Brother J105 vs J480DW vs J562DW: Inkjet Printer with WiFi, Duplex, and Refill Cartridges Options
granttt 4398 9
Which Wi‑Fi inkjet printer under 550 PLN should I buy if I want duplex and low running costs, and is it worth using refill or replacement cartridges for Brother models like the J105, J480DW, or J562DW?
Buy the DCP T500W instead, because it has cheap original inks and you do not need to mess with replacement cartridges. [#16256350] [#16273520] The main advantage mentioned is low operating cost: the T500W comes with a CISS, so the inks cost about half as much and the yield is at least twice as high. [#16274072] It was also pointed out that this model is a better fit for home use than the MFC office machine, which was noted as lacking a CISS system. [#16273996]
  • #1 16256222
    granttt
    I am trying to buy an inkjet printer with wifi, up to 550 PLN gross. I consider the Brother DCP J105, but I also came across the Brother J480DW, which is over PLN 100 cheaper and already has a duplex. The only drawback is the price of the original cartridges.
    Does anyone have such a model or J562DW and use refill cartridges? Do you need a chip resetter or is it enough to change the chip?
    Do you use the original brother inks or maybe a replacement, for example Activejet or Dulin? Activejet supposedly guarantees that it will cover the costs of failure if the service refuses to repair ...
    Or maybe something else in this budget (+ scanner, + wifi)? May be mono laser.
  • #2 16256350
    płetwa
    Help: 165
    Rate: 551
    Drop 150 and buy a DCP T500W
  • #3 16256495
    granttt
    if I had a bigger budget, I had already bought the T500 :) but I will think ... thanks for the opinion
    At the moment, the closest to me to buy the DCP J105 (i.e. the version with wifi but no duplex and standard cartridges).
    In the future, I would like to buy refilling cartridges and original brother ink in bottles for the T300 / T500 models. I wonder if it makes sense? Rather, it shouldn't clog or void your warranty ...
  • #4 16273190
    cuoresportivo156
    Anything More Why You Should This DCP T500W?
  • #5 16273520
    płetwa
    Help: 165
    Rate: 551
    Cheap original inks, no combination with replacements.
  • #6 16273701
    cuoresportivo156
    Ok thank you for the quick reply.
    This is now just a quick question before buying.
    Better T500 or MFC-J5720DW?
    I am more inclined to 5720, but the only drawback here is the lack of duplex; /
    But cheap operation. I have to buy tomorrow - where is the cheapest?
  • #7 16273996
    płetwa
    Help: 165
    Rate: 551
    What do you compare? Office harvester with home printer. Besides, MFC doesn't seem to have a CISS system.
  • #8 16274014
    cuoresportivo156
    I know, the comparison may not be very accurate, but I can have it for the same money and I wonder which one to choose.
  • #9 16274072
    płetwa
    Help: 165
    Rate: 551
    See prices and performance of original inks! The T500 is more expensive to buy (because it has fewer functions), but you get CISS with half the price of inks and twice (at least) more efficiency.
  • #10 16274203
    cuoresportivo156
    Okay, all clear. So I will buy a T500, MFC-J5720DW and it would be too big ;)
The discussion revolves around selecting an inkjet printer with WiFi, duplex capabilities, and refill cartridge options within a budget of 550 PLN. The Brother DCP J105 is considered, but the Brother J480DW is noted for being cheaper and already having duplex functionality, although it has higher original cartridge costs. Users inquire about the feasibility of using refill cartridges with the J562DW and whether a chip resetter is necessary. There are mentions of using original Brother inks versus alternatives like Activejet and Dulin, with Activejet offering a warranty for service-related issues. Suggestions include considering the Brother DCP T500W for its cost-effectiveness in ink usage, despite its fewer features compared to models like the MFC-J5720DW, which lacks duplex but offers cheaper operation costs.
