Choosing Between Windows 10 Pro 64 and Windows 7 Pro 64 for a New Desktop (2018)
Magic_moon 16743 13
Should I install Windows 10 Pro 64-bit or Windows 7 Pro 64-bit on a new desktop for data recovery, music, and movies?
Install Windows 10 Pro 64-bit unless you have a specific old program or driver that requires Windows 7; several users report that Win10 runs older tools fine, while Win7 is increasingly problematic on newer hardware and for driver support [#17111203] [#17111512] [#17112828] One reply notes that Win7 can become impossible to install on 6th-generation-and-newer CPUs, so for fresh machines Win10 is the safer choice [#17111202] The main downside mentioned for Win10 is that updates can change drivers or reset settings, so some users disable automatic updates to avoid surprises [#17112219] [#17112909] A minority still prefer Win7 because it gives more control and has fewer services, but the thread overall leans toward Win10 [#17112909] [#17495498]
  • #1 17111159
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    Hello. I have two original systems, Windows 10 pro 64 and Windows 7 pro 64. I bought a new desktop computer. And I would like to ask experienced colleagues what the system would recommend. I use my computer to recover data, listen to music and watch movies. I am asking for the opinions of more experienced colleagues. Thank you and best regards.
  • #2 17111174
    Matuzalem
    Help: 1653
    Rate: 1101
    Your post does not contain any information that gives you a reason to make a sensible choice.
    PS
    The title of the thread is sure to look like it looks like?
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #3 17111189
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    I have intel (r) core (tm) processor i7-3770 cpu @ 3.40ghz
    SSD 250 silicon power
    Memory of 32GB frames
    450W Corsair power supply
  • #4 17111202
    Matuzalem
    Help: 1653
    Rate: 1101
    And so we will be ticking - i7 generation ...? - If you have a newer one (6+), please give peace of mind with Windows 7, because you will soon be looking for the reason for the lack of possibility to install this system.
    PS
    Please refer to the forum regulations - point 3.1.15 and global rules "in computers" and start to treat seriously what should be included in the post when seeking help.
    Doradztwo podatkowe
  • Recommends Windows 10 over Windows 7 for compatibility
    #5 17111203
    malik123
    Help: 11
    Rate: 37
    I defended myself a long time before switching to Windows 10, I did it only at the end of last year directly from Windows 7
    I'm very happy. So I recommend Windows 10. If you put everything right, it is much better than Windows 7. there is no conflict of programs, eg I have fw comodo from 2011 and I am working great.
    I was afraid of backward compatibility with the programs, but they all cope, even the tools are easy to go, like Victoria.
    Install Windows 7 upgrade for free to Windows 10 and Windows 10 for sale :)
  • #6 17111402
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    And I have a question yet. Is it often happens that programs with Windows 7 do not work on Windows 10?
  • #7 17111512
    malik123
    Help: 11
    Rate: 37
    I just wrote, it did not happen to me. Even like Victoria, or fw from 2011. All you have to do is to disable some kind of incompatible programs, because you do not install the old software, but you turn it off and everything is nice :)
  • #8 17112219
    iagre
    Help: 213
    Rate: 281
    I know from experience that Win10 likes to lose the settings and change the drivers at the time of the update. That's why Win10 definitely falls out.
  • #9 17112251
    sylweksylwina
    Help: 1882
    Rate: 2355
    Windows 10 can evade a joke for a long time.
    Even if it works without any problems, after a build update there may be some surprise.
  • Recommends Windows 10 after early update issues settled
    #10 17112433
    malik123
    Help: 11
    Rate: 37
    holy ration, that's why I do not have the update turned on :)
    I really defended myself for a long time before w10, but it was unjustified, and it happened that I was selling a laptop and updated to W10 out of curiosity. Then instead of the laptop I got rid of the PC for a while, so I came back to the paw with W10, I can say that I regret it, I could do it differently and switch to it much earlier as it grew out of childhood diseases :)
    And as I mentioned, I chewed on him with W7 so I can see the 'traditionalists' W8, 8.1 and early build y W10 politely waited. But I remember I had the same thing with the same, I also forgot it for a long time 2000 ME, and XP did not make it until after some time, the story was repeated with W7 Viste and the first W7 also skipped. I will not attract tradition anymore because the next MS no longer announces eternal updates, which is why I have successfully blocked them.
    In summary, I recommend W10
  • #11 17112552
    bodek60
    Help: 6
    Rate: 23
    I have a W10 from the beginning and I have no problems with it, automatic updates enabled.
  • #12 17112828
  • #13 17112909
    nici
    Help: 266
    Rate: 979
    W10 does too much without knowledge / questions from the user. It is possible to write a poem about the fact that it changes the drivers to not working.
    W7 does not have the above-mentioned defects. I use both systems, and everyone has their pros and cons. You decide which one fits you better because both are good.
  • #14 17495498
    dnetsky
    Rate: 25
    How do you look at the number of Win10 and Win7 services (in my case the Pro version)
    Win7 has much less
    Win10 has a lot more services that already in the latest version of NO DA to turn off even from the level of Admin !!!
    so you can see exactly what Microsoft is aiming for
    There are a lot of services that have a user ID in the name and only Microsoft knows what they really do
    fishing can not be turned off either
    In total, with Windows 10, you can do less with the update for updates on your system
    Windows10 with update on the update is getting smarter than you to be more comfortable
    Win7 is what it was and does not limit your possibilities
    Oddly, after installing both systems, Win10 takes up much less disk space
    And now you have to answer the question ... are you a comfortable user and you want Win10 to overload you from the configuration and thus from the access to the system
    Do you prefer to get a little more tired from the old and have full, almost full control over the Win7 system
    It is true that Win10 often poses problems for its self-importance: drivers mentioned above, but also the exchange of networks for the public, and disconnecting services during the update ... and they sometimes last several days and sometimes the printers are disconnected just ... until the update is finished
    Good luck in your choice
The discussion revolves around the choice between Windows 10 Pro 64 and Windows 7 Pro 64 for a new desktop setup. Users share their experiences, highlighting that Windows 10 is generally more compatible with modern hardware and software, especially for newer Intel processors. Many recommend Windows 10 for its improved performance and compatibility with applications, while some express concerns about automatic updates and driver changes that can disrupt functionality. Windows 7 is noted for its stability and fewer background services, appealing to users who prefer more control over their system. Ultimately, the choice depends on user preferences, software requirements, and hardware compatibility.
TL;DR: Windows 10 Pro 64 is the safer pick for your i7‑3770 desktop; one upgrader hit 0 incompatible apps and said, "I'm very happy. So I recommend Windows 10." [Elektroda, malik123, post #17111203]
Why it matters: This FAQ helps owners choosing between Windows 10 Pro 64 and Windows 7 Pro 64 for a new desktop focused on data recovery, music, and movies.
What’s the better choice for an i7‑3770 desktop: Windows 10 Pro 64 or Windows 7 Pro 64?
Choose Windows 10 Pro 64 for broader compatibility and smoother upgrades from Windows 7. A user upgraded and hit zero app conflicts. They added, "I'm very happy. So I recommend Windows 10." For everyday tasks, Windows 10 handled older tools reliably in this report. [Elektroda, malik123, post #17111203]
Do Windows 7 programs usually work on Windows 10?
Many do. One upgrader reported no compatibility failures and cited even older utilities working. They wrote, "it did not happen to me." They named Victoria and a 2011 Comodo Firewall as functioning under Windows 10. Test your must‑have apps first, but results here were positive. [Elektroda, malik123, post #17111512]
Can I install Windows 7 on newer Intel CPUs?
It can be difficult or impossible on 6th‑gen and newer Intel platforms. A moderator advised skipping Windows 7 in those cases. They warned you will search for why installation is not possible. For older generations, installations remain more feasible with proper drivers. [Elektroda, Matuzalem, post #17111202]
Will Windows 10 change my drivers or settings during updates?
Some users saw driver changes and setting resets after updates. One wrote, "Win10 likes to lose the settings and change the drivers." Consider checking drivers after major updates and keeping backups. This behavior can disrupt audio, networking, or peripherals temporarily. [Elektroda, iagre, post #17112219]
Is it safe to leave Windows 10 automatic updates enabled?
Experiences vary. One long‑time user ran Windows 10 from the beginning with automatic updates on. They reported no problems. If your hardware is stable, this can work well. Always allow scheduled restarts to complete updates cleanly. [Elektroda, bodek60, post #17112552]
Can I disable Windows 10 updates to avoid surprises?
Some users block updates to avoid unexpected changes. One said they successfully turned updates off and preferred that setup. This reduces the risk of driver swaps after feature builds. Plan manual update windows if you choose this route. [Elektroda, malik123, post #17112433]
Could a Windows 10 build update break the system?
Yes, though it is rare. One report described a build update that pulled a number and failed. The user wrote, "The system could not be repaired and did not get up." Keep current backups before major upgrades to avoid data loss. [Elektroda, Anonymous, post #17112828]
Does Windows 10 really run more services and give less control than Windows 7?
A user compared both and found Windows 10 runs many more services. They noted some cannot be disabled, even by an administrator. This reduces fine‑grained control compared with Windows 7. Factor this in if you tune services for performance. [Elektroda, dnetsky, post #17495498]
Which OS uses more disk space after a clean install?
One comparison observed Windows 10 using less disk space than Windows 7 after clean installs. Storage footprints vary by edition and updates. However, this report saw Windows 10 smaller out of the box. Leave headroom for future updates and restore points. [Elektroda, dnetsky, post #17495498]
Is Windows 7 still supported?
No. Microsoft ended Windows 7 support on January 14, 2020. Running it exposes you to unpatched vulnerabilities and driver stagnation. Upgrade paths to newer Windows editions are recommended. [Windows 7 end of support]
Until when will Windows 10 get security updates?
Windows 10 reaches end of support on October 14, 2025 for Home and Pro. Plan your migration timeline accordingly to maintain security updates. [Windows 10 end of support]
How do I check my Intel CPU generation to decide on Windows 7 compatibility?
Use CPU generation as your first filter. If it is 6th‑gen or newer, avoid Windows 7. If it is older, installation is more feasible.
  1. Check your CPU model string.
  2. Identify the generation number.
  3. If 6 or higher, choose Windows 10. [Elektroda, Matuzalem, post #17111202]
Will older tools like Victoria or Comodo Firewall 2011 run on Windows 10?
One upgrader confirmed both Victoria and a 2011 Comodo Firewall worked on Windows 10. They migrated from Windows 7 and saw no conflicts. This suggests strong backward compatibility for common utilities. Always test mission‑critical tools before committing. [Elektroda, malik123, post #17111203]
