Step-by-Step Guide to Replacing Old Uniphone with New PROEL PC512
arek0315 7179 1
  • #1 16408250
    arek0315
    Hello all. I'm new to the forum. I live in a block of flats and I would like to replace my old uniphone with a newer one. Could someone tell me how to connect it all? I am adding photos of the old uniphone. New I would like to mount this
    PROEL PC 512
    If possible, please explain step by step in understandable language what I should do and what to connect.
    Thanks in advance for any answer.
    PICTURES OF THE OLD DOORPHONE:
    Step-by-Step Guide to Replacing Old Uniphone with New PROEL PC512 Step-by-Step Guide to Replacing Old Uniphone with New PROEL PC512
  • #2 16408600
    robertamel
    Help: 115
    Rate: 56
    Old camera manual: http://proel.pl/main_libs/files/assets/1/Schematy_podlaczenia/sp_pc255.pdf
    Instructions for the new camera:
    http://www.proel.com.pl/nasze-produkty/aparaty/aparat-cyawod-pc512/
    According to the instructions, it is enough to set only the address of the device (in the old device it is set, as I can see, the address 32 + 8 + 2, i.e. 42) and correctly connect (keep the correct polarity) the two wires that are connected to the LU + and LU- connectors
