HP Photosmart 7520 Printer: Adding Polish Language Option for US-Bought Model
kwiatuszek1959 4578 10
How can I make the display language on a US-bought HP Photosmart 7520 printer Polish?
You likely need to change the printer’s region to the European one through HP Poland, because the Polish language may not be available on a US-bought model. The suggested procedure is to call HP Poland; they are said to provide the special code and steps needed to switch the region, and the process can take up to an hour [#16375501] One reply also suggested trying a device settings change first, and if that fails, uploading EU software/firmware with Polish support [#16373883] However, a later attempt to solve it by updating firmware was reported as not helping [#16373911] After the region change, keep in mind the printer may require European inks (364) instead of US cartridges [#16375501]
  • #1 16373555
    kwiatuszek1959
    Level 4  
    Hello, I have an HP Photosmart 7520 printer bought in the USA. There is no Polish in the language selection. Could someone advise me on what to do to make it in Polish. Is there anyone who can help me? Please :)
  • #3 16373821
    kwiatuszek1959
    Level 4  
    sosarek wrote:
    This did you check
    Hello sosarek, thanks for your help but before that I was on this page and downloaded this software and drivers, unfortunately it did not help :( Maybe I put myself wrong, specifically the language on the printer display should be in Polish. best regards :)
  • #4 16373883
    sosarek
    Help: 9321
    Rate: 15543
    Have you tried to change it in your device settings? However, since the printer was bought in the USA, it may be unavailable, then you would have to upload its EU software with Polish.
    Z
    Pka, Poznań, 60-850
  • #5 16373896
    kwiatuszek1959
    Level 4  
    But how do I upload its EU software with Polish? Can you give me the bearings and tell me how to do it?
  • #7 16373925
    kwiatuszek1959
    Level 4  
    It didn't help either :(
  • #8 16373930
    sosarek
    Help: 9321
    Rate: 15543
    In that case, you will get used to the language displayed on the device display, or download something from EU (or PL).
    Z
    Pka, Poznań, 60-850
  • #9 16375501
    Stan-S11
    Help: 141
    Rate: 310
    Printer manufacturers use regionalization and to switch the printer to the European region, call HP Poland - they will tell you how to carry out the entire procedure and will provide a special code to change the region.
    Sooner or later you will have to do this because the printer will not accept inks purchased in Europe (364), unless you have a large supply of American inks. I will add that the change of regionalization takes up to an hour.
  • #10 17624284
    tomi26
    Rate: 17
    The topic is a bit old, but I want to buy such a printer and I know that there will be no Polish language in it.
    Did the author of this topic manage to change the language to PL?
  • #11 18455193
    mojrzesz01
    He probably sold and gave it up, but I'm joining the question.
    Good equipment, it would be nice if the Polish language would be, I have the European version and yet there is no Polish.
    Besides, the hp service did not bring anything to the matter.
    best regards
The discussion revolves around the HP Photosmart 7520 printer purchased in the USA, which lacks a Polish language option in its settings. Users suggest checking device settings and updating firmware, but these methods have not resolved the issue. A key recommendation is to contact HP Poland for assistance in changing the printer's regional settings, which may involve uploading EU software that includes Polish language support. The process of regionalization is noted to take up to an hour and is necessary for compatibility with European ink cartridges. Some users express frustration over the lack of Polish language support in both US and European versions of the printer.
