Struggles with Manual Installation of Intel HD Graphics 630 on MSI B250M PRO-VD with Win7 64bit
Świr 8478 7
  • #1 16736854
    Świr
    Help: 114
    Rate: 249
    I am tired of installing the drivers for the above graphics card. The motherboard software installer (MSI B250M PRO-VD) did not detect the VGA card at all, and when I try to install manually I get the message:
    "This operating system is not supported"
    I also tried to manually select and add a driver, but I did not find the model "630" on the list.
    I will add that windows is freshly installed, Pro version. I installed all the updates (I think), including SP1. The processor on board is I3-7100.
    Where is the problem?
  • #4 16736887
    Świr
    Help: 114
    Rate: 249
    Kasek21 wrote:
    After installing the graphics card in the PCI-E slot - the integrated chip in the CPU does not work.
    Intel HD 630 is, after all, an integrated graphics system. I don't have anything inserted into the PCI-E slot.
    Kasek21 wrote:
    Enter the device identifier as above, because it is not known what card you are talking about - integrated circuit or separate graphics card?
    Is there a separate graphics card on the PCIE called "Intel HD Graphics 630"?
    Hardware ID:
    PCI \ VEN_8086 & DEV_5912 & REV_04 & SUBSYS_7A741462
    There are still some updates - I download and install. I'll let you know how it went.
  • #7 16736982
    badboy84
    Help: 1198
    Rate: 1487
    The problem is that Kaby Lake doesn't like Windows 7 and vice versa.
  • #8 16737543
    Świr
    Help: 114
    Rate: 249
    Thanks Kolobos. It works!
The discussion revolves around the difficulties faced in manually installing drivers for the Intel HD Graphics 630 on an MSI B250M PRO-VD motherboard running Windows 7 64-bit. The user encountered an error stating "This operating system is not supported" during installation attempts. Responses included suggestions to check the device ID, install specific drivers from Intel and Dell, and unpack the driver files for manual installation via the device manager. It was noted that the Kaby Lake architecture (i3-7100 processor) has compatibility issues with Windows 7, which may contribute to the installation problems. Ultimately, the user confirmed success after following the provided guidance.
