Quad Bike 110 for Children: Spark & Fuel Present, But Fails to Start - Possible Causes & Solutions
KrystianGa 6630 4
  • #1 16509937
    KrystianGa
    Hello. I'm new here, I'd like to test your skills. But seriously, I have a small problem with a small quad bike 110 for children :)
    I bought it damaged. I checked everything, and here the problem begins, because the quad does not start even though there is a spark and fuel is coming :)
    Checked :
    -module
    -Isystrator
    -shaft condition
    - cylinder condition
    -the state of the rings
    - the condition of the head
    - I measured the compressions
    -checked the timing
    - second carburetor fitted
    -fun
    -candle
    Well, what do you say, gentlemen? :( anyone have any ideas? I tried for a cake, it also does not speak :)
  • #2 16509966
    lord5543
    I suggested that I check the ignition switch, a friend had a similar problem in bashan 200, he checked all the electronics, there was a spark on the candle but it was weak, he replaced the ignition, the quad lit
  • #3 16509969
    KrystianGa
    The installation is done in a short time, the spark plug is 3 cables, modul, and the coil in the candle.
  • #4 16510046
    lord5543
    is the spark but weak ??
  • #5 16603535
    rafcio_21
    Help: 137
    Rate: 295
    Try on another module of such a quad, I also repaired everything like a spark, fuel, timing and no smoking. It turned out that the ignition module was to blame for everything.
