VW Passat B7 2.0 TDI CFGC: Turbine Adjuster Error After Engine Replacement - Possible Reasons?
Szylo 44184 11
Why does the turbo actuator on a VW Passat B7 2.0 TDI CFGC show reversed voltage readings and trigger a blocked actuator error after an engine swap?
The actuator likely is the wrong type for this turbo, not a vacuum or adaptation problem. Normal readings are about 3.3–3.9 V with no vacuum/ignition on, and about 0.76 V at idle with vacuum applied, so the values the thread starter measured are actually within the expected range for one actuator variant [#16637052][#16637572] However, one reply points out that after replacement you should also do the VCDS adaptation in engine measuring block/channel 120 and adaptation channel 151 to select the turbocharger [#16637572] The key clue came later: there are two visually similar actuator versions with the same number, but they work in opposite directions, one about 4.47→0.22 V and the other about 0.24→4.75 V, and the cheaper one was likely the wrong version for this engine [#16637623] In other words, the actuator/pearl itself is probably incompatible with the turbo, so the fix is to fit the correct actuator variant (or the correct turbo/actuator assembly) rather than trying to reverse the wiring or force the values [#16637603][#16637627]
  • #1 16636921
    Szylo
    Rate: 19
    After firing the engine, I passed a few meters and the spiral ignited and dislodged the error of the type of turbine adjuster (blocked). I will add that the engine was replaced and during transport the dome was removed from the Turbo positioner, which was purchased new.
    CFG (C) engine 177km CR 2.0 tdi
    Measurement on the positioner terminals:
    Voltage on terminals 1 and 3 5v
    Voltage at terminal 2:
    Barbell extended / lowered 0.87v
    Barbell max zassana / drawn 3.75v
    It is so I start the car after a while, takes the barbell and holds in this position is then 3.75v. Suddenly the engine starts to work unevenly shows up the fluttering spiral and barbell falls to the bottom, the voltage on terminal pin2 drops to 0.87v? What could be the reason ? I will add that this happens after 10 seconds after starting the car, How to disconnect the vacuum pipe from the turbine pellets the car can walk for a minute does not show any error, N75 valve still sucks in the air as if to keep the pear in the upper position, just connect the vacuum hose to the pear he starts to pull the barbell and after 10 seconds he blows up the turbine controller error blocked. I will just add that the barbell rises and lowers At the extreme points That is, nothing is mechanically blocked
    Such as the V controller was supposed to work the other way round, so my only assumption is that as there is a voltage of 0.8 volts at idle speed, none shows A And sucks the bulb will show the voltage of 3.8 v after 10 seconds it crashes with the positioner is blocked
    The bar comes out 3.75v
    Barbell sucked 0.87v
    It is possible ? Because here is my uncertainty due to the fact that the engine was replaced and damaged during transportation. The upper dome of the pear was bought and now I do not know if there are two types of pears or one pear :(
    Short film of pear work, the syringe does not pull the pear to the end as I touch my finger or I start the car on the terminal shows up almost 3.8V
    https://youtu.be/vXAkjpXpReU
    Sent from my SM-G955F using Tapatalka
  • #2 16637052
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    At idle with connected negative pressure is to be 0.76 V (0.87 V will also be fine), ignition (without underpressure) approx. 3.6 V. Surely the actuator, it can be selected in the service although not all engines are separate.
  • #3 16637065
    Szylo
    Rate: 19
    Well now you cheered me because the pear was bought as a new and not too little money for this model of the engine only that I with connected negative pressure I have 3.8 va without 0.8v :( there is a possibility or doing something that will reverse the value, that is, where it is 3.8 to be 0.8 And where there is 0.8 to be 3.8, of course, to do something like that
  • #4 16637572
    marko888
    Help: 15
    Rate: 66
    The procedure for adapting the pear was made?
    After replacing the pear, check the VCDS in the engine, measuring blocks, channel 120, with the correct length of the bar. With the banner fully inserted - without vacuum (engine off, ignition on) in channel 120 should show 3.3- 3.9V, max. Ejection - creation of underpressure, eg when the engine is running at idle - 0.76V. That's what ELSA says. Adaptation is done in the BS 151 adaptation channel - you choose a turbocharger from the drop-down list.
  • #5 16637573
    Szylo
    Rate: 19
    I will say so that I did not adapt, but today I will certainly do the measurements I measured by connecting to the second PIN and with the ignition on, the engine turned off I have 0.8v. And when I start the engine it shows 3.8v
  • #6 16637575
    marko888
    Help: 15
    Rate: 66
    As for the setting itself, it is best to set the lever of the new one just like the old one, and if you set it wrong then you will make mistakes. Although the pear new as you write, you can test it, it's hard to see because in CR it is not visible from above but you can check it out in a homemade way by purchasing a large syringe of about PLN 2. and connect with a hose and a coo. If it allows air to exchange - complaints.
  • #7 16637577
    Szylo
    Rate: 19
    You do not set the pears because it has a constant tendon no adjustment of the model 794081-16, CDA tightness of the pear is OK I already checked with a syringe The only thing is only the values are reversed or I have with the engine turned off 0.8V and when turned on begins to suck pear 3.8 goes up to the top, And from what you read it should be the other way around
    • VW Passat B7 2.0 TDI CFGC: Turbine Adjuster Error After Engine Replacement - Possible Reasons? Screenshot_20170812-054314.png (1.42 MB) You must be logged in to download this attachment.
  • #8 16637603
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    The fact that the values are reversed is certainly not the fault of adaptation, it is only done to check the setting of the actuator. For me, however, this is not a pear. Bought at aso? As I wrote, not all engines are available.
  • #9 16637623
    Szylo
    Rate: 19
    Kupiona na allegro: / supposed to this engine but on another auction it is written that there are 2 types of pears with the same numbers; /
    FACTORY NEW ORIGINAL TURBINE ACTUATOR AUDI SEAT VOLKSWAGEN SKODA 2.0 TDI 170HP CR
    ATTENTION THERE WERE OTHER PRINCIPLES OF ACTION SO SAME LOOKING PEARS
    794081-16 FR14 FR15 WORKS ON 4.47 -> 0.22 -800ZŁ
    794081-16 FR14 FR15 WORKS WITH GROWING 0.24 -> 4.75 -400ZŁ
    Of course, I bought the cheaper one :(
  • #10 16637627
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    Well, you probably have the answer that should probably work descending
  • #11 16637635
    Szylo
    Rate: 19
    Well, that does not make sense. Buy the pear alone. For 800 zlotys I will buy the whole turbine with the pear at this price: / it also does not make sense. You have to look for the entire turbine and possibly only translate the pear itself
  • #12 18330639
    chimay723
    Rate: 8
    Hello, I have a similar problem with golf VI 2.0tdi cffb after replacing the pear after about 10s error 2563 returns, can you ask for help in setting the pear correctly, my meil chimay1(_at_)wp.pl, thanks in advance
The discussion revolves around a VW Passat B7 2.0 TDI CFGC experiencing a turbine adjuster error after an engine replacement. The user reports that after starting the engine, a "blocked" turbine adjuster error appears, with voltage readings on the positioner terminals indicating potential issues. Responses suggest checking the adaptation of the turbo actuator using VCDS, ensuring correct voltage readings during operation, and verifying the actuator's compatibility, as there are different types available for the same model. The user notes that the actuator was purchased from an online auction, raising concerns about its suitability. Suggestions include testing the actuator's functionality and considering a replacement if the values are reversed.
TL;DR: If your VW Passat B7 2.0 TDI CFGC shows turbo actuator error after 10 s, verify sensor targets (0.76 V idle; 3.3–3.9 V KOEO) and perform VCDS adaptation—“Adaptation is done in the BS 151 adaptation channel.” [Elektroda, marko888, post #16637572]
Why it matters: This FAQ helps DIYers diagnose reversed actuator readings, adaptation steps, and P2563 causes after engine or actuator replacement on CR 2.0 TDI.
What does code P2563 or “turbo actuator blocked” mean right after an engine swap?
The ECU sees the vane position outside the learned range. After about 10 seconds, it flags a blocked actuator if feedback is wrong or reversed, even when the rod moves freely. Check vacuum routing, sensor voltage, and actuator type compatibility. [Elektroda, Szylo, post #16636921]
What actuator voltages should I see on a healthy 2.0 TDI CFGC?
Expect about 0.76 V at idle with vacuum applied. With ignition on and no vacuum, expect around 3.6 V, within a 3.3–3.9 V window. Use VCDS Measuring Block 120 to confirm the KOEO range during checks. [Elektroda, jacek074, post #16637052]
How do I adapt a new turbo actuator with VCDS?
Use VCDS Basic Settings channel 151, and select the turbocharger. Quote: “Adaptation is done in the BS 151 adaptation channel.” Verify sensor voltage in Measuring Block 120: 3.3–3.9 V without vacuum and ~0.76 V with vacuum at idle. [Elektroda, marko888, post #16637572]
Why are my position sensor readings reversed (0.8 V KOEO, 3.8 V at idle)?
You likely fitted the opposite-sense actuator variant. Listings show identical housings but inverse output scaling (e.g., 4.47→0.22 vs 0.24→4.75 V). Using the wrong variant triggers P2563 despite correct movement. [Elektroda, Szylo, post #16637623]
Do I need to set the rod length on actuator 794081-16?
No. This model uses a fixed-length linkage (“constant tendon”). There is no mechanical length adjustment, so ensure the correct actuator variant and perform electronic adaptation to align readings. [Elektroda, Szylo, post #16637577]
How can I leak-test the vacuum actuator at home?
Use a large syringe and hose to apply vacuum. The rod should move smoothly and hold position without air exchange. If it bleeds down, return the actuator as defective. This quick test isolates vacuum leaks before deeper diagnostics. [Elektroda, marko888, post #16637575]
What pin voltages should I measure at the actuator connector?
Pins 1 and 3 supply 5 V. Pin 2 is the signal that varies with rod position, typically observed around 0.87–3.75 V between extremes. These checks confirm sensor supply and feedback integrity during diagnosis. [Elektroda, Szylo, post #16636921]
Will adaptation fix reversed sensor readings?
No. Adaptation verifies and stores actuator limits, but it does not flip an inverted sensor characteristic. If readings are reversed, replace the actuator with the correct variant, then adapt. [Elektroda, jacek074, post #16637603]
Where should the actuator read with ignition on, engine off (no vacuum)?
With the rod fully inserted and no vacuum, VCDS Measuring Block 120 should display 3.3–3.9 V. Apply vacuum at idle to see the reading drop to about 0.76 V. This confirms correct electrical sense and travel. [Elektroda, marko888, post #16637572]
What happens if I disconnect the vacuum hose to the actuator?
The engine may run longer without immediately triggering the fault because the rod stays in the no-vacuum position. Once vacuum is applied, incorrect feedback can cause the error within seconds. [Elektroda, Szylo, post #16636921]
Are all CR 2.0 TDI turbo actuators interchangeable across engines?
No. Some engines use actuators that are not available separately or differ in sensing direction. Fitting a look‑alike part can invert feedback and cause persistent P2563. Verify by part number and sensing type. [Elektroda, jacek074, post #16637603]
How much does the correct actuator variant cost, and why does price matter?
Listings show two variants: an inverse-sense unit around PLN 400 and a descending-sense unit around PLN 800. Choosing the cheaper, wrong-sense part often leads to immediate faults and rework costs. [Elektroda, Szylo, post #16637623]
Can wrong actuator sense cause faults even if the rod hits both stops?
Yes. The ECU evaluates voltage direction and range, not just mechanical travel. If voltage rises when it expects a drop, it logs a blocked/implausible position despite full movement. [Elektroda, Szylo, post #16637623]
How-to: Adapt the turbo actuator after replacement (3 steps)
  1. KOEO: Verify 3.3–3.9 V in Measuring Block 120 with no vacuum.
  2. Start engine: Confirm ~0.76 V at idle with vacuum applied.
  3. Run Basic Settings channel 151 and select the turbocharger to complete adaptation. [Elektroda, marko888, post #16637572]
I get P2563 ~10 seconds after start on a Golf VI CFFB too—related?
Yes. The pattern also appears on CFFB after actuator replacement when settings or variant are wrong. Recheck sensing direction, voltages, and perform adaptation to clear the code reliably. [Elektroda, chimay723, post #18330639]
