Saab 93 1.9 tdi 2006: Steering Lock Failure and Persistent Headliner Lights Issue
dariusz1390 8565 4
  • #1 16415399
    dariusz1390
    Hello, maybe someone had a similar problem. I have a Saab 93 from 2006 1.9 tdi, today there is a problem: the steering lock does not work and the headliner lights do not want to turn off, the car starts normally and it's ok, only these shortcomings, maybe someone will help.
  • #2 16415600
    piotrekwoj1
    Help: 947
    Rate: 3438
    Have you checked anything, e.g. fuses?
  • #3 16415741
    dariusz1390
    Fuses ok, it is strange that at the same time with the light blockade, the headlining does not turn off by themselves, only after closing the door with the remote control they go out, both of these things went out at the same time.
  • #4 16684754
    mk-tronic
    Rate: 187
    Has the topic been resolved? I have the same. Please reply.
  • #5 17240052
    blackdwarf
    In our case, the Saab 95 2011 automatic.
    We got off in the parking lot 15 later we wanted to leave and nothing about the steering column blocked.
    Disconnecting the battery checked fuses. No results.
    And it was enough to replace the battery in the key. And the car fired. And that's good, because 450 km are ahead of us
