Choosing Speakers for Strong, Deep Bass: Klipsch RF 82 vs. Altus 300 vs. Zeus Rock & Others
lukasz262 19725 13
How can I achieve much stronger, deep bass with a PLN 3,000 budget and an Onkyo A-8870, and should I choose Altus 300, Zeus Rock, STX F-360, or add a subwoofer?
To produce the requested stomach- and chest-compressing bass, add a properly designed powerful subwoofer rather than replacing the main speakers with Altus 300, Zeus Rock, or STX F-360 models [#16385812] [#16385922] A car-audio subwoofer is not a good solution for a room because a vehicle cabin creates much higher pressure in a far smaller volume, so connecting one through a subwoofer’s headphone output is not recommended [#16385812] One suggested DIY route is an STX W.27.500.8.FCX driver in a suitably low-tuned enclosure with a 500 W amplifier, while recognising that it may still not meet extreme expectations [#16385812] [#16408139] For music, the desired “fast” impact is often boosted kick-bass around 80–120 Hz, whereas cinema may contain genuinely deep frequencies below 40 Hz that require a dedicated subwoofer [#16398998] The budget-oriented Altus and STX F-360 designs prioritise loudness over quality; a better proposal is an STX FX-300 or Electrino 250 paired with an S-250N subwoofer, or suitable used speakers with a large subwoofer, after listening before purchase [#16402215]
  • Seeking high-impact bass speakers within a 3,000 PLN budget
    #1 16384157
    lukasz262
    I am looking for speakers that have a very strong bass that makes my stomach feel constricted. I had the Klipsch rf 82 speakers for two years, but I sold them over a year ago, currently I have 4 columns for Sony home cinema and on some songs with strong bass but only at maximum volume there is a feeling of squeezing in the stomach and on the chest as if my heart started beating faster and I expect this effect from the speakers but I would like it to be much stronger than on those speakers that I currently have. I have 3000 PLN to buy the columns. Of course, I was thinking about the Altus 300 (I heard the friend Altus 200 but outdoors) and about Zeus Rock (I did not hear them) but I do not know if they will have such strong bass I am looking for, they can also be other loudspeakers, and here I ask those who heard different loudspeakers for choosing the right ones. As for klipsch rf 82 they had a completely different bass than the one that is in those Sony speakers that I now have had to feel its vibrations all over the body and the objects were shifting and vibrating around the regiments but there is also nothing to exaggerate that it was some very strong, but as for the cramping in the stomach and faster heartbeat, nothing could be felt at all, this bass was just but rather medium, which is why I sold it.
    I am asking for a budget of up to PLN 3,000, the amplifier is Onkyo A-8870, 115 W at 8 ohms and 160 W at 4 ohms.
  • Subwoofer required for car-audio-like bass at home
    #2 16384747
    telecaster1951
    Help: 829
    Rate: 818
    lukasz262 wrote:
    Of course, I was thinking about Altus 300 (I heard a friend Altus 200 but outdoors) and Zeus Rock (I didn't hear those)
    You have high bass here and here. I understand that you expect something like you have in caraudio? I will say right away that car speakers will not work. This way you won't generate such bass at home.
    There are no speakers in the world that would sound the way you describe it. You need a subwoofer for this application.
    What is your room size?
  • Seeking high-impact speakers and subwoofer recommendations for home
    #3 16385488
    lukasz262
    Well, in car audio you can hear better how strong the bass is, showing how hair flutters under the influence of the bass. The room is 20 m, but if I buy stronger loudspeakers I can move them to a room about 40 m, and if you can't use car audio speakers at home, what speakers would you recommend so that there is even a little squeezing effect on the stomach and faster heartbeat. The subwoofer has a weak Sony 20 cm, and whether it makes sense to connect through the headphone jack in the subwoofer amplifier just typically to the car stereo with a built-in amplifier in the bass box and separate speakers for the house because I was also thinking about it.
    e.g. something like this:
    http://allegro.pl/tuba-basowa-subwoofer-aktywny-peiying-py250qa-500w-i6670185196.html
    or possibly provide some other suggestions for columns and subwoofers
  • Recommend STX W.27.500.8.FCX for deep room bass
    #4 16385812
    telecaster1951
    Help: 829
    Rate: 818
    There is no point in inserting other columns. No column will play like this!
    lukasz262 wrote:
    and is there sense to connect through the headphone jack on the subwoofer amplifier just typically to the car stereo with a built-in amplifier in the bass box and the loudspeakers separately at home because I was also thinking about it.
    No. In the car, the subwoofer works in a small box (what is the volume of the car cabin?) And these pumps create high pressure. Just. The situation is completely different in the room. Big larger volume of air, walls, reflections. Here you have to get more tired.
    You can buy STX W.27.500.8.FCX. Its can be tuned very low, plus a 500 watt amplifier (remember not to exceed the clip). For this adaptation of the room, i.e. curtains, rugs, etc. and this effect can be achieved.
    It would be unheard of for me, I don't know for you. It may turn out that it's still not enough for you, but then you have to go to subwoofers, even stage speakers.
    If this STX is not enough for you, the only thing I can think of is: http://akustyk.com.pl/p/100/171/scan-speak-32w8878t01
  • #5 16385848
    lukasz262
    and would the STX 360 N speakers be a better choice than the Tonsil Altus 300 or Zeus Rock, which of these three are the best when it comes to the bass base they have?
  • Subwoofer required for truly deep bass
    #6 16385922
    telecaster1951
    Help: 829
    Rate: 818
    None of these jitters will give you this effect. You had great speakers, but you sold them for KD junk.
    Altus and Zeus play with high bass, with a screaming treble. In addition, the Zeus have no midrange.
    STX F-360 n is total junk. Above 1kHz they play terribly! In addition, these 30 Hz is also a wishful thinking.
    Don't get the mess, it's a waste of money. If you want to have the bass you are talking about, then you must have a subwoofer.
  • #7 16398419
    lukasz262
    anyone has any other proposals in the budget up to 3000 PLN
  • #8 16398998
  • #9 16400590
    lukasz262
    cefaloid wrote:
    I doubt it - Telecaster suggestions and advice are optimal what you can do.
    And answer the key question: what is it supposed to be for?
    - to music
    - or for movies
    If it is for music, it is very rare here to deal with a low-reaching bass, i.e. with tones below 40hz, because there are almost no instruments that produce such a low bass unless you are a fan of organ music. What you might like so much about the altuses is so-called kick-bass, i.e. the 80-120Hz band in which the band works, e.g. drums. This boost gives a very deceptive impression of 'strong and fast' bass, which is eagerly used by producers of various budgetary instructions that are supposed to make any noise. Here, it will not be about how low the loudspeakers go down, just how high the level of acoustic pressure will be able to evoke the bass you are looking for. Not necessarily the lowest bass. I don't know, maybe give us also the type of music you listen to because it sometimes helps to choose the most suitable sound of the columns.
    If it's supposed to be for home cinema ... well, there may be sounds well below those 40hz. And here, indisputably and irrevocably, you must have a specific subwoofer and you will not jump over it. Not and now. But the lowest frequencies are no longer fast as drums ... they are quite lazy ...
    70% music, 30% cinema
  • Avoid boom-focused Altus; consider STX FX-300 with subwoofer
    #10 16402215
  • #12 16408139
    telecaster1951
    Help: 829
    Rate: 818
    With the fact that a colleague has 3 thousand. As for me, there is no other option than to build a subwoofer on the speakers I proposed. However, it will still not be the effect that can be achieved with this Paradigm.
  • #14 16408454
    telecaster1951
    Help: 829
    Rate: 818
    RMS.pl wrote:
    Of course I'm aware of how much he has. I just want to point out the disproportionate expectations to the budget.
    I know, that's why I wrote it so that the author was aware of how absurd his requirements are in relation to the budget he has.
The discussion revolves around selecting speakers that deliver strong, deep bass, with the user expressing dissatisfaction with their current Sony home cinema setup. They previously owned Klipsch RF 82 speakers and are considering alternatives like Altus 300 and Zeus Rock, but are uncertain about their bass performance. Responses emphasize the necessity of a subwoofer for achieving the desired bass effect, as typical speakers cannot replicate the intense bass experienced in car audio systems. Recommendations include STX W.27.500.8.FCX and caution against models like STX F-360 N, Altus, and Zeus for their inadequate bass response. The conversation also highlights the importance of room acoustics and the limitations of budget in achieving high-quality bass.
