Connecting Cyfral Smart 5P Uniphone: Step-by-Step Guide for Replacing Old UNIFON TCL Intercom
karoll430 5538 14
How do I connect a Cyfral Smart 5P uniphone to replace an old UNIFON TCL intercom, and is it compatible with my installation?
The Cyfral Smart 5P is not suitable for this installation; you need a digital two-wire uniphone instead, such as the Cyfral Smart 2-wire version [#16346009][#16346017][#16346061] Connect only the two existing intercom wires to the uniphone’s + and - terminals; there is no separate microphone or speaker wire in this system because both wires handle calling, conversation, and door opening [#16346087][#16346357] If you are unsure which wire is + and which is -, check the markings on the old unit or use a meter, because the installer’s color choice is not standard [#16346795][#16347763] Reversing + and - should not damage the uniphone; it will simply not work until the wires are swapped [#16346795] In the end, the issue was solved by identifying the old unit’s markings: green was plus and blue was minus [#16355049]
  • #1 16345942
    karoll430
    As I am finishing the renovation, I decided to change the intercom. To be honest, I do not know anything about it, so I bought it in the store that my wife liked. And of course, I have no idea how to connect it.
    The intercom that I had earlier is connected to 6 cables (green, blue, red and three white) but only two are soldered ... (green and blue)
    The previous intercom was probably called the UNIFON TCL Connecting Cyfral Smart 5P Uniphone: Step-by-Step Guide for Replacing Old UNIFON TCL Intercom
    The connection looked like this:
    Connecting Cyfral Smart 5P Uniphone: Step-by-Step Guide for Replacing Old UNIFON TCL Intercom Connecting Cyfral Smart 5P Uniphone: Step-by-Step Guide for Replacing Old UNIFON TCL Intercom
    Everything works as it should. It rings, you hear it upstairs, it opens ...
    I bought a CYFRAL Smart 5P, and how to connect it? Is he even suitable for my "installation"?
    I do not have photos of the panel at the front door, but it is the most ordinary panel of the most ordinary, something of this type Connecting Cyfral Smart 5P Uniphone: Step-by-Step Guide for Replacing Old UNIFON TCL Intercom
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    Unfortunately, it is not suitable.
    Matching uniphones: http://tinyurl.com/j4f2yyd
    piotrek22101
    Help: 695
    Rate: 1421
    Hello, unfortunately this one will not fit, you need to look for a digital uniphone, two-wire connection.
    Ircys
    Help: 1342
    Rate: 2085
    The one from the auction is OK
  • #6 16346068
    karoll430
    that's perfect :) thank you for the quick replies. Uniphone ordered. And so for the future when it comes. I'll connect the blue and green cables. Which entrance? ie which is responsible for the microphone and which for the voice?
    Ircys
    Help: 1342
    Rate: 2085
    There is only "+" and "-" and nothing else needs to interest you - green and blue veins.
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    karoll430 wrote:
    ... who is responsible for the microphone and which for the voice?
    A single cable is not responsible for anything, only both of them are responsible for everything, i.e. for calling (bell), for conducting a conversation and finally for opening the door.
  • #9 16346790
    karoll430
    and which of these cables is a plus and which is a minus? will something happen if I mistake them?
  • #10 16346795
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Only those who installed the intercom system know about it. However, it is best to check with a meter where the plus and minus are. The installer should choose the "warm" color as the plus and the "cold" color as the minus. For you, he should choose orange as a plus and blue as a minus. However, he did not. Good thing he didn't pick two whites. If you mix up the cables, nothing bad should happen. The uniphone will simply not work.
  • #11 16346820
    piotrek22101
    Help: 695
    Rate: 1421
    Connecting Cyfral Smart 5P Uniphone: Step-by-Step Guide for Replacing Old UNIFON TCL Intercom Maybe it will help.
  • #12 16347076
    karoll430
    That's cool. I was only worried if it would burn it if I mistake + with -. But if not then no problem :) when he comes it will all be cleared up.
  • #13 16347430
    karl102
    Help: 106
    Rate: 265
    In the attached photos of the old one you have + and - clearly marked.
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    From what you can see, the plus is on the blue cable. Very unusual, but well, that's what the installer decided.
  • #15 16355049
    karoll430
    Problem solved. As I looked at the old intercom ... Under the rust, there was a sign .. The green was plus, the blue was minus. The intercom plays and beeps, I emphasized the potentiometer on the voice and there is a guitar. Thanks for advice. I always recorded a bit of knowledge :) greetings
The discussion revolves around replacing an old UNIFON TCL intercom with a CYFRAL Smart 5P model. The user initially inquired about compatibility and connection methods, revealing that the old intercom was connected using six cables, with only two (green and blue) soldered. Responses indicated that the CYFRAL Smart 5P is not suitable for the existing installation, which requires a digital uniphone with a two-wire connection. The user later found a compatible model and confirmed that the green cable is the positive (+) and the blue cable is the negative (-). The installation process was clarified, emphasizing that both cables are essential for the intercom's functionality, including ringing, conversation, and door opening. The user successfully connected the new intercom after identifying the correct wiring.
