VAG COMMANDER 3.6 Installation on Windows 10: 16-bit to 64-bit System Conflict Solution
maggiej 17223 2
  • #1 16409610
    maggiej
    Rate: 42
    I have to install VAG COMMANDER 3.6 on Windows 10, but unfortunately there is a conflict because the application is 16-bit and the system is 64.
    How to avoid this problem? I have no idea.
    Regards.
  • #2 16409621
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    The system works on DOS that has 16-bit? Is 32 bit on which older and current systems work?
  • #3 16410672
    tzok
    Help: 3177
    Rate: 6559
    You can install a 32 bit system on a virtual machine and VAG COMMANDER on it. Nevertheless, VAG K + CAN 3.6 is a 32 bit program and runs easily on Win 10 x64 ... the problem can be at most with the installer and / or driver.
