Kiano Elegance 5.1 Pro - Part of the screen does not respond to touch
deozur99 5997 5
  • #1 16462376
    deozur99
    Hey
    For some time I have a problem with the touch in my phone (Kiano Elegance 5.1 Pro). The part of the screen, i.e. about a centimeter wide almost at the top, quite often ceases to react to the touch. Rather, it seems to me that this is a mistake on the side of the software, not a damage to the digitizer, because sometimes everything is okay.
    Is there a way to fix it?
  • #2 16462595
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    The simplest option is to restore factory settings.
  • #3 16462757
    bogdan2491
    Help: 52
    Rate: 97
    Try factory settings if it does not help, I would check the connection of the touch with the motherboard - tape clip. If it does not do anything, it probably releases the glue on the tape I wrote about, connecting the touch with the glass.
  • #4 16462772
    deozur99
    Okay thanks. I will try to restore the factory settings
  • #5 16474022
    deozur99
    I restored the factory settings and still the same. I think, however, the digitizer's fault. And I know the cause of the problem - the volume buttons have recently started to work worse and you have to press them harder. It seems to me that this has had an impact on the digitizer, but I'm not sure. Give back the phone for guarantees?
  • #6 16474209
    nutergsm
    Help: 1034
    Rate: 1665
    If you have this option, use it.
