Using USB Port Meter BTE-147 for Li-ion Capacity Measurement - Differences with USB 3.0?
E8600 6120 12
Can a USB power meter like the BTE-147 be used to measure the capacity of Li-ion cells and power banks, and what is the difference between the USB 2.0 and USB 3.0 versions?
It can be useful for comparing phones and power banks, but it does not measure the true capacity of a Li-ion cell; it measures the charge/current delivered during charging, so actual capacity requires a discharge test [#16412581] [#18123505] One user reported that the BTE-147/KWS-V20 works well and has a 0-20 V, 0-3 A range [#16412581] The USB 3.0 version was identified as “Rui Deng OLED USB 3.0” [#16412560] Another reply said the USB 2.0 model is cheaper and reportedly reaches up to 20 V, while the USB 3.0/OLED version only goes to about 13 V; the same post also mentioned KWS-20 vs KWS-21 as differing only in voltage range [#16413751]
  • #1 16412109
    E8600
    Help: 529
    Rate: 2520
    I wanted to ask users with such equipment if it is able to determine the similar capacity of a Li-ion cell because I would like to use it mainly to measure capacity because other measurements are going to be done with a multimeter. I noticed that such a USB meter is available in 2 versions, for USB 2.0 it is BTE-147, while for the USB 3.0 version I did not find the manufacturer's name. Below are illustrative photos.
    USB 2.0
    USB 3.0
    At first glance, they differ in the way of mounting the through-hole and surface-mounted displays.
    Capacity measurement I need to measure GSM battery status, real capacity of powerbanks, Li-ion 18650 cells, etc.
    If someone has a code name of the USB 3.0 meter, I would ask for it, it will be easier to find.
    LA72
    Help: 648
    Rate: 1658
    The second version is KWS-V20.
  • #3 16412521
    E8600
    Help: 529
    Rate: 2520
    Yes, but it is also USB 2.0, just a different designation of the first BTE-147 model and I meant this USB 3.0 because it has a wider measuring range.
  • #4 16412560
    LA72
    Help: 648
    Rate: 1658
    For USB 3.0, look for "Rui Deng OLED USB 3.0".
  • #5 16412581
    szymon122
    Help: 302
    Rate: 762
    I own the first one myself, it works perfectly. I measured the batteries in phones and powerbanks, you can sometimes be surprised at the actual capacity and declared. It has a wide range of 0-20V 0-3A operation.
  • #6 16412876
    E8600
    Help: 529
    Rate: 2520
    Which exactly model do you have kws 20 or this 147. I would not want to cut because they give different data on each page. If the former has such ranges, it should be enough for me. The latter probably much more expensive from what I saw. I would like this invention to embrace the capacity of 18650 because the modeling charger is about 100 PLN and I found the first model for PLN 20. Probably 5-10 times smaller real capacity in power banks.
  • #7 16413126
    szymon122
    Help: 302
    Rate: 762
    BTE-147, I do not know if exactly the same model but the manufacturer agrees and the appearance.
    No exaggeration, the Chinese 2200mAh is a real 1580mAh ;)
  • #8 16413163
    E8600
    Help: 529
    Rate: 2520
    Well, I saw a Chinese 30,000 and it was actually 5000mAh. Therefore, a useful case such a gadget. It is better to make a powerbank yourself, it will come out cheaper than the branded one because in Chinese there is still a myk with a Chinese unit wrongly labeled as mAh.
  • #9 16413169
    Ronin64
    Help: 248
    Rate: 349
    I also have the model from the first photo and I can confirm the usefulness of this gadget :)
  • USB meter choice depends on voltage range and Quick Charge
    #10 16413751
    E8600
    Help: 529
    Rate: 2520
    I do not know how much to trust the manufacturer's data, the second model of the USB 3.0 meter only has a voltage range of up to 13V and the cheaper one for USB 2.0 has a range of up to 20V, if the data from the net is true, the USB 2.0 model, which costs PLN 20, is more profitable. I found the OLED display for PLN 44. The USB 3.0 port is downward compatible so it doesn't pay to pay extra for the OLED display itself.
    If someone cares about quick charge functions, I recommend a more expensive model that supports USB 3.0 and voltage up to 30V.
    Following the auctions, I found the marking of this miracle from 2 photos, it is BTE-143 looks like this, so as not to be mistaken:
    I still found such data that someone would like to buy:
    KWS-20 voltage up to 9V
    KWS-21 voltage up to 20V
    The only difference is the voltage, the rest of the data is the same ;)
  • #11 16414407
    Sławek 61
    Level 19  
    Help: 29
    Rate: 140
    I will throw in my three cents regarding Chinese power banks, they have a patent for large capacity in the form of sand cells. Here, for example, you can see how it is done http://plumbi.pl/blog/?p=101 there are also hard drives with pendrives and nuts or capacitors one in the other. Chinese technical thought is not limited.
  • #12 18123484
    don vito19
    Rate: 15
    Does the measurement with this meter make sense ??
    Does the amount of current "come in" when charging shows the real battery capacity
    I think not, the capacity would show such a tes but discharging the batteries
  • #13 18123505
    tzok
    Help: 3176
    Rate: 6549
    The current measurement is on a resistor (I don't remember the value) which causes quite a significant voltage drop at higher currents. Besides, it measures the energy delivered to the device during charging, not the actual capacity.
The discussion revolves around the use of the USB Port Meter BTE-147 for measuring the capacity of Li-ion cells, particularly in comparison to a USB 3.0 version. Users inquire about the ability of the BTE-147 to accurately measure the capacity of various batteries, including GSM batteries and 18650 cells. The BTE-147 is noted for its wide operational range of 0-20V and 0-3A, while the USB 3.0 version, identified as KWS-V20, has a narrower voltage range. Users express skepticism about the accuracy of manufacturer claims regarding battery capacities, particularly with Chinese power banks, and discuss the practicality of using these meters for capacity measurement versus other methods. Concerns are raised about the measurement methodology, with some users suggesting that current measurements during charging may not reflect true battery capacity.
