Seeking Specific Drivers for Kiano Intelect X1 FHD After System Repair
Akane 11184 6
  • #1 16455649
    Akane
    Help: 144
    Rate: 33
    I got X1 FullHD for system repair. The system partition was formatted from the recovery console and thus it was impossible to recover the system - the proper size of the install.wim archive on the recovery partition was not available.
    So I installed Windows 10 from DVD, I transferred some drivers from the Intelect 8.9 3G model (Windows 8.1 was there), and some of it installed automatically.
    There is a lack of drivers for sound, touch, camera, battery and tilt sensor. Using the devcon program, I made a list of deficiencies:
    ACPI\BOSC0200\1
    ACPI\OVTI2680\0
    ACPI\OVTI2680\2
    ACPI\INT33D5\3&11583659&0
    ACPI\GDIX1001\4&34076DDA&0
    I will add that the equipment is used to receive SDRPlay radio and the victim depends mainly on sound and battery. The problem with the lack of power drivers is that even with the charger connected, the battery is constantly running out while Windows is running, and is actually charging with the equipment off. What's worse - there is no way to check its status, only with the Volume buttons on the switched off equipment.
    What pleases me: the contents of the directory
    \Windows\System32\DriverStore\FileRepository
    Unfortunately, there are a lot of files there and the whole thing takes about 250MB in a compressed form with a zip with the highest compression. If someone from Silesia would like to help personally, I am mobile every day, mainly on the route Gliwice - Katowice.
  • #3 16457668
    Akane
    Help: 144
    Rate: 33
    Thank you for the package!
    Everything works fine except the touch screen which reacts mirroring in the "vertical" axis.
    I installed everything from the device manager and, to be sure, updated all already placed drivers with drivers. This packet setup could not cope with one inf file, stating that some file was missing.
  • #5 16962142
    bobruk.pl
    Rate: 19
    Try these drivers. Today I got them from the producer.
    Kiano Inte..t X1.7z (69.39 MB)You must be logged in to download this attachment.
  • #6 17055403
    Denis Podgajski
    You need to copy TouchSetting.gt from the appropriate folder (HD or FHD) to c: \ windows \ inf \
✨ The discussion revolves around the need for specific drivers for the Kiano Intelect X1 FHD tablet after a system repair that involved formatting the system partition. The user successfully installed Windows 10 but encountered issues with missing drivers for sound, touch, camera, battery, and tilt sensor. Several users provided links to driver packages and suggested tools like Snappy Driver Installer. The user reported partial success with the drivers, but the touch screen exhibited a mirroring issue. Additional suggestions included copying specific files to the Windows directory to resolve touch functionality problems.
