How to uninstall McAfee? - McAfee removal status has been going on for 4 weeks .
janiszk 6876 11
How can I stop a McAfee uninstall that has been stuck and freezing my laptop for weeks?
End the stuck McAfee process in Task Manager, especially if it appears as “McAfee Ul Host,” and then let the uninstall continue [#16389123] [#16389146] [#16389151] If the laptop does not respond, open Task Manager with Ctrl+Alt+Delete and use End Task/Finish job; if that still fails, force a shutdown with the power button and try again in Safe Mode [#16389123] [#16389127] [#16389143] Another suggested option was McAfee’s cleanup tool, VSCleanupTool.exe: download it, save it to the desktop, run it, and follow the instructions [#16389120] In the thread, ending the McAfee process made the removal succeed and the laptop start working again [#16389187]
  • #1 16389101
    janiszk
    Please help. The uninstall process has been going on for 4 weeks ... What should I do? The laptop is unusable. You can only see the program message: delete status, wait, LifeSafe removal, status: ongoing
  • #2 16389110
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Have you tried through safe mode to uninstall it?
  • #3 16389117
    janiszk
    I can't do anything on this laptop right now. Does not respond. The answer to your question is: no, I did not try to uninstall it through safe mode, because there was no such need before.
  • #4 16389120
    Heniek56
    Help: 6
    Rate: 18
    download and save to the desktop a special tool to uninstall McAfee anti-virus: VSCleanupTool.exe double-click the file VSCleanupTool.exe to run it, follow the instructions
  • #5 16389123
    RADU23
    Help: 2428
    Rate: 1732
    CTRL + Alt + Delete => task manager => processes => terminate process.
    janiszk wrote:
    no, I did not try to uninstall it via safe mode, because there was no such need before.
    So give it a try
  • #6 16389127
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Then turn it off, restart in safe mode and try to uninstall the problematic program.
  • #7 16389133
    janiszk
    I'd love to do it, but how if I can't do anything on this laptop. HE DOES NOT RESPOND. ONLY THIS PROGRAM MESSAGE IS DISPLAYED THAT UNINSTALLING TRW A.
    OKAY. Beautiful thanks, I got to the task manager. I clicked FINISH JOB ... I'm waiting for the result.
  • #8 16389143
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    If nothing reacts then you are turned off by holding the Power button.
  • #9 16389146
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    But what process did you finish? Check in the task manager which process consumes the most RAM or / and Prock.
  • #10 16389151
    janiszk
    McAfee disappeared from the list of tasks to be completed for a moment and reappeared after a while. I clicked FINISH JOB again.
    Added after 5 [minutes]:
    McAfee Ul Host is on the Task Manager list. I selected it with the cursor and click FINISH JOB. Waiting for effect ...
  • #12 16389187
    janiszk
    Thank you. The operation was successful. The laptop is coming again !!!!!!!!!! Baaaaaaaaaaaaa thank you !!!!!!!!
The user reported an issue with uninstalling McAfee, which had been stuck for four weeks, rendering the laptop unusable. Various solutions were suggested, including attempting to uninstall in safe mode, using the VSCleanupTool.exe for removal, and terminating processes via the task manager. After some troubleshooting, the user successfully managed to terminate the McAfee process, leading to the successful uninstallation of the software and restoring laptop functionality.
