Philips 55pus9109 - Unstable android, freezes, won't boot, resets
bodex20 7389 4
  • #1 16411353
    bodex20
    I have already given my tv to an authorized service center twice. Unfortunately, the same problem repeats every time. Android hangs and after booting it either reboots over and over again giving a black image or already glitching at the logo display. The only thing they do on the site is with the service tools they run it further and update the system again or they can replace the entire motherboard. Updating does not give anything, I learned myself to do minor faults through android recovery just like they did. Why can't they do more?
    - will not diagnose the motherboard
    - do not check log files
    - does not find corrupted files and replace with new ones
    - they cannot reinstall the stock android on the disc
    - they will not test it with antivirus and check the memory if it has been damaged,
    There are so many things they don't do, just updating or replacing it is normal practice on the site?
    Now I can not start it again, it can not even go into the android recovery system, the remote control codes also do not work, it resets over and over again. How can I get around this. How do I move on? The website is passive and does not get involved in fixing the underlying problem. After the update, it works stably for them, so they reject hardware faults after logging in on their own after connecting to the network crazy as above. Will you help in solving and providing the necessary tools?
  • #2 16411550
    lisek
    Service technician RTV
    Help: 6350
    Rate: 6880
    Try the method described Link
    * USB flash (FAT32)
    Or in English. Link
    ps
    Most of the problem in "bad soldering_ low quality" BGA processor or DRAM memory (since Philips switched to Chinese factories)
    So replacing the disc or rebal ...
    ps
    is a model on the Philips chassis QV14.1E LA (EN 3122 785 19573) / * EN 3122 785 19574
    55PUS9109 / 12
    55PUS9109 / 60
    Main (EN 3122 785 19574) on Link_ price EUR 145 (not including delivery price)
  • #3 16411630
    mirex
    Help: 1950
    Rate: 1990
    Do. On a different level. The service for you should be fast and effective. You have a guarantee and from your point of view it doesn't matter if they replace the disc with another one. It's not your problem.
    You are to receive a working TV. And that six months or a year would work again? It's hard. He's not the only one, and it's not our fault that you've let yourself into modern Filipki girls. ;)
    Why not invite the service home? Or maybe you really need to fine-tune the configuration matters in your network?
  • #4 16411966
    bodex20
    And this story is not guaranteed. It fell apart practically even after two years, as soon as the warranty expired. He ran fairly well for the first two years. It had flaws in the updates, but each new one was better.
    The method given by "Lisek" has been used by me so far, on average every 3-4 days since the TV came back from repair for the first time. Their update did not change anything, so I made it myself as soon as something was out of control. Currently it is not responding to this pattern of conduct.
    I did everything according to the same instructions from the same link.
    When it comes to buying another album on my own, it also crossed my mind, but what if the album is after repairs, some refresh or something else. On the net, everyone will describe that the new one and the Chinese cried when he sold. The website claims that when they exchange it, no one will complain for a minimum of 3 years. It's not much in my opinion, but I will be able to sell it further.
  • #5 16498957
    bodex20
    Tv returned from the site once again. I found out from the guys that ... he's fine. For over 2 weeks they used it normally: they watched TV, installed apps, played with YouTube, Skype and other functions, it never crashed all the time. They pointed out that maybe I have problems with the network at home since such faults occur.
    When I connected the tv at home, there is no preview of the application in the google play store. Crashes a connection error with the server. As if ports are being blocked. My supplier says that I have all unlocked and the router blocks them. I tried to share them, but I still have blocked connections to the server. Tv is on android 4.2.2. . Other phones also work at home on andku, but they do not have such problems. It seems that the topic is now slightly twisting and changing the department, but the common point of the problems so far is the fact that it was always connected to the network and the system used google services and created accounts.
    So now the question is how to permanently make TV available to the network so that the network traffic is smooth and the connection is permanent ??
