Kiano Elegance by Zanetti 9.7 - Stuck on KIANO Logo After Unsuccessful Recovery Update
goodgulf 5739 18
How can I recover a Kiano Elegance by Zanetti 9.7 tablet that only shows the KIANO logo and no longer enters recovery after an incorrect rkimage update?
You need to flash the correct Rockchip firmware for your exact tablet model using RKBatchTool, not recovery mode, and use the manufacturer’s drivers/package for the device [#16421623] [#16424638] Install the Rockchip USB drivers, then put the tablet into Rockusb mode by holding Vol+ while connecting the USB cable and pressing Reset/Power for a few seconds until Windows detects a new device [#16422015] [#16422217] [#16424638] If the driver does not install automatically, remove the unknown device in Device Manager and manually point Windows to the rockusb.inf file from the driver package [#16424228] [#16424159] Make sure you use the correct update.img for the exact version of the tablet, because there are different variants (for example with and without 3G) [#16421623] In the end, the tablet was revived by doing this on an old Windows XP laptop, which detected the Rockusb device and allowed RKBatchTool to restore the Android 4.4.2 image successfully [#16426621]
  • Recovering Kiano tablet after incorrect rkimage update
    #1 16420588
    goodgulf
    I have a question and at the same time a request for help, I tried to update the tablet through recovery and inadvertently I chose rkimage ... and it was rather an error that it started to update, but after all, only the screen with the word KIANO lights up and I can not enter recovery.
    Is it possible to do anything else to revive it because I do not hide that it is not my toy and I would not like it to fall
    Regards Goodgulf
  • #2 16421074
    gradek83
    Help: 930
    Rate: 2104
    Connect the tablet to the power supply, turn it on and wait maybe some time after the update to start up.
    Connect the tablet to the power supply, turn it on and wait maybe some time after the update to start up. Where did you get the update from? Recovery usually updates from the update file from the micro SD card.
  • #3 16421282
    Freddy
    Help: 1394
    Rate: 2821
    goodgulf wrote:
    I have a question and a request for help, I tried to update the tablet ...
    You did what is described in HERE on the manufacturer's website?
    Not true - it depends on the manufacturer.
  • #4 16421382
    goodgulf
    So I tried this first but unfortunately RKBatchTool didn't want to see the device visibly. Bad drivers - nothing. After connecting to the computer, however, the system reports something, so it will try again, and I had the upgrade.img file from the net, but unfortunately I am not able to remember where from. Apparently it's Android 4.4 for this tablet.
  • #5 16421445
    Freddy
    Help: 1394
    Rate: 2821
    Start by downloading the correct files and the correct drivers according to the manufacturer's instructions.
  • #6 16421623
    gradek83
    Help: 930
    Rate: 2104
    goodgulf wrote:
    upgrade.img
    Through recovery mode, you will not upload it only using RKBatchTool
    This tablet, as far as I know, is in two versions with 3G and without, as the previous speaker wrote, download the correct file specifically for your model. Search for the software on the manufacturer's website or on a rodent. If you are sure you have a Rockchip tablet then you have it drivers . If you have win 10, install drivers without digital signature.
  • #7 16421965
    goodgulf
    I installed the given rudders by you and win 7 and 10 with such an effect Kiano Elegance by Zanetti 9.7 - Stuck on KIANO Logo After Unsuccessful Recovery Update
    but RKBatchTool still cannot see the device
  • #8 16422015
    gradek83
    Help: 930
    Rate: 2104
    1) Turn off the tablet fully press VOLUME + and keep it pressed
    2 connect the usb cable after a while it detects a new device, it should install the drivers
    3) After installing the drivers, run RKBatchTool and load the .img file and click on RESTORE
  • #9 16422159
    goodgulf
    Well, unfortunately, turn off means that the screen will go blank, I can only press reset and after plugging in usb on vol - and it still shows in the manager "Android ADB Interface and nothing else RKBatchTool still does not see it
    gradek83
    Help: 930
    Rate: 2104
    Connect the tablet to the USB, press and hold VOLUME - and do not let go and now press the reset button for 5 seconds, release the reset and it should detect a new device. Possibly check the same but with VOLUME +
  • #11 16422267
    Freddy
    Help: 1394
    Rate: 2821
    goodgulf wrote:
    yes, after connecting usb to vol -
    First you press Volume- and while holding it you insert the USB plug.
  • #12 16424147
    goodgulf
    Well, unfortunately, the max what I managed to get is: Kiano Elegance by Zanetti 9.7 - Stuck on KIANO Logo After Unsuccessful Recovery Update
    ps there are times when the tablet chirps like a sparrow :)
  • #13 16424159
    Freddy
    Help: 1394
    Rate: 2821
    Then indicate the drivers manually, you have them in the file from the manufacturer's website.
  • #14 16424228
    gradek83
    Help: 930
    Rate: 2104
    goodgulf wrote:
    well, unfortunately, the max what I was able to get it
    There is progress, having something like this, right-click on an unknown device and select the uninstall option, then if you downloaded the drivers, what I gave you or from the manufacturer, run DriverInstall.exe as administrator, then in Device Manager refresh the devices and the drivers will be installed either manually like Freddy suggests, that is, indicate their location with a 64bit system, it will be the path: ... \ DriverAssitant_v4.4 \ Driver \ x64 \ win8 \ rockusb.inf
  • #15 16424315
    goodgulf
    Unfortunately, it does not go this way. I still remembered with the old one paw I have XP on my laptop. Maybe it will be there. But that's later. Eh, I hope we can save him.
  • #16 16424331
    gradek83
    Help: 930
    Rate: 2104
    You do it with this one option ?
  • #17 16424430
    goodgulf
    Yes, but mainly I did it on win7 32b and 10 have x64
  • Manufacturer package includes 64-bit drivers and correct Vol+ recovery steps
    #18 16424638
    Freddy
    Help: 1394
    Rate: 2821
    After all, the package from the manufacturer's website also includes drivers up to 64bit.
    The file also includes instructions on how to start and proceed.
    First, install device drivers for Windows
    - to install the drivers, press the Vol + button on the tablet
    - connect the device with a USB cable to the computer
    - press the Power button for about 3-4 seconds, keeping it pressed all the time
    VOL + button
    - release both buttons, the computer will signal the detection of a new one
    devices
    Sorry for my mistake regarding Vol-.
  • #19 16426621
    goodgulf
    Thank you very much for your invaluable help. Thanks especially to gradek83, according to his tips we managed to finally revive this tablet and it was like that. I fired up the old laptop with Win XP, connected the tablet, pressed vol + and reset for a few seconds. then the win was detected by the rockusb device and then XP swallowed rudders drivers. Other systems did not want to. I fired up RKBatchTool which initially did not see the device, then I repeated the combinations with vol + and reset and it detected it downhill. I uploaded the update.img file for this tablet with andek Android 4.4.2, and of course restore and it went works.
    I corrected the spelling and removed the slang.
    Please take care of her, respecting the readers. RADU23
The Kiano Elegance by Zanetti 9.7 tablet became unresponsive after an unsuccessful recovery update, displaying only the KIANO logo. Users suggested various troubleshooting steps, including connecting the tablet to a power supply, using RKBatchTool for recovery, and ensuring the correct drivers are installed. The author faced difficulties with driver recognition on Windows 7 and 10 but eventually succeeded using an older Windows XP laptop. By following specific button combinations (holding Volume + and Reset), the device was detected, allowing the installation of the correct update.img file for Android 4.4.2, successfully reviving the tablet.
