saab 93 1.9 tid 150km - power steering does not work, esp abs is on
lukaszm108 6801 4
  • #1 16414134
    lukaszm108
    Hello, I have a problem with the support, after replacing the pump, the esp and abs still do not work after resetting the errors, the problem returns or maybe the module has fallen, please help
  • #2 16414378
    kamiloskop
    Help: 42
    Rate: 280
    And you can write what the errors are and you will not replace the pump immediately. First, the fault is diagnosed and then the components are replaced.
  • #3 16414500
    lukaszm108
    The controller cannot see the angle of the steering wheel
  • #4 16415055
    kamiloskop
    Help: 42
    Rate: 280
    It can start with calibration. View the parameters and if not, then replace the sensor, not the pump right away .stad does not work You esp and ABS when it does not see the steering angle.
  • #5 16422419
    lukaszm108
    In the workshop they told me that it could also be a damaged steering gear, because the power steering does not work more to the right and it is lighter to the left, the fluid is graphite, there is play on the gear but it does not leak yet what do you think?
