VW Polo 9n Front Wheel Bearing: Replacement, Hub, Driving Noise, Steering & Convergence
mati4007 11913 16
Can I replace the front wheel hub/bearing on a VW Polo 9N without resetting toe/alignment if the alignment was set yesterday?
Yes—replacing the front wheel hub/bearing should not change toe, so a fresh alignment is normally not required [#16373332] One reply adds that removing the crossover/steering knuckle does not need adjustment either, but if the crossover is pulled during the job it can still affect alignment, so checking it afterward is a safe precaution [#16374029][#16373375] For the bearing itself, the workshop should press it in with the proper device; without that tool, correct installation and durability are questionable [#16373993][#16374029]
  • #1 16373266
    mati4007
    Hello!
    There's something in my right front wheel. I suspect the placenta, when straight driving it roars and when turning right there is silence. According to what I found now, it is not possible to replace the bearing itself, only with the hub.
    Is it possible to work around it somehow not to set convergence because I set it yesterday?
  • #2 16373332
    stanislaw1954
    Help: 2013
    Rate: 4673
    Replacing the front wheel hub should not change the toe, so it does not require re-setting.
  • #3 16373375
    robokop
    Help: 1763
    Rate: 6371
    But pulling out the crossover can affect it, so it doesn't hurt to check later.
  • #4 16373746
    mati4007
    And what does this exchange look like in the workshop? exchange and the price is convergence if they have an instrument for it and do not take it off (I guess it may depend on the workshop or have something like that), how is it usually?
    robokop
    Help: 1763
    Rate: 6371
  • #6 16373850
    mati4007
    @robokop
    I saw it, it costs 5,000 but does every major workshop not Janusz have something like this? probably not .
  • #7 16373993
    ociz
    Help: 1379
    Rate: 3486
    It is much cheaper without hydraulics. Without such a device, it is not possible to press the bearing correctly. I made some holes for it in the Passat B5 spacing and change bearings without removing the steering knuckle.
  • #8 16374005
    mati4007
    @ociz
    and workshops (not Janusz) usually have such tools? do the press and hi with work?
    ociz
    Help: 1379
    Rate: 3486
    Nobody else has such in my area.
  • #10 16374011
    mati4007
    @ociz
    So they pull out the switches and take only PLN 60 for exchange. And I have to do convergence at a separate cost?
  • #11 16374020
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    If we are talking about the same placenta as in Cordoba 2, t5 and tuaregu, then in the press there is no chance for correct assumption and longevity.
  • #12 16374026
    mati4007
    I have a placenta with a hub
  • #13 16374029
    ociz
    Help: 1379
    Rate: 3486
    Do not worry, there is nothing to adjust when removing the crossover. However, the bearing will be damaged during assembly as it will be pressed in without the device.
  • #14 16374032
    mati4007
    But somehow the steering arm must be separated and it holds the pin on 3 screws if they are unscrewed the convergence is to be set.
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    And how do you split on the pin?
  • #16 16374058
    mati4007
    @ T5
    I know you can do it on a bolt but I just heard how they turn off rather than split, that's why this topic is so hollow.
    If they spin and there is no set convergence, it can be seen by the position of the steering wheel speak good?
  • #17 16374074
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Chick, it's a half hour job.
The discussion revolves around the replacement of the front wheel bearing and hub on a VW Polo 9n, with a focus on the associated driving noise and steering issues. The user suspects a problem with the right front wheel, noting a roaring sound during straight driving and silence when turning right. Responses indicate that replacing the hub typically does not require resetting the toe alignment, although some caution that removing the steering components may affect it. The cost of replacement and the necessity of specialized tools for proper bearing installation are also discussed, with some users sharing experiences about workshops and the tools available. Concerns about potential damage to the bearing during installation without the correct equipment are raised, along with the importance of ensuring proper alignment post-repair.
