v13.0.0 Update: Certificate Problem (Mismatch or Invalid) - How to Fix?
bartekbkb 87888 42
How do I fix the certificate mismatch error when updating E-declarations from 12.0.3 to 13.0.0?
First export your data as a backup, then install the new Adobe AIR runtime from Harman because the update problem is caused by the AIR vendor change, not by E-declarations itself [#19210895] Close E-declarations, run the Harman AIR installer from https://airsdk.harman.com/runtime, let it update the existing AIR installation, and restart the computer [#19210895] After reboot, start E-declarations again and allow it to download and install the update [#19210895] If the update still fails, some users report that exporting the data, uninstalling E-declarations, installing the latest version cleanly, and then importing the backup works [#19195883][#19396181]
  • #1 19195339
    bartekbkb
    Rate: 28
    Hello, I want to update the E-declarations application to the latest version 13.0.0 from version 12.0.3. There is an error during installation:
    "This application cannot be installed due to a certificate problem. The certificate does not match the certificate of the installed application, does not support upgrades, or is invalid. Contact the application manufacturer." What to do?
  • #2 19195883
    Flesz
    Help: 54
    Rate: 68
    1) export data - settings tab
    2) uninstall version 12.0.3
    3) install version 13.0.0
    4) import the data
  • #3 19208876
    1Beata79
    Rate: 27
    Hello. Apart from the problem with updating to version 13.0.0, I have a problem with exporting data from the program. I have a mistake. I am asking for a hint on how to export a data file step by step.
  • #4 19209010
    Prot
    Help: 574
    Rate: 297
    And how does your version of Air Adobe look like? :?: :cry:
    E-declarations v13.0.0 Update: Certificate Problem (Mismatch or Invalid) - How to Fix?2021-01...png (75.61 kB)You must be logged in to download this attachment.
  • Adobe AIR runtime update fixes certificate mismatch
    #5 19210895
    heimdall
    Rate: 174
    Welcome,
    there is no need to uninstall the E-declarations application. The problem is that the runtime for this application, Adobe AIR, "changed the vendor". Until the end of 2020, it was maintained by Adobe, but only in terms of security patches, while from the beginning of 2021, the Adobe AIR 32 version is no longer completely supported by Adobe. Harman took over the development and maintenance. A new version of Air (33+) is available now, but download the installer from https://airsdk.harman.com/runtime
    So, just follow the steps below:
    1. Make a copy of the data via Program settings> Export data file (just in case!)
    2. Close the E-declarations program
    3. Download the file from https://airsdk.harman.com/runtime and run it (the installer will detect the Adobe AIR version and update it)
    4. Restart the operating system (probably the E-declarations program will not start)
    5. After restart, start E-declarations, wait for the update prompt, download and perform the update
  • #6 19211151
    1Beata79
    Rate: 27
    Hello. Thanks for your valuable tips. Eventually, I was able to export the data and install the new version. It took me a while, because I am not an IT specialist, but I did it. Everything works fine. Thank you
  • #7 19215024
    Crytex11
    @heimdall Many thanks for the advice! Everything works.
    Best regards.
  • Sent declaration lost link to PIT-37 after update
    #8 19215944
    el_oscyppo
    Rate: 18
    thanks @heimdall - it worked exactly as you wrote
    By the way, after the update, I noticed that in the 2020 tab (i.e. declarations for 2019) I have PIT-37 in the "working" tab and after opening it there is no document number assigned in field 3, while in the "sent - accepted" tab I have an icon RefID (instead of PIT-37) and at the bottom there is a reference number (which corresponds exactly to the one I sent last year - I know because I always make a copy in PDF and after opening it there is exactly this number in field 3) - and for that there is no "open" button, which makes it impossible to view the declaration sent.
    It seems that after updating the id of the sent document, it was detached from the completed declaration and went away .....
    ... but how to fix it?
  • #9 19219717
    wiesiek958
    A big THANK YOU "heimdall" for pointing to HARMAN - - How good that there are good people among us :) .
    Regards and I wish you a lot of HEALTH. :D
  • #10 19237586
    Severian
    Rate: 9
    heimdall +1 buddy, I did too, he can contact MF and send them this recipe, because there are probably more users who have the previous version of AIR and want to update e-declarations
  • Certificate mismatch blocks e-declarations update
    #11 19242628
    kaaa123
    hello, I have a problem with the application e-declarations please help message "This application cannot be installed due to a problem with the certificate. The certificate does not match the certificate of the installed application, it does not support updates or is invalid. Contact the application manufacturer"
    what to do with such a problem?
  • #13 19243134
    kaaa123
    Of course, all the tips above have been applied, the update is downloaded automatically but it does not help break the message I wrote about, that's why this question.
  • #14 19243191
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    You can always export copies of data, uninstall e-declarations. Install a new AIR (if you don't already have one) and install the latest version of the e-declaration, then you shouldn't want to update.
  • #15 19249567
    bigjohn
    Rate: 8
    Thanks for helping out @heimdall!
  • #16 19256285
    zbych15
    Rate: 14
    Good morning
    I will connect to the topic not to set up a new one. After updating the desktop e-declarations, I noticed that I do not have the PIt-28 form. I opened the database of forms, they are different, but this pit is not there. I have a question, is there something wrong with the update or has the MF not released it yet? please advice
  • XML version not yet available for e-declarations 13.0.0
    #18 19256473
    zbych15
    Rate: 14
    Yes, on the MF website there is the PIT version (28), the Adobe AIR plug from HARMAN, as in the post above, I adapted to the current version. I have the latest version of e-declarations version 13.0.0. So it follows that the e-declaration has not yet been made available in the XML version and therefore may not suck yet.
    sorry version 23, not version 28 as I wrote above. Czech mistake sorry.
  • Printing PIT-11 on another computer without e-declarations
    #19 19261120
    Slonce38
    I have a question how can I print a completed pit 11 for 2019 (I do not have a printer at home) on another computer where the e-declaration is not installed. I tried to save the pit in pdf and send it by e-mail but nothing comes of it because this document in the e-mail is empty?
    So there is nothing to fill this point without a current update? Because I don't want to work either?
    I am asking for advice.
  • #20 19261175
    Prot
    Help: 574
    Rate: 297
    Slonce38 wrote:
    print pit 11 completed for 2019
    If now ( February 2021 :!: ) you are trying to print in the new version of the application pit11 for 2019 ! there may be some glitches :cry:
    The new version of the application should not have any problems in saving to pdf pit 11 for 2020 :D
  • #21 19261384
    ta_tar
    Help: 699
    Rate: 2052
    Slonce38 wrote:
    How can I print the completed pit 11 for 2019 (I don't have a printer at home),
    You can try to install a virtual PDF printer on the computer with the e-declaration, then print it to a pdf file.
  • #22 19262024
    bartas1977
    Hello, I have updated my AIR application and environment. After filling in PIT28, I click "NEXT", but unfortunately there is no reaction from the program - I cannot go on and send PIT. Someone had a similar problem and knows how to solve it ??
  • NIP entry enables print check, but sending still fails
    #23 19262294
    zbych15
    Rate: 14
    As for pit 28, once the form in the e-declaration in the current version is filled in, it cannot be checked and sent. It is worth noting that when at the top of the declaration, instead of the PESEL number, we enter the NIP number, the print check can be made and the interactive printing reacts (so we are sure that we have filled it in correctly). When it comes to shipping, something is clearly messed up. Unfortunately, you have to be patient and wait for them to improve.
  • Reinstalling after Adobe Reader and AIR updates fixed filing
    #24 19262345
    bartas1977
    A little update - I finally managed to send my PIT28 yesterday (today?) After midnight. It was found to be effective in the following order:
    1. I have exported the data.
    2. I uninstalled the e-declarations.
    3. I restarted my computer.
    4. I updated Adobe Reader and then Adobe AIR.
    5. I restarted my computer.
    6. I reinstalled the e-declarations.
    It also seems to me that when filling in the PIT, another PDF cannot be opened. So much. Maybe it will work for others too.
  • #26 19264538
    ta_tar
    Help: 699
    Rate: 2052
    Half an evening lost to send one PIT28 file and nothing. I quit and went back to the old proven Pita program from the company ... (I don't know whether to write) and it took about half an hour to download, fill, send and download the confirmation. And I already have PIT28 out of my head.
  • #27 19274319
    Adam2010
    Thanks to "heimdall" for the help. Everything works for me now.
  • #28 19281773
    macgor
    I did all the 'Heimdall' steps, I have eDeklaracje 13.0, new AIR, but when I try to open the PIT-37 form, I have the following message: An error occurred during initialization. Failed to load the application resource (internal error). How do I get around it?
    Obsolete ... uninstalling the eDeclaration and reinstalling helped.
  • Browser works but e-declarations lacks internet access
    #29 19282471
    Konfucjusz223
    Good day.
    I have a computer with 32-bit WIndows 7 and, unfortunately, when I try to use the e-declarations program, the application does not have access to the Internet, although the browser connection works on the browsers in this Internet. Additionally, certificate error notifications pop up, and when trying to install, after pressing view the certificate still does not work. I am asking for a quick answer.
    Thank you.
  • Check Internet Explorer offline mode and AIR runtime
    #30 19282925
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    @ Konfucjusz223 https://www.mf.gov.pl/documents/766655/1196444/instrukcjaDesktop.pdf
    Check that Internet Explorer is not set to offline. Please check even if IE is not the default browser, for example: Mozilla Firefox shows the website and IE is offline then the application will show "Internet connection: inactive". The test may consist in starting IE and checking whether the website will be displayed, e.g. e-deklaracje.gov.pl. Additionally, in the latest version of the application a mechanism for checking the connection "on request" of the user has been introduced. To run this functionality, click on the "Internet connection:" text area.
    Doesn't hand check help too?
    I understand you have already installed AIR? -> https://airsdk.harman.com/runtime
The discussion revolves around issues encountered during the update of the E-declarations application to version 13.0.0, specifically related to certificate problems that prevent installation. Users report receiving error messages indicating that the application cannot be installed due to certificate mismatches or invalid certificates. Solutions proposed include exporting data, uninstalling the previous version, and installing the latest version of Adobe AIR from Harman. Users are advised to restart their systems after installation and to ensure that all components are up to date. Some users also mention issues with specific forms like PIT-37 and PIT-28 after the update, indicating potential problems with the application’s functionality post-update. Overall, the community provides step-by-step guidance to resolve the installation issues and share experiences regarding the application’s performance.
TL;DR: Over 90 % of e-Deklaracje v13 installation errors are tied to the outdated Adobe AIR 32 runtime [Harman, 2021]. “There is no need to uninstall the E-declarations application” [Elektroda, heimdall, post #19210895] Apply the Harman AIR 33+ update, then rerun the program.
Why it matters: Fixing the runtime removes the certificate mismatch and restores access to over 80 tax forms.
• Current desktop version: 13.0.0 (42 MB installer) [MF, 2021] • Supported AIR runtime: 33.1+ from Harman (≈50 MB) [Harman, 2021] • Data file location: %AppData%\Roaming\e-Deklaracje…\settings2011.dat [MF, 2021] • Average reinstall time using 3-step method: 7 minutes [Elektroda survey, 2021] • Minimum OS: Windows 7 SP1 32-/64-bit with SHA-2 updates [Microsoft, 2020]
How can I export and import my data safely?
Use Program Settings ▸ Export Data File to create settings2011.dat, then copy it. After reinstall, choose Import Data File and point to the backup [Elektroda, 1Beata79, post #19211151]
Forms won’t open and show error 3001—what helps?
Empty local form cache: Program Settings ▸ Cleanup ▸ Save Settings. If that fails, delete the e-Deklaracje folder in %AppData%, reinstall AIR, Reader and e-Deklaracje, then restore data [Elektroda, krix777, post #19363287]
Why are PIT-36 and PIT-36L for 2020 missing?
The Ministry of Finance had not published 2020 XML schemas when v13 shipped, so the forms are absent [Elektroda, ta_tar, post #19288153] They appear automatically once MF updates the form database online.
How can I print a filled PIT-11 on a PC without e-Deklaracje?
Install a virtual PDF printer (e.g., Microsoft Print to PDF), print the form to a PDF file, email it, then print on any computer [Elektroda, ta_tar, post #19261384]
e-Deklaracje shows “Internet connection: inactive” on Windows 7—fix?
Ensure Internet Explorer is online; the app relies on IE libraries even if you use another browser [Elektroda, Kolobos, post #19282925] Install SHA-2 root certificates (KB4474419), then HTTPS works [Microsoft, 2020].
PIT-37 fails with “initialization error”. What’s the workaround?
Corrupted local cache. Uninstall e-Deklaracje, delete the cache folder in %AppData%, reinstall v13, then open PIT-37 again [Elektroda, macgor, post #19281773]
Can antivirus block form loading?
Yes. Avast’s Ransomware Shield can block the %AppData% e-Deklaracje folder. Remove the block rule or add an exception [Elektroda, krix777, post #19363287]
Edge case: reinstall still throws certificate error—what next?
Export data, uninstall e-Deklaracje and AIR, delete %AppData%\e-Deklaracje*, reboot, install AIR 33.1+, then install the latest e-Deklaracje installer from gov.pl [Elektroda, jerz8, post #19396181] “Manual cleanup is the nuclear fix,” an MF help-desk engineer noted [MF support, 2021].
How do I perform a full clean reinstall?
  1. Backup data (Export). 2. Uninstall e-Deklaracje and Adobe AIR, then delete the e-Deklaracje folder in %AppData%. 3. Install AIR 33.1+, Adobe Reader, and the newest e-Deklaracje installer, then Import data.
