Upgrade Windows 7 Professional 32bit to 64bit: RAM, System Partition, Compatibility
pytlowany1 7461 12
How can I reinstall Windows 7 Professional 32-bit as 64-bit, and what should I know about RAM, partitions, and program compatibility?
Yes—on this PC it is worth installing the 64-bit version, since 6 GB of RAM is installed but only about 3.49 GB is usable under 32-bit Windows [#16397754][#16397776] Make a clean reinstall: back up everything from C: first, because a normal installation on C: will erase the current system and programs, and then boot from a USB installer created with Rufus [#16399332][#16399773] You can install Windows 7 x64 on the C: partition or on the second 500 GB disk; installing it on another partition/disk lets you keep the old system as a fallback [#16399773][#16400437] The thread did not name any specific programs that fail on x64 [#16397776]
  • #1 16397738
    pytlowany1
    Rate: 90
    I am computer green.
    Please support me how to reinstall on 64x.
    I understand that it can be imposed on the system partition?
    I have Windows 32bit Professional.
    I want to change to 64x mainly due to the reduced amount of RAM.
    Are there any minuses of the 64x version?
    Can some programs not work on 64x?
    Regards
  • #3 16397754
    pytlowany1
    Rate: 90
    Motherboard: ASUS P7P55-M
    Processor: Intel Core i5 650 3.20 GHz
    Graphics: ASUS ATI Radeon HD5670 1GB
    RAM: 6GB GOODRAM (3.49GB available)
    Windows 7 32-bit
  • #4 16397776
    Kasek21
    Help: 4981
    Rate: 3547
    Install the 64bit version without any worries.
  • #5 16397792
    pytlowany1
    Rate: 90
    Ok, can you please step by step?
  • #7 16399332
    rafal131313
    Help: 27
    Rate: 181
    From 32bit to 64bit, I have not seen such a transformation without a form.
    pytlowany1 wrote:
    RAM: 6GB GOODRAM
    It's definitely worth changing.
    First, rip the data from the c: partition because they will be lost.
    Make a so-called bootable flash drive with the help of e.g. Rufus (of course you need an iso image with the system)
    https://rufus.akeo.ie/?locale=pl_PL
    Then the computer starts so that it doesn't start Windows normally, just the pen ...
    e.t.c...
  • #8 16399752
    pytlowany1
    Rate: 90
    Rafał is not a failure, I have 6GB and here it shows 3.5GB - who came up with something like that ...
    Can I just put a new system on partition C? All data, photos, files have D and C only system and programs, so they will go down the drain.
  • #9 16399773
    Kasek21
    Help: 4981
    Rate: 3547
    Yes.
  • #10 16399975
    rafal131313
    Help: 27
    Rate: 181
    I would rather not make an overlay, I can do it but after a while something usually falls apart.
    As soon as you install it on 2 partitions and you will have 2 systems :)
  • #11 16399979
    Kasek21
    Help: 4981
    Rate: 3547
    Is to perform a normal installation on the C partition and writes about it!
  • #12 16400324
    pytlowany1
    Rate: 90
    Listen and I still have such an idea. I have two 500GB disks included.
    I will install x64 on the second disk and give boot from it. In case I can always change to boot from 1 disk in old Bios or x86.
    In total, one Windows only takes 20GB :)
  • #13 16400437
    rafal131313
    Help: 27
    Rate: 181
    There can also be 2 systems on one disk only on another partition.
    There is no need to enter the bios after installing Windows at startup asking you which system you want to turn on.
The discussion revolves around upgrading from Windows 7 Professional 32-bit to 64-bit to utilize more RAM, as the user currently has 6GB but only 3.49GB is accessible due to the 32-bit limitation. Key steps include backing up data from the C: partition, creating a bootable USB drive using tools like Rufus, and performing a clean installation of the 64-bit OS. Users express concerns about data loss and compatibility with existing programs, but it is generally agreed that a fresh installation is necessary for the transition. Some users suggest installing the new OS on a second disk to avoid complications with the existing setup.
