Daelim S1 125 FI 2010: Scooter Won't Start Despite Spark and Fuel - Possible Causes & Solutions
srebny22 7017 5
  • #1 16389862
    srebny22
    Hello colleagues and I am asking for help. The case is as follows. The scooter does not want to start, the spark is on the candle, the fuel comes and it does not want to start. This situation started with the fact that I drove to the house and the scooter went out, looking at the indicator I thought that the fuel ran out, so I bought fresh and preferred but did not start anymore. I am asking for advice. greetings
  • #2 16390251
    citromaniak
    Help: 53
    Rate: 394
    pour some fuel into the cylinder if it does not start, a weak spark or no compression
  • Checking for incorrect ignition timing despite good spark and compression
    #3 16390959
    srebny22
    My friend poured fuel into the cylinder and it did not work, I also did a test with plaque and lime. As for compression, it is also good because 8.7. I wonder if there is a possibility that the spark appears at the wrong moment, what needs to be done and how to check it and what could be responsible for it. I will add that the scooter is on injection. Before that, he was smoking from an arrow. On the last ride he was suffocated for a while but it passed, but after the drive to the house he went out and here the problem with starting began. A beautiful spark, a new candle
  • #4 16392159
    sk700
    Help: 173
    Rate: 420
    Check also the wedge fixing the position of the magnet wheel. If there is spark at the right moment, compression is there, fuel is still not burning, call an exorcist :)
  • #5 16392297
    BANANvanDYK
    Help: 1167
    Rate: 2602
    It is unlikely to cut a wedge in a modern engine - to make sure that the T mark on the magnet wheel aligns with the physical upper blind spot (something inserted into the candle hole).
    If okay then check with the strobe that the spark is in the right place (F mark if present).
    BTW. Also check the spark plug, the length of the spark.
  • #6 16393000
    srebny22
    Thanks gentlemen, I will check it out today and let you know. greetings
