18650 Battery Capacity Meter: Optimal Discharge Current for Low and High-Current Batteries
Oximon 11334 7
  • #1 16405711
    Oximon
    Help: 79
    Rate: 27
    I have a 18650 battery capacity meter with adjustable discharge current, in the range of 0.3-5A. I would like to know what is the optimal discharge current for low-current batteries (e.g. from laptop batteries) and high-current ones (with short-circuit current> 30A). Differences in the results of some pieces at 0.5A and 1.5A are quite significant (up to 500mAh), hence my zagwozdka.
    Greetings,
    Mariusz
    Xantix
    Help: 686
    Rate: 1657
    Well, the most optimal would be a measurement with current consumption for a specific application. As you noticed, the same battery will have a "different" capacity in the flashlight and a different one in the mp4 player, etc. Therefore, for example, using a given battery for a 0.3 A pulling device is best to measure the capacity for just such a load, because in practice you are interested in the value you can realistically get in a given device, not a standardized test result.
    By the way, maybe there are some established recommendations for measuring the capacity of li-ion cells as it is the case in e.g. car batteries - but I have not heard of such recommendations.
    I would practically assume that for low-current applications the discharge current is within 0.3-0.5 C while for high-current something in the range of 2 C to 5 C.
  • #4 16405969
    Oximon
    Help: 79
    Rate: 27
    Great, thank you very much for your substantive answer! :)
    Pawel_1985
    Level 4  
    Help: 5
    Rate: 13
    Oximon - if you want to check the manufacturer whether it supplies the cell in accordance with the declared capacity, then do this test with a discharge of 0.2 C.
    Practically in every documentation that I reviewed concerning cells, at the capacity indicated, the discharge current was just 0.2 C.
    By discharging cells with high currents, you can get capacities much different from what the manufacturer declares, and this will not mean that the manufacturer is lying, because he is not lying, but only examined the capacity under certain conditions (discharge current, low ambient temperature, etc.)
    SPEAKERS_XP
    Help: 56
    Rate: 53
    0.2C discharge is commonly used to determine the capacity of Ni-MH batteries. For Li-ion, this is no longer an iron rule - you should rely on the cell manufacturer's specifications, there is always a specific discharge current for the declared capacity.
    Most Li-ion batteries of good quality without much difficulty will reach a value close to the nominal capacity at a discharge current of 1A - this is a good value to screen out any scraping from disassembly.
    500 mA is also not useless, but using such a load it is good to measure the resistance of such a cell.
  • #8 16435496
    Oximon
    Help: 79
    Rate: 27
    Thank you all for your help!
The discussion centers on determining the optimal discharge current for measuring the capacity of 18650 batteries, specifically for low-current applications (like laptop batteries) and high-current applications (with short-circuit currents exceeding 30A). It is noted that the discharge current should ideally match the application; for low-current devices, a discharge current of 0.3-0.5C is recommended, while for high-current devices, a range of 2C to 5C is suggested. The importance of manufacturer specifications is emphasized, as capacity ratings are often based on specific discharge conditions, typically around 0.2C for accurate capacity assessment. Users are advised to refer to datasheets for precise conditions under which capacities are declared, as higher discharge currents can lead to significant capacity losses due to internal resistance.
