Media-tech MT4058 Firmware Search: Device Stuck on Logo - Copying Software Between Devices
chodas 9885 4
  • #1 16411625
    chodas
    Hello to all forum users,
    At first, please move the post if it is in the wrong department.
    I am looking for firmware for the device mentioned in the topic. It is not on the manufacturer's website. The device hung during reboot and is still hanging on the "media-tech" logo. For unknown reasons I am also not able to enter the recovery menu in accordance with the manufacturer's instructions.
    I will add that I have the same device. Is there any possibility of "copying" the software from one device to another in the event that I cannot find the software.
    Thank you in advance for your help
  • #2 16412716
    Freddy
    Help: 1394
    Rate: 2822
    Have you tried it
    How to restore factory settings?
    Connect the car charger, press and hold the MENU button, press RESET, wait until the menu with options appears, release the MENU button. VOL + (down), MENU (up), set to WIPE DATA FACTORY RESET, the POWER button works as OK
  • #3 16412770
    chodas
    I tried this option, unfortunately it has no effect.
  • #4 16413242
    Freddy
    Help: 1394
    Rate: 2822
    If you still have a guarantee, only the service remains.
    Try to write to them because the firmware is not available anywhere.
    Yes, but you need a professional programmer - although maybe some dump and firmware will work.
  • #5 16414005
    chodas
    Unfortunately, I have no warranty anymore, I contacted the service regarding firmware, but they do not want to share it.
    I don't have a programmer, so I will probably have another brick at home: /
