LCD LG 32LW570S - LED is blinking, does not turn on from standby.
janomo 6342 4
  • Suspected LGE34230 BGA failure causing missing inverter enable signal
    #1 16391627
    janomo
    Help: 45
    Rate: 247
    ON TV:
    matrix: LC320EUD (SD) (P1)
    main: EBT61537556 EAX64405501 (0)
    The PSU, after being switched on from the standby mode, gives the correct voltage: 24V, 12V, 3.5V.
    The diode flashes slowly all the time, the TV can be turned off to standby.
    The main voltages are also correct: 0.9V, CPU core voltage, 1.2V, 3.3V, 5V. There is no voltage on the logic - the system supplying this voltage is operational.
    There is also no voltage that activates the inverter - when applied artificially - the backlight turns on.
    The main processor in this TV is LGE34230 - it warms up slightly.
    I am inclined to reballing this processor.
    Here https://www.elektroda.pl/rtvforum/topic2996427.html#14498585 helped reballing. Can anyone confirm this?
    Or maybe it's better to look for a new main immediately? But up to 32 inch, the customer may not decide.
    Best regards.
  • #2 16391655
    mirex
    Help: 1950
    Rate: 1990
    Do what they do. ;) And it wasn't any reballing to my liking. ;)
    If you were to put it on again, you'd better buy a new chip. ;)
    Where can you buy for a human price new main? ;)
  • #3 16391722
    janomo
    Help: 45
    Rate: 247
    mirex wrote:
    Do what they do.
    I do not understand. Since they write about soldering, it seemed to me that it was about reballing. Is it just a paste about overheating the system?
    Why a new layout?
  • #4 16391807
    grubas
    Level 40  
    Help: 647
    Rate: 553
    Reballing is a removal of the circuit, placing new balls and re-soldering the circuit.
    Reflow, in turn, is a soldering of the system so that it starts to float.
    If the core of the system is damaged, nothing will help but replace it with a new one.
  • #5 16395609
    janomo
    Help: 45
    Rate: 247
    The client wanted a fast and reliable TV set. He decided to replace the main without any problems. So I replaced the entire module.
