nokia c2-02 - internet configuration in the lycamobile network
robert1808 5733 12
Jak skonfigurować internet w Nokia C2-02 dla sieci Lycamobile?
Ustaw APN na `data.lycamobile.pl`, nazwę użytkownika `lmp` i hasło `plus` [#16399846] Jeśli szukasz miejsca wpisania tych danych, w tym modelu chodzi o ustawienia połączenia pakietowego / punktu dostępu [#16413161]
  • #1 16387637
    robert1808
    Rate: 20
    I have Nokia C2-02 and I cannot cope with the internet configuration in the Lycamobile network. I know from the consultant that you need to enable data transfer, add APN to data roaming, and enter data.lycamobile.pl. Despite this, I do not know how to do it, so I am asking for help.
  • #2 16391365
    robert1808
    Rate: 20
    Is no one really using such a phone anymore?
  • #3 16391396
    nutergsm
    Help: 1034
    Rate: 1665
    Look for manuals for this model or similar, you should have it described there.
  • #4 16391487
    robert1808
    Rate: 20
    I have read the manual and I must say that it relates to the use of the telephone. There is nothing there about the configuration. I think someone who uses this model can help here.
  • #5 16391491
    nutergsm
    Help: 1034
    Rate: 1665
    Have you checked the settings on your phone, tried to change something?
  • #6 16392021
    robert1808
    Rate: 20
    This is how I tried to change various options and entered what the Lycamobile consultant indicated in different places. Only on this phone these options have different names and I do not know where to enter and what to enter.
    Added after 5 [hours] 12 [minutes]:
    Need internet setup nokia c2-02 help!
  • #7 16398842
    robert1808
    Rate: 20
    NOKIA C2-02> settings> connections> available here> Bluetooth, Packet data, USB cable
    I choose Packet Data and there are two options> Connect. data package. and Set. data package.
    Merge package data. I set it to then go on to
    Set data package. and here there are I enter Lycamobile and go to and here they are to set enter Lycamobile and enter www.data.lycamobile.pl
    Will it be okay?
    Added after 4 [minutes]:
    Unfortunately it does not work. How to set it up, help.
    Added after 13 [minutes]:
    Added after 1 [hours] 47 [minutes]:
    I FOUND CONFIGURATIONS ON THE ORANGE NETWORK BUT HOW TO DO IT ON THE LYCAMOBILE NETWORK?
    To set up Internet in ORANGE network in Nokia / Microsoft C2-02 phone, please follow the steps below:
    Enter the MENU
    Select SETTINGS and then CONFIGURATION.
    Select PERSONAL SETTING
    If no configuration, press ADD, otherwise press OPTION, then ADD NEW.
    In the next step, choose INTERNET
    Enter Orange Internet in the ACCOUNT NAME field
    In the USER NAME field. enter internet
    Enter internet in the PASSWORD field
    PREF field. ACCESS POINT set to NO
    Select SET. ACCESS POINT and set the PROXY field to OFF
    Enter SET. MEDIA
    In the field ACCESS POINT. DAN. Enter internet
    Select IPv4 as the NETWORK TYPE
    In the USER NAME field. Internet
    Press BACK three times
    Mark the entered Orange Internet configuration (holding it down) and then select ACTIVATE
  • #8 16399846
    nutergsm
    Help: 1034
    Rate: 1665
    Set APN like this: data.lycamobile.pl
    User: lmp
    Password: plus
  • #9 16412758
    robert1808
    Rate: 20
    In my last message, I presented what options are available in this model. And I don't know which one is APN - that's the whole problem.
    Is APN the account name because there is a place for the user and password under it?
  • #10 16412820
    nutergsm
    Help: 1034
    Rate: 1665
    It would seem.
  • #11 16413161
    robert1808
    Rate: 20
    And maybe so:
    In the field ACCESS POINT. DAN. Enter: data.lycamobile.pl
    In the USER NAME field. type: lmp
    Enter: plus in the PASSWORD field
    I just don't know what an APN is.
  • #12 16413349
    siudziu
    Help: 57
    Rate: 113
    I have been struggling with the internet recently in se w810 and, unfortunately, I also did not manage to set anything up such a sad truth that you will not connect to the keys :( . In the case of lyca mobile, you must remember that this network does not support MMS, so the question is what in noki c2-02 internet?
  • #13 16896834
    SmysA
    Rate: 14
    I have the same problem, I can only answer that I want to use the phone as a modem. Since I have it for foreign connections at a good price and additionally internet in the package. I'll let you know if I can.
The discussion revolves around configuring internet settings for the Nokia C2-02 on the Lycamobile network. The user seeks assistance in enabling data transfer and setting the Access Point Name (APN) to data.lycamobile.pl, as advised by a consultant. Various responses suggest checking the phone's settings, referring to manuals, and entering specific configurations. Key steps include navigating to settings, selecting packet data, and entering the APN along with user credentials (username: lmp, password: plus). However, users express confusion regarding the terminology and specific settings on the Nokia C2-02, leading to ongoing challenges in establishing a working internet connection.
