Proxima Mini Remote Control: Copying, Frequency Info, Wiśniowski Garage Gate & Estate Barrier
BODZIO1986 10899 2
  • #1 16381341
    BODZIO1986
    Rate: 8
    Hello everyone,
    I have Proxima Mini remote control and use it to open the Wiśniowski garage gate and the barrier on the estate.
    Is it possible to copy the above remote control?
    I'm not sure what frequency it has, variable or constant?
    If the variable, which copying pilot would you recommend?
    Attached photo of the pilot.
    I am asking for help and thank you very much in advance.
    kotbury
    Gantry automation specialist
    Help: 2100
    Rate: 3631
    Variable code - no envelopes (they are Chinese, but they do not work even 30% confidently and cause a lot of trouble - you can temporarily disable the rest of the pilots).
    In addition, if this estate is you fall into the competence of the administrator - get rid of legal and headache.
  • #3 16381565
    BODZIO1986
    Rate: 8
    Everything is clear, thank you for the answer and arrange with the administrator.
    Please close the topic.
