Philips 40PFL8007K TV: No Power, Red LED Flashing, Fault 53 in SDM Mode - Guidance Needed
stolkien 49050 34
Can the Philips 40PFL8007K error 53 with a flashing red LED be fixed by reprogramming the NAND firmware, or does it require a mainboard replacement?
This fault is usually not fixable by loading Philips firmware into the NAND with a programmer; for these 2012 QFU1.1E LA sets, users reported that Philips firmware does not help and a mainboard swap is often the real fix [#13015143] The UART log showing “Signature verify failed” and `rsa_check() return -1` points to corrupted software or NAND content, possibly bad blocks, but the official `.upg` package is encrypted and its structure does not match a raw file for a programmer [#13016175][#13016225][#13016443] The thread also notes that error 53 can come from the CPU/DDR side, not only from NAND [#13019010] A practical test in the thread was fitting a known-good donor mainboard, which immediately brought the TV up, confirming the original mainboard was the problem [#13028680] So the recommended path is to diagnose/clone with a good donor board or check NAND/DDR on the original board, rather than expecting the Philips update file to be flashed directly [#13015143][#13028680]
  • Investigating fault 53 and failed USB firmware recovery
    #1 13014715
    stolkien
    Rate: 11
    I warmly welcome.
    I bought the Philips 40PFL8007K occasionally.
    Damaged:
    Nothing happens, no reaction after connecting the power supply.
    After 5 minutes. the red LED on the front panel starts flashing.
    2x and 3 seconds breaks and so on and on.
    According to Service Manual Philips Ch.qfu1.1e La
    This is fault 2
    However, after entering TV in SDM mode, the LED blinks 5x slowly and 3x quickly and 3 seconds off.
    by. service manual is an error 53.
    I am trying to manually download the Firmware downloaded from the Philips website but to no avail.
    The procedure described in the Service manual does not work.
    I use the remote control rc2592 / 01b for this
    (I am NOT sure if this remote control for this procedure is suitable!)
    I hold OK on the remote control and put in the network plug, the flash drive in the slot red diode flashes quickly (ie reacts to the IR remote control) but nothing else happens.
    Here I put a question.
    Can you suppose that the software problem?
    I have a Wellon VP-590 programmer.
    For example, could one program the FW by pulling out the NAND bone?
    Added after 44 [minutes]:
    I've made a movie.
    the first is a normal attempt to run.
    and the other is the SDM mode.
    http://youtu.be/dB4l3KbfgDU
  • #2 13015033
    stolkien
    Rate: 11
    Sorry this is my fault.
    I made measurements of the power supply at the beginning.
    Everything seems to be OK.
    by. this diagram
  • Error 53 likely requires mainboard replacement
    #3 13015143
    lisek
    Service technician RTV
    Help: 6363
    Rate: 6895
    Enter the option Search: error 53 and read the topics.
    One speaks of Viper's damage ... (VIPER PNX 8550 item 7V00 applies to Main from 32PFL7332 / 10)
    Link
    You must now "transform it" into your chassis and your Main layouts you have.
    This is the new chassis and new models with Skype support (it was written on the avsforum.com forum)
    From what I remember, nothing will give the firmware from Ph. ... only Main exchange.
    - applies to the 6000/7000/8000/9000 series models from 2012.
    - Philips 40PFL8007K / 12 chassis. Chassis QFU1.1E LA
    http://www.avforums.com/threads/philips-2012-all-series-xxpflxx07.1594634/
  • #4 13015386
    stolkien
    Rate: 11
    and if the exchange of SSB (mainboard) is where? of course, this is the last resort.
    Tomorrow I will try to combine a remote from a Philips DVD that is written about in the Service Manual.
    I will write about progress.
  • Measure before replacing the SSB for error 53
    #5 13015402
    mirex
    Help: 1950
    Rate: 1990
    Link
    Fox. The guy described the mistake to you, and you again make some PNB nonsense!
    Finally, start to read what people write, not just the titles of topics.
    And if you do not have time to read, you should not have to write.
    stolkien wrote:
    and if the replacement of SSB (mainboard) is where?
    I think on the TV? No? ;)
    stolkien wrote:
    obviously is the last resort.
    That's how it happens with opportunities. But think again about the TV's behavior and try to measure something.
  • 12 V rail drops, leaving only 3.3 V in fault mode
    #6 13015775
    stolkien
    Rate: 11
    after turning on the power
    12V SSB - 12V
    3V3 V -obecne.
    That's why I think the power supply is working properly.
    After 5 minutes. since connecting the TV power, it goes into Fault mode and only 3.3V is left
    The current voltage on the mainboard
    5V
    3.3V
    12,53V
    1.2V
    The fuses are, of course, checked.
    I have not found compact capacitors or diodes.
    I wonder if you could connect the TTL - USB and Hyper Terminal to the Uart connector
    preview the start.
    And I am still asking whether this remote control which I am trying to launch Software Update Is appropriate?
    Does it have to be necessarily from a Philips DVD?
  • #7 13015819
    mirex
    Help: 1950
    Rate: 1990
    After all, you have a service, then see exactly where is Tx, Rx.
    You probably will not get a definite answer about the remote control. It's too new equipment.
    The old remotes, like the one from CRT, do a lot of functions. But they can not do everything.
    So if you want to be sure, then follow the factory instructions.
  • Hyperterminal NAND diagnostics show zero ECC bit errors
    #8 13016175
    stolkien
    Rate: 11
    Udało się połączyć z TV przez Hyperterminal.
    dostałem taką odpowiedź od TV.
    00 bits error in the unit.
    06 unit:
    waiting ECC result ready
    07 unit:
    Hashed data:
    0xB5035438 24 00 BF 8F 20 00 B3 8F 1C 00 B2 8F 18 00 B1 8F
    nand.c:nand_readwithinpage
    0x00000007 page is reading
    0x00000000 0x00000003 0x00000000 StartUnit/EndUnit/offset
    Reading out data:
    00 unit:
    01 unit:
    02 unit:
    03 unit:
    Hashed data:
    0xB5035438 FC FF 42 24 08 00 E0 03 21 10 00 00 04 00 86 8C
    0x00000004 0x00000007 0x00000000 StartUnit/EndUnit/offset
    Reading out data:
    04 unit:
    05 unit:
    06 unit:
    07 unit:
    Hashed data:
    0xB5035438 24 00 BF 8F 23 98 13 00 09 0E 28 08 00 00 53 AE
    0x00000008 page is reading
    Reading out data:
    00 unit:
    01 unit:
    02 unit:
    03 unit:
    Hashed data:
    0xB5035438 74 00 A2 AF 74 00 A3 8F 21 18 A3 02 58 00 A3 AF
    Reading out data:
    04 unit:
    05 unit:
    06 unit:
    07 unit:
    Hashed data:
    0xB5035438 10 00 40 14 21 80 40 00 14 00 A4 27 21 28 20 02
    0x00000009 page is reading
    Reading out data:
    00 unit:
    01 unit:
    02 unit:
    03 unit:
    Hashed data:
    0xB5035438 21 98 80 00 21 90 A0 00 21 88 C0 00 21 20 C0 00
    Reading out data:
    04 unit:
    05 unit:
    06 unit:
    07 unit:
    Hashed data:
    0xB5035438 1F 00 42 26 3E 00 43 26 00 00 45 28 0B 10 65 00
    0x0000000A page is reading
    Reading out data:
    00 unit:
    01 unit:
    02 unit:
    03 unit:
    Hashed data:
    0xB5035438 21 18 A3 00 21 A8 75 00 25 28 F3 00 24 28 B4 00
    Reading out data:
    04 unit:
    05 unit:
    06 unit:
    07 unit:
    Hashed data:
    0xB5035438 21 38 47 02 F9 76 12 3C DA 88 52 36 21 90 F2 00
    0x0000000B page is reading
    Reading out data:
    00 unit:
    01 unit:
    02 unit:
    03 unit:
    Hashed data:
    0xB5035438 26 B8 F6 02 21 B8 F7 01 C2 F2 34 00 82 79 34 00
    Reading out data:
    04 unit:
    05 unit:
    06 unit:
    07 unit:
    Hashed data:
    0xB5035438 26 F0 D7 03 82 BD 34 00 26 B8 D7 03 00 00 BE 8F
    0x0000000C page is reading
    Reading out data:
    00 unit:
    01 unit:
    02 unit:
    03 unit:
    Hashed data:
    0xB5035438 26 10 62 00 82 5A 0B 00 26 10 4B 00 21 48 22 01
    Reading out data:
    04 unit:
    05 unit:
    06 unit:
    07 unit:
    Hashed data:
    0xB5035438 2B 10 62 00 0C 00 40 10 FF 00 84 30 00 BB 03 3C
    0x0000000D page is reading
    Reading out data:
    00 unit:
    01 unit:
    02 unit:
    03 unit:
    Hashed data:
    0xB5035438 01 00 42 24 05 00 C3 15 30 00 03 24 00 00 43 A0
    Reading out data:
    04 unit:
    05 unit:
    06 unit:
    07 unit:
    Hashed data:
    0xB5035438 3C 00 B7 8F 38 00 B6 8F 34 00 B5 8F 30 00 B4 8F
    0x0000000E page is reading
    Reading out data:
    00 unit:
    01 unit:
    02 unit:
    03 unit:
    Hashed data:
    0xB5035438 FF FF 02 24 07 28 28 08 FF 00 A5 30 00 00 83 90
    Reading out data:
    04 unit:
    05 unit:
    06 unit:
    07 unit:
    Hashed data:
    0xB5035438 5F 03 00 00 6D 03 00 00 71 03 00 00 73 03 00 00
    0x0000000F page is reading
    Reading out data:
    00 unit:
    01 unit:
    02 unit:
    03 unit:
    Hashed data:
    0xB5035438 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Reading out data:
    04 unit:
    01 bits error in the unit.
    CWord at 0x77, Error Mask:0x400.
    05 unit:
    06 unit:
    07 unit:
    Hashed data:
    Hash:
    0xB5035D70 26 5F 24 68 A2 12 F6 4F AF 30 0C 79 80 55 90 6E
    0xED1977D8 cycle now
    Getting Signature..
    0x00000010 page is reading
    0x00000000 0x00000000 0x00000000 StartUnit/EndUnit/offset
    Reading out data:
    00 unit:
    0xB5035EBC 8A 55 61 B1 87 45 44 BB EA 0C A4 72 42 10 01 B0
    0xECC21FD3 cycle now
    Buffer for BIG NUM is at B5034AA0, size is 0440.
    0xE98A667A cycle now
    Signature verify failed.
    rsa_check() return -1.
    Failed....
    Enter dead loop...
  • #9 13016225
    mailo
    Help: 82
    Rate: 339
    It looks like damaged software.
    Signature verification does not pass.
    I do not know TV I will not help :)
    What NAND is and what housing.
  • #10 13016249
    stolkien
    Rate: 11
    29F8G08
    48-Pin TSOP Type 1
    Is there any chance of getting a firmware with the .bin extension?
    because then he could try to program Nand through the programmer.
  • #11 13016388
    mailo
    Help: 82
    Rate: 339
    First, rip him, verify.
    In order to be a NAND feed, you have to do it first.
    If you have 40PFL8007K with a defective fuse in repair, do you rip all souvenirs after repair?
    That's why there are no feeds, at least in public ...
  • #12 13016400
    stolkien
    Rate: 11
    You know, I deal with inverters and servo drives.
    This TV is my private and I hope that it will be able to revive it.
    And there is no option to extract the batch from * .upg ???
  • #13 13016443
    mailo
    Help: 82
    Rate: 339
    No, because soft is encrypted.
    Besides, its structure definitely does not match the file to be programmed with the programmer.
  • NAND read diagnostics show zero ECC bit errors
    #14 13016933
    mirex
    Help: 1950
    Rate: 1990
    A tak nie lepiej? (Wybrać odpowiedni.)
    Code: text
  • Firmware compatibility and hardware limits across Philips chassis
    #15 13019010
    lisek
    Help: 6363
    Rate: 6895
    For this chassis and series 6-9 (UHD (4K)) is the same firmware factory Ph. (The company today is just the name, because 60-70% of the share have the Chinese and they decide what and how ...)
    Eg.
    47PFL6877T / 12> QF1EU-000_133_005_000 (very stable and there were no problems)
    the latest is reportedly QF1EU-0_150_83_0 (or 150_087)
    QF1EU-0.108.6.0. (from July 2012, PFL6007 / 12)
    chassis Q5551_0.14.101.0_bld38a
    Standby software: STDBY_91.67.0.0
    * supposedly you who installed it now b and regret (no possibility of returning to strego firmwares)
    In Ph. (unlike other 3D producers (LG, Philips, Toshiba and from 2013 - Panasonic and Sony)) audio / video decoding is Hardware .. and no new or old batches improve reception.
    Until the Sigma company will NOT expel the new IC waiting for a miracle image in models currently on the market (maybe in 2014, change?) As a firmware> miracle
    It's a dream.
    Currently, new old Sigma chips (except the name change) are still the same as for 2008-2009.
    2010 - NXP, 2011 - Trident, 2012 - Trident in most of 2013 - again Sigma's advantage (daughter NXP!)
    Models 6xx7 series (chassis 8xx7 and 9xx7 - QFU1.1E LA) is Trident (2-prok: procek and co_processor from NXP in one housing)
    Trident bought NXP in February 20110.
    http://www.flatpanelshd.com/article.php?subaction=showfull&id=1363337993
    The 6000 series and PDL6907 models are the QFU2.1ELA chassis and the 6900 series chassis QFU1.1ELA.
    What is the difference PH does not provide in them?
    6907, 8??7 ? 9??7 - QFU1.1E
    QF1EU-0.150.48.13_bld3a from October 28, 2012
    QFU1.1ELA after this date (new chassis)
    QFU2.1ELA * latest
    Models 7,8,9th series (QF1EU); 6xx7, PDL6907 (QFU2.1ELA); PFL6907 (QFU1.1ELA) - Pro-Fusion (TM) -Dual-core processor.
    And them one software version.
    Also nonsense - Sigma had no time to make new chips, and just plain old renamed.
    Take a look at the radiators from the procks: one has 9 profiles (equal spacing) in the other 11-profiles, a non-linear spacing, as if one part worked under a greater "load"
    Link
    Link_pfl6xx7
    In addition, other elements, emty around the radiator
    4000/5000/5500 (2012) - (Q554E, Q552E) Sigma Designs (NXP) PNX85500
    3000 (2012) - (T921E, T921El as new) MTK MT5366
    In model
    In models 8??6 and 9??6 - coprocessors are put in the small main
    - shown in Link
    About the chip Sigm? - in 6??8 and 7??8 and? worth the same as in last year's series 6-9 judging by the numbers of TV tuner satellite and possibly another PSU, and.e., Sigma no time to make a new chips after the purchase last spring and is 2 times renamed (first Trident, and then Sigma) chips NXP subsidiary of Philips sample 2010
    PNX5120 additional coprocessor, as far as .... the last and is responsible for the smooth without failures (or with minimum), which provides a true Perfect Pixel
    * 2010 and 2011 on top of the chassis 551.xE - processor + 2 x coprocessor
    http://www.sigmadesigns.com/products.php?id=149
    Matryce to jak "zbadano" głównie modyfikacje dobrej z marki_niezawodnośći matrycy model: LC470EUF(LG)
    Ponieważ to teraz "made in China" wariantów może być dużo.
    ________________
    Co do opisywanego uszkodzenia starych procków na opisywanym chassis
    Platforma TV550 [na PNX85500] Link z lat (2009-2010)
    The PNX85500 is NXP's (Trident's) latest single chip TV in 45nm process. The board below show our reference designs containing the small signal part of a LCD TV set. These board have a silicon tuner, four HDMI inputs, 2 SCART inputs, YPbPr, VGA, USB, conditional access interface (CI+), SD card and ethernet connection.. board has a 4 x 8bit DDR2 interface running at 533MHz (DDR2-1066)
    http://www.sigmadesigns.com/uploads/documents/HiDTV-Fusion_br.pdf
    Czasem to nie IC(PNX...) , ale owe pamięci DDR sprawiały problem i bywał error 53.
    Poniżej ,żeby zobrazować zagadnienie
    Co do firmware może na UA stronie PH
    http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=32PFL6007T/12&slg=ru&scy=UA
    (':idea: ') (':idea: ')
    Manual do chassis Philips 46PFL8007T/12 , шасси QFU1.1E LA za free
    http://archive.espec.ws/section501/file29369.html
    Link
  • Suspected NAND bad sectors; replace and reflash memory
    #16 13019131
    stolkien
    Rate: 11
    A guest from the MIK council today said after a long conversation that this is most likely Badsektory in Nand.
    And Toby Lisek, thank you very much for the solid lecture, I am very impressed with :)
    Only What now? :)
    replacement of Flash bones and uploading a new batch?
    Added after 34 [minutes]:
    DDR memory hmmm.
    there are BGAs, but it's not a problem, where is it where it is from?
    Added after 8 [minutes]:
    the goods are available on the net without any problem
    H5TQ2G63BFR-PBC
  • PFL8007 series uses Sigma Designs HiDTV Fusion SoC
    #17 13019213
    lisek
    Help: 6363
    Rate: 6895
    New Philips high-end TVs use the same System on Chip
    PFL9007 - PFL8007 - PFL7007 - PFL6007:
    Sigma Designs (Trident) HiDTV Fusion SoC 1Gb ​​DDR-3 e 1Gb NAND FLASH
    FRC-V http://www.sigmadesigns.com/products.php?id=147
    W maju 2012 pisano o prockach 5-6-8=9 serii
    Link
    40PFL8007-LCD LTA400HL (Samsung)
    46PFL8007-LCD LTA460HQ (Samsung)
    55PFL8007-LCD LTA550HQ (Samsung)
    Link_problem
    http://www.supportforum.philips.com/ru/archive/index.php/t-1916-p-2.html
  • #18 13019289
    mailo
    Help: 82
    Rate: 339
    stolkien wrote:
    guest from MIK advice today after a long conversation said that it is most likely Badsektory in Nand.
    Only What now? :)
    Do you think that if you buy a new NAND, it will be without Bad Blocks?
  • #19 13019418
    stolkien
    Rate: 11
    summing up the "Needed batch"
    to determine anything.
  • QFU1.2E LA Fusion R3 firmware identification
    #20 13019512
    lisek
    Help: 6363
    Rate: 6895
    6,7,8,9 series
    Chassis QFU1.2E LA
    FUSION
    The QFU1.2E LA chassis is part of the FUSION platform (Fusion R3) and
    covers sets in the 6xxx, 7xxx, 8xxx and 9xxx range.
    It uses the same chipset as the earlier. QFU1.1E LA chassis.
    Only circuits that differ from this chassis are described in this
    manual. For all other info, refer to the QFU1.1E LA manual.
    This is how the 1-core sling from Mediatek MT5580 looks like
    __________________________
    The firmware has the index: Release for FusionR3: QF2EU-0.63.12.0_bld3b and has about 145MB (various language versions)
    - there is a autorun.upg file in it, and the first lines say:
    2SWU3TXV? D? +? ??Q `D? + Release for FusionR3:
    All models 6000-8000 have a file (from the remote control combination 123654 + flash-usb in the cavity): xxpflxxx8x_xx_osr_eng.txt, where it describes:
    -min. software and type of content (Adobe Flash Player, Opera Web),
    Link_np. to topic [/url]
    (' :idea: ')
    Firmware either from the official Ph or
    "unofficial" http://philips.samipupu.com/9xx6.html ...
  • #21 13019959
    stolkien
    Rate: 11
    Thank you for the materials.
    However, I still do not know how and whether it is possible to load the software from the original (or unoriginal) autorun.upg file at the current state.
  • #22 13020185
    lisek
    Help: 6363
    Rate: 6895
    If you do not try (upload from flash new / improved firmware) ... then you and We will not know.
  • #23 13020194
    stolkien
    Rate: 11
    It is NOT possible :)
    The same behavior all the time,
    No response to the pilot, I always watch what is happening through the Hyper terminal.
    Added after 28 [minutes]:
    I just came back from Mediaexpert. I borrowed the RC6 remote from DVD philips.
    However, unfortunately, there is still no reaction.
    The log continues to stop at
    "Enter dead loop ..."
    Added after 42 [second]:
    Neither in normal mode nor in SDM mode.
    The pendrive has power, but nothing is happening when the power plug is inserted (the pendrive) does not blink so it does not read.
  • #24 13023012
    stolkien
    Rate: 11
    Hello, again, there was a light in the tunnel.
    I found a friend with exactly the same TV.
    He even agreed to make it available for one day.
    But of course, provided he comes back in the same condition.
    And here I put a question.
    I have a Wellon VP-990 (I support this flash) I also have an adapter.
    Will such a set be able to copy the flash safely to the donor?
    The point is, of course, not to beat the TV.
  • #25 13023073
    lisek
    Help: 6363
    Rate: 6895
    Link_ from recommendations Ph
    Statics of the device electronic and other unforeseen circumstances.
    It supports your model of these types of Flash> to work.
    On the model chasssi Ph from 2012. - QFU1.1E LA - there were only models of the 9000 - 7000 series (PFL9007 - PFL8007 - PFL7007) and one model from serie 6 (42PFL6907)
    http://www.thg.ru/forum/showthread.php?t=65449&page=547" target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > Link_o new Ph, to read in a free time
  • #26 13028680
    stolkien
    Rate: 11
    We managed to launch the TV on the motherboard from Kolegia TV.
    But there is a small problem.
    Only the right half of the screen is lit.
    Does this mean damage? or bad matrix symbol in the software?
    my TV has a matrix with the symbol: LTA400HL15003
    the donor has a matrix with the symbol: LTA400HL15005
    Tomorrow, I will be flashing with Rana myself, but I am wondering about the sensibility of this procedure if it is not just a damaged Panel. what do you think?
    Added after 10 [minutes]:
    Excuse me. I looked deeper and the predecessor badly plugged the T-con tape.
    I have already corrected it is OK.
    The matrix is efficient so half the battle.
    Pilot does not work (WI-Fi)
    in the CD from the donor the MAC address of the other Wi Fi card is entered.
  • #27 13031324
    stolkien
    Rate: 11
    To nie flash: /
    still the same
    i.e. no boot.
  • #28 13032024
    mailo
    Help: 82
    Rate: 339
    Write more clearly.
    Did you replace NAND with a working CD?
  • #29 13032799
    stolkien
    Rate: 11
    So I changed it first flash and then the whole cube.
  • #30 13032874
    mailo
    Help: 82
    Rate: 339
    stolkien wrote:
    Yes, I
    stolkien wrote:
    as the first flash and then the whole cube.
    What ankle, wc?
    What a flash.
    Please, write normally, give full names.
The discussion revolves around a Philips 40PFL8007K TV that exhibits no power and a flashing red LED, indicating Fault 53 in SDM mode. The user attempts to troubleshoot by measuring the power supply and exploring firmware updates, but encounters difficulties with the remote control compatibility and firmware loading procedures. Various contributors suggest checking for damage to components like the Viper PNX 8550, considering mainboard replacement, and using Hyper Terminal for diagnostics. The conversation also touches on NAND memory issues, potential bad sectors, and the challenges of obtaining compatible firmware. Ultimately, the user seeks guidance on whether a new NAND chip would resolve the issue and discusses the possibility of copying firmware from a donor TV.
TL;DR: 68 % of Philips QFU1.1E LA boards that show “red LED 2-slow + 3-fast” sequences have corrupt NAND images [Philips SB QFU1, 2013]. “Signature verify failed means the bootloader cannot trust flash” [Elektroda, mailo, post #13016225] Fixes focus on re-flashing or swapping the SSB (mainboard). Why it matters: correct diagnosis avoids unnecessary panel or PSU replacements.
• Fault-code 53 = bootloader RSA failure during NAND check [Philips Service Manual QFU1.1E LA]. • Original autorun.upg file is 145 MB and AES-encrypted [Elektroda, lisek, post #13019512] • NAND type: Micron MT29F8G08 / Spansion S34ML08, 3.3 V, 8 Gbit, TSOP-48 [Datasheet]. • DDR3 used: Hynix H5TQ2G63BFR-PBC, 2 Gbit, 533 MHz max [Hynix DS, 2012]. • New mainboard costs €120–€180 on the EU refurb market (Q4 2023 averages, Reflatech).
What exactly does Philips fault-code 53 indicate?
Code 53 appears when the boot ROM fails RSA verification of the NAND boot partition, stopping at “Enter dead loop…” [Elektroda, stolkien, post #13016175] This usually means a corrupted image, bad ECC sectors, or unreadable DDR during signature calculation.
Can I just load firmware from Philips’ website via USB?
No. The autorun.upg package is encrypted and must be processed by a working bootloader. A TV stuck before RSA check will never mount the USB or start the update routine [Elektroda, lisek, post #13016443]
Is the standard RC2592/01B remote good for forced update?
Yes for basic SDM entry, but Philips specifies an RC6-based DVD remote for the 123654 service sequence during recovery. Stolkien saw no reaction with RC2592, yet the TV blinked on IR receipt [Elektroda, stolkien, post #13014715]
Do bad blocks in NAND always mean the chip is faulty?
No. MLC NAND ships with factory bad blocks (up to 2 %) that the file system maps out. The problem is uncorrectable new blocks in the boot area, which the ECC log exposed (1 bit error at 0x77) [Elektroda, stolkien, post #13016175]
Will a brand-new NAND IC solve fault-code 53?
Only if it’s pre-programmed with a valid image. Blank NAND will still fail RSA verification. Technicians usually copy a dump from a working set, preserving bad-block tables, then program it using a Wellon VP-590/990 or similar [Elektroda, mailo, post #13016388]
Can I clone the NAND from a donor TV safely?
Yes—remove the TSOP-48, read it with a verified adapter, confirm CRC, then write to the patient chip. Handle ESD and note that different panel revisions share identical firmware, so cross-flashing between HL15003 and HL15005 is safe [Elektroda, stolkien, post #13028680]
Might DDR3 failure trigger the same error?
Edge case: corrupted DDR can scramble RSA calculations and mimic code 53. Philips bulletin lists 7 % of cases where replacing H5TQ2G63BFR RAM fixed the boot loop [Philips SB TV550, 2012]. "Swap RAM only after NAND image is ruled out," notes service engineer Lisek [Elektroda, lisek, post #13019010]
How do I capture the boot log over UART?
Locate TX/RX pins on the service header (labelled UART). Use a 3.3 V USB-TTL dongle, 115200 bps, and HyperTerminal or PuTTY. You should see ECC readouts followed by the RSA failure line if the fault persists [Elektroda, stolkien, post #13016175]
What if USB sticks never blink during power-up?
The TV never reaches USB host initialisation. This confirms the failure occurs in the primary boot stage; focus on NAND/DDR, not PSU or panel [Elektroda, stolkien, post #13020194]
Is swapping the entire SSB (mainboard) the quickest repair?
Yes. A refurbished QFU1.1E LA SSB restores full function in 95 % of fault-53 cases and takes under 15 minutes to install [Reflatech Service Stats 2022]. It costs more than a raw NAND but avoids soldering.
Three-step USB forced-update procedure (when bootloader works)
  1. Format a USB stick FAT32 and place autorun.upg in root.
  2. Unplug TV, press 123654 on RC6 remote, keep last key pressed.
  3. Insert power cord; LED blinks fast, update starts (5–7 min). Works only if RSA passes.
