Entering Channel 19 on Baofeng UV-5R: Step-by-Step Guide for Beginners + Antenna Info
Wojciech58210 108348 6
  • #1 16408170
    Wojciech58210
    Rate: 44
    I recently bought a Baofeng uv-5r radio. I do not know how to turn on channel 19, or if you can. I am a beginner so it's great if someone explained it to me. Mainly I mean the frequency at which the channel is 19. I do not know if I need a new antenna because I use the one that was in the set. I am asking for a quick response, D
  • #3 16408407
    Wojciech58210
    Rate: 44
    Thanks cristal2242, I already understand
  • #4 16408486
  • #5 16409034
    Wojciech58210
    Rate: 44
    Thanks, but I do not have a cb radio.
  • #6 16409129
    gumisie
    Help: 1667
    Rate: 2483
    It's how you want to "enter on k.19.
    cristal2242 wrote:
    You still have CB frequency tables.
    It is after frequency that it advises. This equipment does not support the CB band (Duobander BAOFENG UV-5R 2m / 70cm VHF & UHF). https://www.wasserman.eu/pl/p/Duobander-BAOFE...okowany/2534?gclid=CMfS7PThn9MCFUvcGQodpPsE6Q
  • #7 16409581
    Wojciech58210
    Rate: 44
    Yes, I know
✨ The discussion revolves around the Baofeng UV-5R radio and the user's inquiry about accessing channel 19, specifically the frequency associated with it. A response clarifies that the Baofeng UV-5R does not support the CB band, which includes channel 19 at 27.180 MHz. The user is informed that the UV-5R operates on VHF and UHF frequencies (2m and 70cm bands) and that they may not be able to use the existing antenna for CB frequencies. Additional resources, such as frequency tables for CB, are suggested for further exploration.
