#1 20680659 04 Aug 2023 14:16 mdaa mdaa Level 3 Posts: 87 Rate: 2 Topic author Post #1 20680659 04 Aug 2023 14:16 Marka: LGModel: 32lb1rChassis (płyta lub główne podzespoły): ml-051b 68709m0045aMatryca/Panel (jeśli występuje):Inne (uwagi): precisava de arquivo flash para este LCD
#2 20714941 30 Aug 2023 18:31 querij querij Level 21 Posts: 375 Help: 42 Rate: 227 Helpful post? (0) Post #2 20714941 30 Aug 2023 18:31 Tente aquecer a mainboard com um aquecedor
#3 20715048 30 Aug 2023 19:31 bajdu bajdu Level 31 Posts: 1294 Help: 193 Rate: 327 » | Helpful post? (+1) Post #3 20715048 30 Aug 2023 19:31 Is the power supply working?
#4 20724839 07 Sep 2023 20:09 mdaa mdaa Level 3 Posts: 87 Rate: 2 » | Topic author Helpful post? (0) Post #4 20724839 07 Sep 2023 20:09 Thank you for your attention. Problem solved. 5 V standby electrolytic capacitors
#5 20842036 01 Dec 2023 20:32 mdaa mdaa Level 3 Posts: 87 Rate: 2 Topic author Helpful post? (0) Post #5 20842036 01 Dec 2023 20:32 substituicao condensadores electroliticos 5v standby
