Audi A3 8P Steering Issue: Torque Sensor Error and Red Light Indicator
vollvek 70998 16
What is the cause of the electric power steering failure in an Audi A3 8P when the steering wheel light turns red and a torque sensor error appears, and can it be repaired?
The fault is usually in the G269 steering torque/force sensor or in the steering rack electronics, and the repair is not a simple quick fix [#13654941][#13656290] You can theoretically replace the G269 sensor separately, but the posters say it is not certain that this will solve the problem, so the whole rack is often replaced or regenerated instead [#13656290][#13656274] Buying a used unit is possible, but there were several revisions and compatibility matters, so matching the exact part and adapting it is a concern [#13656274] If the fault code also points to terminal 30 voltage being too low, check the power supply, ground, fuse box and connector on the side member first, because poor supply can also disable assist [#14855784][#14855813][#14856054] One user reports that replacing the steering gear with a 2008 Golf Plus 5 unit restored normal operation [#14856054]
  • #1 13653312
    vollvek
    Help: 10
    Rate: 99
    I am looking for information on repairing the electric power steering, but I only found that it is a common problem in these cars. It helps to replace the entire transmission, of which there are several versions, because they improved it. I would like to know what exactly is damaged and whether it can be repaired. The symptom is that there is no power steering and the steering wheel light is red. Previously, the steering wheel light turned yellow or red sporadically. If the light was red, there was no support. Shows torque sensor error.
  • #2 13653630
    dafit906
    Help: 91
    Rate: 515
    nr pale pass
  • #3 13654941
    vollvek
    Help: 10
    Rate: 99
    I didn`t write it down, but if I remember correctly, it`s G269, the steering torque or steering force sensor.
  • #4 13655587
    melas
    Help: 138
    Rate: 687
    I wish you good luck when you get to the electronics and fix it and give someone a warranty for it.
    Added after 43 [seconds]:
    exactly this error, crazy gear
  • #5 13655717
    dafit906
    Help: 91
    Rate: 515
    look for support
    Added after 1 [minute]:
    because this is not a modus/clio where DF002 is "repaired" within 5 minutes
  • #6 13656274
    vollvek
    Help: 10
    Rate: 99
    I want to repair it, in the old instructions, each gear element was replaceable separately, even the sensor. The only question is whether it is the fault of the sensor or the control electronics. For now, I`m researching the topic, I haven`t taken it apart yet. Maybe someone has already practiced the topic and knows what exactly is the cause. I don`t count on repairing it in 5 minutes, but a used one costs about PLN 400, but I don`t know if it has to be exactly the same number because apparently there were several changes and they also fit with a different number. When buying a used one, I don`t know if it will break down in a month or two. Apparently you can regenerate it for PLN 500. In both cases, there is the cost of replacement and geometry adjustment, which means the costs are high.
  • #7 13656290
    dafit906
    Help: 91
    Rate: 515
    but it`s the same in other electric ones, e.g. what`s the point of buying a power steering for Clio or Modus for PLN 100-200, COMPLETELY apart from that, because you`ll install it and it won`t start after the first one, and after the second time it won`t work. Even if you resolder the eeprom in it, it won`t work. There are two people in Poland who do this, a company in Poland and me, and that`s why I say the topic is difficult. Even if you buy a virgin, the Renault gearbox won`t work either :) Nissan, Reno, Ford Fiat, etc. etc. Look for electronics here, it doesn`t matter which one fits the hooks, just change the VIN and it should work. It is their fault these problems. You can theoretically replace G269, but it is not known whether it will help.
  • #8 13656316
    Aleksander_01
    Help: 1156
    Rate: 3386
    dafit906 wrote:
    but it`s the same in other electric ones, e.g. what`s the point of buying a power steering for Clio or Modus for PLN 100-200, COMPLETELY apart from that, because you`ll install it and it won`t start after the first one, and after the second time it won`t work. Even if you resolder the eeprom in it, it won`t work. There are two people in Poland who do this, a company in Poland and me, and that`s why I say the topic is difficult. Even if you buy a virgin gearbox for a Renault it won`t work either :) nissan, reno, ford fiat etc etc. .
    What year are these "miracles" from?
    Recently I replaced such devices in a Scenic II and a Nissan Micra (both after 2005). Plug end play, only the rods need to be adjusted because the steering wheel fits onto the shaft only in one place.
  • #9 13656333
    elektronikia666
    Rate: 20
    clio3, modus, megane3, scenic3. If necessary, I can arrange such support by mail
  • #10 13656438
    dafit906
    Help: 91
    Rate: 515
    Aleksander_01 and why change it? there is no need
  • #11 13656481
    Aleksander_01
    Help: 1156
    Rate: 3386
    If the steering wheel is "inclined" when driving straight and the shaft fits in exactly one place, it must be adjusted on the rods, unless there is another way. In the VAG group, you can mount the steering wheel on any shaft and there is no such problem.
  • #12 13805987
    m.zab
    Rate: 8
    electronics666 Hello. Question for my friend elekronikia666, can you provide some contact details because I have a problem with Scenic support.
  • #13 14855337
    tomku77
    Rate: 48
    Today, during normal driving, when turning, the red steering wheel light came on and there was no power steering.
    I connected the Vag Can Pro interface and there is an error in the power steering system;
    "Controller number
    1K1909144K EPS_ZFLS Kl.5 D06 00 0000000 1701
    Errors found 668(0x029C):22 Voltage in the electrical installation, terminal 30 Lower limit exceeded Lamp OFF sporadic"
    Is this a minor defect (which I doubt) or does the steering gear need to be replaced?
  • #14 14855784
  • #15 14855798
    tomku77
    Rate: 48
    Unfortunately no... I wanted to check, but access is difficult.
    I`m curious about this error - can the same content be present in the case of a damaged engine?
  • #16 14855813
  • #17 14856054
    tomku77
    Rate: 48
    I checked the fuse in the car, probably the third one in a row, and it`s ok.
    PS. I checked right after the fault... unless there is another one under the hood, but they are probably all good.
    I found the harness on the side member. There are 6 cables in the plug, after checking with a meter, two of them have a voltage of 12.45 V, one of them is about 10.40 V, two of them are 2 V with pennies, and the 6th one is ground.
    I have cleaned the mass, but it didn`t help.
    There is also electricity on the thick power cable.
    I drove around a bit after the procedure, but the same thing - no support.
    It`s probably best to check the harness, the plugs at the gearbox...
    Below are photos of the mentioned beam.
    Audi A3 8P Steering Issue: Torque Sensor Error and Red Light Indicator Audi A3 8P Steering Issue: Torque Sensor Error and Red Light Indicator Audi A3 8P Steering Issue: Torque Sensor Error and Red Light Indicator
    I replaced it with a transmission from a Golf Plus 5 from 2008. EVERYTHING IS HAPPENING LIKE CRAZY ;)
    Thanks and best regards.
✨ The discussion revolves around a common issue with the Audi A3 8P's electric power steering, specifically related to a torque sensor error and a red steering wheel light indicator. Users report symptoms including a lack of power steering and sporadic warning lights. The G269 steering torque sensor is identified as a potential culprit, with suggestions for repair or replacement of the entire steering transmission due to various versions and improvements over time. Some participants mention the difficulty of repairs, the high costs associated with used or refurbished parts, and the importance of checking electrical connections and harnesses. The conversation also touches on similar issues in other vehicle models, emphasizing the complexity of the problem and the need for thorough diagnostics.
