Audi A4 B6 2001: Locating Door Open/Close Signal Wires for Alarm Installation - Comfort Module
bossmax 8670 10
Where can I find the door open/close signal wires in an Audi A4 B6 (2001) for an alarm install, without removing the seat or carpet?
Use the driver's door wiring, not the comfort module under the seat; the central-locking open/close signals are in the door module and the system is ground-controlled [#16394646][#16403277] One reply identifies the black connector on the module near the window motor in the driver's door as the place to look for the signal [#16403277] Another reply says a black 16-pin plug under the seat has a red-yellow wire that gives a + pulse when the rear door is opened/closed, but that signal does not control the whole car's lock/unlock [#16395154][#16396905] The module under the carpet is reported to carry only interior-lighting-type signals and receive CAN from the door modules, so it is not the right place for the full lock/unlock trigger [#16394646]
  • #1 16393069
    bossmax
    Rate: 76
    Hello. I am looking for a signal to open and close the door in audi a4 b6 2001. I need it to mount an alarm. Arming by closing signal and disarming by car opening signal from remote control. I mean a positive impulse. I know that these signals come from the comfort module which is under the driver's seat. My question is where these wires go on and what color they are. My point is not to dump the seat or the carpet but to find these wires somewhere more accessible. After all, these wires somewhere must go to some cube.
  • #2 16393085
    frankrom
    Level 19  
    Help: 23
    Rate: 151
    There, look for signals in the driver's door.
  • #3 16394574
    bossmax
    Rate: 76
    Approx. I'll check tommorow. Maybe in fact in the door I will find these signals because in the door there is a lock and window module, but this does not change the fact that I still have a question where are the wires from the Mk module from under the seats? If they were in the door under the upholstery, I will be pushed through a 20-pin connector in the post.
  • #4 16394646
    frankrom
    Level 19  
    Help: 23
    Rate: 151
    From this module under the rug you cannot take out the closing and opening signal of the central locking. There are signals only from the interior lighting, etc. There are modules in the door and signals from the lock come to them followed by a can signal to this module under the carpet.
  • #5 16394942
    bossmax
    Rate: 76
    Approx. We will fight and see. I always thought that the module responsible for lighting is the one under the steering column.
  • #6 16395088
    frankrom
    Level 19  
    Help: 23
    Rate: 151
    The one under the column is from external lighting.
  • #7 16395154
    bossmax
    Rate: 76
    I found. From the module under the seat comes out of the black 16-pin cube the red-yellow wire to control the rear door. The plus pulse appears after opening and closing the door.
  • #8 16396905
    frankrom
    Level 19  
    Help: 23
    Rate: 151
    Yes the signal is there because they are at the back of the windshield crank but with this signal you can not close and open the entire car.
  • #9 16397327
    bossmax
    Rate: 76
    So I keep looking.
  • #10 16403277
  • #11 16605601
    bossmax
    Rate: 76
    I'm closing the topic.
The discussion revolves around locating the door open/close signal wires in a 2001 Audi A4 B6 for alarm installation, specifically seeking a positive impulse from the comfort module located under the driver's seat. Participants suggest checking the driver's door for signals, noting that the central locking signals are not directly accessible from the comfort module. A key finding is that a red-yellow wire from a black 16-pin connector under the seat controls the rear door, providing the necessary signals upon door operation. Additional insights mention the black connector near the windscreen motor as a potential source for ground control signals.
