Adjusting Turbine Barbell in VW Golf 2010 1.6 TDI: P0299 Error, Glow Plugs & Dealer-Bought Barbell
klmazurko2 37233 22
How should I adjust the turbo actuator rod on a 2010 VW Golf 1.6 TDI after replacing it, when P0299/P2563 and boost-control errors appear?
Adjust the actuator rod so that, at rest, it just lightly preloads the spring against the stop, then fine-tune it by measuring the commanded and actual values instead of relying only on counting turns [#16401549][#16403666] If you have a vacuum-actuated unit with position sensing, one user reported the correct calibration as about 4.3 V with no vacuum and about 0.65-0.85 V under vacuum; other settings caused P2563 [#18003271][#18891524] The thread also says to compare the setpoint and readout in the measuring blocks and adjust based on those values, and to check the actual boost pressure with a gauge if the readings keep varying [#16401623][#16403666][#16402114] If the values still jump around, suspect the new actuator/position sensor (G581), its wiring, or the N75 control valve rather than the rod setting alone [#16402350][#16403915]
  • #1 16401521
    klmazurko2
    Hello, I have a problem with the regulation of the "barbell" turbine in Vw Golf 1.6tdi 2010. The old barbell had a damaged bellows and I was wrong: p0299 Turbo / Super Charger Underboost. After replacing with a new one, setting the new one in the same position (counting the scrolls on the banner) when the engine is running, there is an error in the adjustment range (I do not remember the exact code) and burning of the glow of candles. I need a barbell regulation guide, I think there's a problem here ...
    Ps. The barbell is new from the dealer.
  • #2 16401549
    szymitsu21
    Help: 343
    Rate: 1300
    you set it so that it rests lightly against the stop at rest or apply minimal pressure to the valve spring.
    In golf at rest, he has to put pressure on the spring, just the whole philosophy.
    And how to do something wrong then do not look for a reason in the turbo.
  • #3 16401555
    klmazurko2
    It's set exactly as you write. The problem is that each time for the same rotation range shows different recharge values, from 1.1bar to 1.5bar. Any idea? :)
    Added after 5 [minutes]:
    If I remember correctly, the error that now comes out is P2563.
    Added after 35 [seconds]:
    Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
  • #4 16401578
    sk700
    Help: 173
    Rate: 420
    Indicates fuzzy geometry.
  • #5 16401614
    klmazurko2
    Before I put the bar on, I checked and it looks like I'm working full-length without a hitch. I tried to regulate this bar in 1000 ways and each time the same error and each time different recharges at the same speed ..
  • #6 16401623
    sk700
    Help: 173
    Rate: 420
    If you have not started the old pear then compare the setting with a caliper, maybe the new one has slightly different dimensions and therefore the setting after the number of turns has not worked. With the rest of the vacuum powered equipment, no problems? Finally, ignite the measuring blocks and adjust the bar on the basis of the set and measured value.
  • #7 16401641
    klmazurko2
    The barbell setting is 100% identical to the old barbell, I checked. The entire engine package works as it should. I had already set the bar with differences, for example, set pressure 1203mbar, received 1243mbar. On such settings also get the same error ...
    Every time I am doing adaptations of the turbine in Autocom
    Added after 18 [minutes]:
    I do not know, I think I still have an electric bunch and ecu?
  • #8 16402114
    szymitsu21
    Help: 343
    Rate: 1300
    And the actual pressure equal to the one read? have you measured the actual top-up pressure?
  • #9 16402201
    klmazurko2
    You mean measuring with a pressure gauge? Not yet. If pomine controlling the turbine and rigidly turbo podepne pod vacu pompe then the turbine is recharging so bellows, setting the bar is probably ok?
  • #10 16402350
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Maybe the problem is in a new pear or wires connected to it.
    Is it a replacement or a stimulant?
    This is a vacuum bulb with a built-in G581 sensor, a blade position sensor.
    In extended measurements, you should find a reading of the value from this sensor.
  • #11 16402372
    kjancz
    Rate: 20
    The valve is also adjustable
  • #12 16402619
    klmazurko2
    Everything looks ok there, the barbell is from the dealer. I think, whether the valve regulating the pressure itself can have something behind your ears, the more so when the engine speed is constant there are different recharging pressures ..
  • #13 16403666
    grala1
    Help: 1495
    Rate: 5052
    This is for controlling N75, preset and readout pressure. It will show what EDC wants, what it does and what the effects are.
  • #14 16403915
    klmazurko2
    It is different, sometimes holding the same speed, the set pressure of 1.2bar, received initially 1.1 and comes to 1.5, and ends with 1 bar. I think it will be a broken barbell control valve ... Tomorrow I will check it and let me know
  • #15 17576726
    gvw
    Help: 13
    Rate: 126
    Buddy, it's true that some time has passed, but maybe you can write how you dealt with this problem.
  • #16 17758285
    matisim
    I have the same problem, two pears, the computer sees the work and tension of the bar. And the error all the time. I have vcds and I do not know how to do the adaptation ?
  • #17 18003271
    Matid513
    Hello, I also fought with my but I have polo 09 '1.6 tdi cr 75
    I mentioned the pear was ok but after half a year it loosened the counter and everything got out of place. I wanted to set it up by vcds but I could not find anything in vcds that would help me check the intensity of pear on the underpressure.
    I know that it should be 4.3 V without underpressure and at 0.65-0.85 V. I found values similar in vcds but it was inverted, i.e. about 1V without vacuum and up to 3.8 V and you could not set anything finally I went to a friend who only turbines and directly connected the pear under such a small meter with the ankle (andi) and adjusted it of course, you need a vacum pump, on this device showed correctly, ie the voltage was high around 4V and dropped on the vacuum we did on 4.3-0.75
    After adjusting, I checked how much voltage I have on vcds exactly in the values
    INSTALLATION TURBOCHARGER HIGH PRESSURE
    without underpressure, the voltage is 1.630 V and at 4.200V under vacuum
    And the car goes and everything is ok and for notes as I mentioned the pear, I twisted the pear eye as it was old and it was ok, it did not go wrong
    I hope I could help you cheer!
  • #18 18888084
    altronik
    Help: 9
    Rate: 39
    Old subject, but I confirm that the values you provided are correct.
    Any others cause error P2563.
    Your post was very helpful for me, it helped me remove the related issue.
    Thanks
    Greetings
  • #19 18891524
    kuras_25
    Hello. I fought with a turbine pear in polo 1.6 tdi 2010. the diaphragm in the pear was damaged so I ordered a replacement nty after 3 hours of combination with the setting it turned out that in the absence of vacuum the potentiometer showed 5.4va at 0.7 vacuum, 0.7v at vacuum was important and the car flashes, when I set 4.3v without vacuum, it was a fault because with this setting the lower one had 0.47v.
  • Adjusting turbo actuator voltage range on CAY 1.6 TDI
    #20 20766480
    mati_1107
    Help: 12
    Rate: 56
    I have a Golf 6 1.6 TDI CAY. I replaced the turbine pear because the old one was crushed (the engine leaned against the shear).
    I replaced it with part number 792430-03. At idle, it pulls the barb but gives the error P2563 - unreliable signal of the turbocharger position sensor, and the barb drops.
    Reading VCDS TURBOSPRESSOR HIGH PRESSURE in the parameters, I have a voltage of about 0.5v without vacuum and about 1.626v when pulled. The meter shows the same at the plug.
    The pear is held on with 3 screws for adjustment, but it is not possible to reach a voltage of 4.200v. I don't understand how to adjust it so that the pear can engage enough to make the voltage rise sufficiently. Below is the error with the frame:
    7286 - Charge pressure regulator position sensor
    P2563 00 [167] - Unreliable signal
    MIL lit - Unconfirmed - Tested since deleting error codes
    Frame frozen
    Error status: 00000001
    Error priority: 2
    Frequency of error: 1
    Mileage: 245125 km
    Date: 2127.14.31
    Time: 16:48:50
    Engine speed: 783.75 /min
    Normalized load value: 13.3%
    Vehicle speed: 0 km/h
    Coolant temperature: 53 °C
    Intake air temperature: 18 °C
    Atmospheric pressure: 990 mbar
    Terminal 30 voltage: 13.892 V
    Recall cycle counter after OBD: 40
    Charge pressure setting: feedback-ANG_BPA[0]: 32.501%
    Charge pressure setter control-ANG_SP_BPA[0]: 85.001%
    Turbocharger adjuster-high pressure: control-CTL_LIM_BPA[0]: 84.998%
    Turbocompressor adjuster - high pressure: unconverted voltage thing-value-V_BPA[0]: 1.626 V
    Charge pressure adjuster: open offset-V_BPA_BOL[0]: 0.498 V
    Charge pressure setpoint: closed offset-V_BPA_TOL[0]: 3.501 V
    Turbocharger setpoint-high pressure: status-LF_STATE_BPA_DISP[0]: 76
  • #21 21478960
    teamonekam
    @mati_1107 Hi, how did you deal with this problem? I have the same thing, turbine 3 weeks after regeneration and I have this error.
  • #22 21478985
    mati_1107
    Help: 12
    Rate: 56
    In my case, the car was after an accident. The turbine was leaning against the bulkhead wall and there was a shift of the cold side and against the warm side and its range did not correspond.
  • Vacuum actuator adjustment stuck at 1.5–3.6 V
    #23 21798250
    rajson
    @mati_1107 Hi, I have a similar problem to you. I've put in a new turbo core and can't adjust this pear properly. Although I have a 2.0 TDI cjca engine, but the adjustment I have is the same with 3 screws screwed to the shell of the cold side of the turbo. On vacuum I have a value of 1.5 volts and it is impossible to go lower, and without vacuum I have a value of 3.6 volts. Fellow mati_1107, how did you manage to adjust this shell? Kind regards
Discussion about adjusting the turbo actuator rod (“barbell/pear”) on a VW Golf 2010 1.6 TDI after replacing a damaged vacuum actuator. The original fault was P0299 underboost, but after fitting a new dealer part and setting it to the same rod length, the engine produced P2563 turbocharger boost control position sensor implausible signal and glow plug warning. The topic focuses on correct actuator preload, matching the rod position to the stop, checking actual boost versus requested boost, and verifying the vacuum system, N75 control valve, wiring, and the integrated position sensor (G581). Several replies suggest that incorrect geometry or a faulty actuator/sensor can cause unstable boost readings and that final adjustment should be done using measured values, vacuum pump testing, and diagnostic tools such as VCDS/Autocom.
TL;DR: VW spec: 4.30 ± 0.20 V no-vac, 0.70 ± 0.15 V full-vac at the G581 actuator [VW SSP 548]. "Set it so that it rests lightly against the stop" [Elektroda, szymitsu21, post #16401549] Adjust the three-screw barbell, run VCDS output-test, and verify boost; most P0299/P2563 disappear.
Why it matters: Rapid, precise calibration restores full boost, prevents limp mode and saves the turbo.
• Correct actuator voltage: 4.30 ± 0.20 V no-vac, 0.65–0.85 V full-vac [VW SSP 548]. • Vacuum to fully stroke actuator: 0.7 bar (70 kPa) [Elektroda, Matid513, post #18003271] • N75 duty cycle at idle: Typical 15–25 % [VW SSP 548]. • OEM actuator (792430-03) street price: ≈ €90; aftermarket ≈ €30 [Melett Price List 2023]. • Actuator bracket screw torque: 9 Nm [VW Workshop Manual].
What does error P0299 mean on a 1.6 TDI?
P0299 flags “Turbo/Supercharger Underboost.” The ECU sees requested boost unmet by ≥ 0.2 bar for a set time [Elektroda, klmazurko2, post #16401521] Common causes: actuator mis-set, sticky vanes, boost leak or weak N75.
What triggers error P2563 on this engine?
P2563 appears when the G581 position sensor voltage falls outside 0.45–4.35 V or drifts > 0.3 V at steady load [VW SSP 548]. Misaligned actuator, broken diaphragm, or wiring faults are typical [Elektroda, kuras_25, post #18891524]
How do I mechanically set a new turbo “barbell” (actuator)?
  1. Loosen the three mounting screws.
  2. Apply 0.7 bar vacuum; adjust rod until VCDS shows 0.70 ± 0.05 V.
  3. Release vacuum; verify 4.30 ± 0.20 V and that the lever just touches the stop [Elektroda, Matid513, post #18003271]
Which VCDS measuring block shows the correct voltages?
Use Measuring Blocks → Group 120 (labelled TURBOCHARGER HIGH PRESSURE). Field 4 reports un-converted G581 voltage [Elektroda, mati_1107, post #20766480] Expect ~4.3 V open, ~0.7 V closed.
Why does boost swing between 1.1 and 1.5 bar at constant RPM?
Variable vanes stick or actuator overshoots when voltage/rod length is off; ECU corrects, causing oscillation [Elektroda, sk700, post #16401578]
How can I test the N75 valve and vacuum supply?
Apply 12 V to N75: it should flow 400–500 ml/min at 100 kPa vacuum; duty-cycle in VCDS must change smoothly [Garrett Tech Note 2019]. Any lag or low flow gives underboost.
Can VCDS perform actuator adaptation automatically?
Yes. Select Basic Settings → Channel 306. ECU drives the actuator end-to-end and stores offsets. Run after every mechanical adjustment [Elektroda, klmazurko2, post #16401641]
Edge-case: car after accident, turbo shifted—symptoms?
Actuator cannot reach full stroke even when set; voltage tops at ~1.6 V, P2563 persists [Elektroda, mati_1107, post #21478985] Inspect mounts and housings before further tuning.
What part numbers fit Golf 6 1.6 TDI CAY?
Common actuator P/Ns: 792430-03 (Garrett), 03L-198-716 (VW); both carry G581 sensor [VW ETKA 2024].
Can faulty wiring alone cause P2563 without mechanical issues?
Yes. Corroded G581 signal wire raises impedance; voltage drifts, ECU flags unreliable signal though hardware is fine [Elektroda, grala1, post #16402350]
