Brother DCP-J4120DW: How to Change Language to Polish in Printer Settings
ana44 8289 8
  • #1 16375142
    ana44
    Can anyone help me change the language to Polish in the Brother DCP-J4120DW printer?
  • #3 16377310
    ana44
    endriuf wrote:
    How is it now?
    Currently he is English and I would need Poland
  • #4 16380721
    dr.master
    Help: 520
    Rate: 932
    1. We turn off the printer
    2. Turn on by holding "Menu"
    3. Select "7" with the up arrow
    4. Press "OK"
    5. Select "4" with the arrow up
    6. Press "OK"
    7. We see the message "Maintenance 74?"
    6. Press B / W Start (or OK)
    7. We see "000X" (X - 3 to 18) is our current language
    8. Use the arrows to the right to go to the last number and use the up arrow to change to the number you want.
    0003 German
    0004 English
    0005 French
    0007 Norwegian
    0008 Dutch
    0013 Danish
    0016 Italian
    0018 Spanish
    9. Press B / W Start
    10. "Maintenance" is displayed again
    11. Turn off, turn on the printer.
    12. There will be either English or a menu with language selection immediately.
    If the printer is not from Polish distribution, it does not have Polish in it.
    I can upload, but unfortunately for $$ because Brother does not provide firmware
  • #5 16380755
    ana44
    4. Press "OK"
    6. Press "OK"
    0003 German
    0004 English
    0005 French
    0007 Norwegian
    0008 Dutch
    0013 Danish
    0016 Italian
    0018 Spanish
    Thanks a lot for the answer.
    Unfortunately, the printer does not have Polish. And how much would it cost to upload such an option and how?
    Greetings, Anna
  • #6 16380961
    dr.master
    Help: 520
    Rate: 932
    PW has gone, only authorized services have access to the firmware and appropriate tools.
  • #7 16380970
    ana44
    Sorry but I don't understand what it means "PW went"
  • #8 16381463
    rys57
    Moderator
    Help: 212
    Rate: 436
    ana44 wrote:
    what does it mean "PW went"
    PW = Private Message. There is an inscription at the top of the window Messages . Click there.
  • #9 16530146
    ana44
    the language cannot be changed because it turned out that the printer was purchased from England and I would have to send it to the service.
The discussion revolves around changing the language setting to Polish on the Brother DCP-J4120DW printer. A user inquires about the process, and a detailed step-by-step guide is provided, which includes turning off the printer, accessing the menu, and selecting the appropriate language code. However, it is noted that if the printer was not purchased from a Polish distributor, the Polish language option may not be available. The conversation also touches on the need for firmware access, which is restricted to authorized services, and the potential costs involved in uploading the Polish language option if it is not pre-installed.
