Toshiba 40L7335D TV: Stuck on Logo, Unresponsive Remote & Keyboard after Batch Upload
grubas 23889 5
  • Seeking proven firmware dump for Toshiba 40L7335D recovery
    #1 16208801
    grubas
    Level 40  
    Help: 647
    Rate: 553
    The TV turns on but hangs on the Toshiba logo. I read similar posts and uploaded a batch that one forum mate shares in his post.
    After uploading this batch, the TV only hangs on the logo all the time. Previously, on the old batch, it only displayed the logo and disappeared, but the backlight remained.
    The TV does not respond to the remote control and keyboard.
    Maybe someone has a proven and ripped input for this TV?
  • #2 16211845
    Dido_I
    Rate: 13
    Hi! New readed from Toshiba 40L7335D. chassis 32L4300 rev1.2
    • W25Q16_20170117_171925.BIN (2 MB) You must be logged in to download this attachment.
    • 24_256_20170118_94520.BIN (32 KB) You must be logged in to download this attachment.
  • #3 16213838
    Andrzej4567
    Help: 26
    Rate: 252
    First, upload this Bin IC112 with a programmer. Then via USB soft 7.1.92.61.01.1. Soft should be on the Toshiba support net. This soft is on the list with Toshiba 40L7333DG.
    • Toshiba 40L7335d soft z netu, ale już wgrywany przeze mnie z pozytywnym skutkiem(po rozpakowaniu,jest on podpisany,że jest też do Tosh 50L7363C).rar (5.44 MB) You must be logged in to download this attachment.
  • #4 16322633
    tefe_negro
    Thank you. This is my dump from Toshiba 40L7335D motherboard sticker 40L7333DG IC112 25Q16.
    • 40L7335D IC112 W25Q16.rar (314.66 KB) You must be logged in to download this attachment.
  • #5 16327122
    KW
    Help: 20
    Rate: 56
    The case you described can be caused by software, but also by other damage. If you can't handle it, I offer to repair these mains.
  • #6 16333710
    grubas
    Level 40  
    Help: 647
    Rate: 553
    It's been a while, but I'm done with this topic.
    It wasn't the software's fault - I substituted the memory from a different board (different TV) and the symptom was the same (no LED lighting, hanging on the logo, the keyboard did not work), so it was a problem with the board. The customer picked up the TV unrepaired and bought a new one.
