Challenges in Installing Debian GNU/Linux 8 Jessie on MSI GL62 with NVIDIA GeForce GTX950M
5316 14
How can I get Debian Jessie working on an MSI GL62 with hybrid Intel HD Graphics 530 and NVIDIA GTX 950M, since installing Bumblebee or the NVIDIA driver crashes X?
Yes—use Bumblebee with the NVIDIA driver from backports/testing instead of trying to hand-edit `xorg.conf`, and the working setup reported here was Debian testing with `bumblebee-nvidia`, `primus`, and `primus-libs:i386` [#16410589][#16442792] Start by adding i386 support with `dpkg --add-architecture i386`, then run `apt-get update` and install `bumblebee-nvidia primus primus-libs:i386` [#16442792] The thread also notes that `bumblebee-nvidia` is available from `jessie-backports` with `apt-get install -t jessie-backports bumblebee-nvidia primus` [#16410589] The user’s final working path was reinstall Debian, upgrade to testing, boot recovery mode without ACPI, install the packages, reboot, and choose Gnome on Wayland as the display manager [#16442792] The setup was then verified with `glxinfo | grep OpenGL` and `optirun glxinfo | grep OpenGL` [#16442792]
  • #1 16410481
  • #2 16410589
    dedito
    Help: 527
    Rate: 595
    Handling your card on a proprietary driver is in the backports.
    I don't know about open source, probably the same.
    Closed driver installation below.
    apt-get update && apt-get install -t jessie-backports bumblebee-nvidia primus
    The rest of the options at https://wiki.debian.org/Bumblebee
  • #3 16410820
  • #4 16410917
    dedito
    Help: 527
    Rate: 595
    hubotx wrote:
    It still doesn't work.
    Sorry, but the fairies aren't here.
    You have to show the logs: dmesg, xorg.log
  • #5 16410996
  • #6 16411006
    dedito
    Help: 527
    Rate: 595
    The system can boot in rescue mode.
  • #7 16411034
  • #8 16411056
    dedito
    Help: 527
    Rate: 595
    This is a buddy you have to answer this question yourself.
  • #9 16416321
  • #10 16416430
    dedito
    Help: 527
    Rate: 595
    Try on an open source driver:
    sudo apt-get install bumblebee primus
    In case of further problems, re-attach the logs.
  • #11 16416513
  • NVIDIA module missing; Wayland falls back to Intel graphics
    #12 16421109
  • #13 16421210
    dedito
    Help: 527
    Rate: 595
    The logs on the external server will expire soon and the thread will become useless, attach them to the message in syntax tags.
  • #14 16421771
  • #15 16442792
The discussion revolves around the challenges faced while installing Debian GNU/Linux 8 Jessie on an MSI GL62 laptop equipped with a hybrid graphics setup, featuring an NVIDIA GeForce GTX950M and Intel HD Graphics 530. The user encountered issues with driver installation, particularly with the proprietary NVIDIA drivers and Bumblebee for managing the hybrid graphics. Despite attempts to use backports and various desktop environments, the system failed to boot properly, resulting in a black screen or unresponsive graphical interface. Solutions proposed included using open-source drivers, booting in rescue mode, and ultimately upgrading to Debian Testing, which allowed for successful installation of the NVIDIA drivers and proper functionality with the Gnome on Wayland display manager.
