Comparing STX T.10.200.8.ALX & Seas 27tbfc/g Speakers for Rock, Chillout, Electronic & Pop
mathew01_1996 4533 5
  • #1 16184055
    mathew01_1996
    Hello!
    Has anyone seen these speakers and would say something about the sound? I want to build monitors and I don't know what project to choose. I want to switch from altus 110. I listen to rock / chillout / sometimes some electronic or pop music.
    I was thinking of designing with these 18 STX AWX tweeters. I have never heard these speakers, but I think it should be better than the A110 in any case.
    best regards
  • Seas preferred, but STX is a cheaper upgrade
    #2 16184498
    telecaster1951
    Help: 829
    Rate: 818
    Anything is better than the GDWT 9/40.
    Seas will be the better of the two. However, if you have listened to this GDWT so far, I think you can safely use STX. Firstly, twice cheaper, secondly, it will be time before you switch your hearing to the domes. Generally, the first thing you will hear after going from this crap is that something above 14kHz is also playing.
    The only question is whether you have a good crossover design on this speaker.
  • #3 16184870
    ven0n
    Help: 5
    As far as I know, ALX sounds very soft, so my friend, after switching from GDWT, may be slightly disappointed with the lack of a "tick"
    Maybe PCX is better?
  • Recommends better, cheaper alternatives to AWX and Seas pairing
    #4 16185034
    marian133
    Help: 426
    Rate: 572
    I've heard the project with Seas and don't recommend it.
    As for the ALX and the AWX project, which project do you mean?
    If this one:
    https://www.elektroda.pl/rtvforum/topic3289042.html
    ... let it go, because it's not correct.
    I want to change from altus 110.
    Then maybe immediately get interested in this project:
    http://diyaudio.pl/showthread.php/24374-quot-...X-i-wysokie-do-wyboru-do-koloru-)-projekt-by- raven1985
    ... or if you insist on 2way then this:
    http://diyaudio.pl/showthread.php/25545-STX-W-18-200-8-MCX-T-10-200-8-PCX-( or-PC)-projekt-by-Pawel-S
    Cheaper and not necessarily worse.
    I do not recommend the AWX with Seas, for this price you can put together better loudspeakers, e.g. for the SBacoustic:
    http://www.troelsgravesen.dk/SBAcoustics-61-NRXC.htm
  • #5 16185462
    mathew01_1996
    If this one:
    The monitors appeal to me more than the great 3way. The design for sbacoustic is very interesting, but making such a cabinet is a lot of fun. What do you think about these projects?
    http://www.zaphaudio.com/audio-speaker17.html
    http://www.zaphaudio.com/SR71.html
    http://audiohobby.pl/index.php?topic=215.0
    I think the monitors have enough bass to please me. In order for the bass to be heard something, I have to boost them anyway + 6dB and it does not go down low, although I have them modified a bit.
  • #6 16185534
    marian133
    Help: 426
    Rate: 572
    The 1st and 2nd design, looking at the characteristics, will not have much bass.
    See how Troels modifies the characteristics to make the structure play bass. It has a sloping characteristic, because the flat, even characteristic in the design causes a lack of bass.
    I cannot see the measurements from the 3rd project, I will not say anything.
    Overall, all 3 projects should play on a level, but I personally would take something from Troels' projects. On Seas, it also has the following structures:
    http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm#SEAS
