Connecting Cyfral Smart 5p Uniphone: Replacing Laskomex LM-8 Installation Guide
cyferglat 10902 7
  • #1 16554484
    cyferglat
    I am asking for help in connecting the new Cyfral Smart 5p uniphone instead of the Laskomex LM-8.
    Below Laskomex
    And here Cyfral
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Unfortunately, these are completely different systems. Old digital, two-wire. New analog, multi-wire.
  • #3 16560392
    cyferglat
    One more question.
    I purchased a Laskomex LY-8.
    Picture below. It seems to me that I connected the same and it does not work. Can I ask for advice? Photo from the first post is an intercom setup at the neighbors (apartment number 1). My apartment is No. 3.
    Is there a difference / dependency?
  • #4 16561019
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    After all, in this new uniphone you currently have (in the photo) set the apartment number 193. So it cannot work.
    After all, in this new uniphone you currently have (in the photo) set the apartment number 193 (128 + 64 + 1). So it can't work.
    Take off jumpers 128 and 64. Put one of them on position 2. Remember that the sum of jumpers gives the apartment number. So 1 + 2 = 3.
  • #5 16561178
    cyferglat
    Okay. Changed to 3 with no changes. I just don't know how to figure it out, since the neighbor who has apartment number 1 has 193 on jumpers.
    When the jumpers are set correctly, should everything work after calling the number in the intercom?
  • #6 16561412
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    Do you have line voltage?
    Try jumper: 1, 2, 64 and 128.
    best regards
  • #7 16561462
  • #8 16561509
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    The photo shows that the neighbor's jumper 64 is probably not on two pins (or it just seems to me).
The discussion revolves around connecting a Cyfral Smart 5p uniphone to replace a Laskomex LM-8 intercom system. Users highlight that the two systems operate on different technologies: the Laskomex is a digital, two-wire system, while the Cyfral is an analog, multi-wire system. The original poster encounters issues with the new installation, particularly with jumper settings for apartment numbers. It is suggested that the jumpers must be configured correctly to match the apartment number, and that the line voltage should be checked. Additionally, it is noted that the apartment number does not necessarily have to correspond with the uniphone number, as there can be limitations in jumper combinations.
