Radio with Bluetooth vs. Separate Speakerphone: Comparing Phone Call Features & Functions
Marian B 10791 10
  • #1 16420691
    Marian B
    Help: 392
    Rate: 1161
    I have a dilemma and I do not really know how to solve it. The point is whether for the sake of the phone to buy a radio with Bluetooth (what I have is without this invention), or better separate speakerphone.
    First of all, I do not know if the "switched off" radio with Bluetooth automatically turns on automatically when the phone call comes on, whether you have to turn it on manually, or later press the "handset".
    This problem obviously does not exist in dedicated sets, the button is pressed and after the problem.
  • #2 16420982
  • #3 16421279
    Marian B
    Help: 392
    Rate: 1161
    I did not mean a set with a battery / rechargeable battery, only one that is permanently connected to the car installation. Turning on the ignition is tantamount to turning the set on, e.g.
    Radio with Bluetooth vs. Separate Speakerphone: Comparing Phone Call Features & Functions Radio with Bluetooth vs. Separate Speakerphone: Comparing Phone Call Features & Functions
    I was not sure how it is with bluetooth radio. If you need to turn them on, then press "handset", (two steps) is according to I do not like this option.
    The fact that you need to lead some additional wires there is not a problem for DIY enthusiasts.
    The cost of this set of pics is only 105 zlotys, and in my opinion, it is not worth buying sets that need to be charged and looked after.
    Thank you for the hint.
  • #4 16421327
    adam_1991r
    Help: 83
    Rate: 153
    I will also recommend you a radio with BT, but it is known that it is a higher cost. Because such a radio is easier to use, it can also improve the quality of playing in the car, or add usb as you do not have.
    The radio with bt has several functions which the device you have entered does not have. First of all, the most important thing is you do not even have to pull the phone out of the pocket to see who is calling, you can also browse the address book directly from the radio and choose who you want to call (you can also set favorites and call 1-6). In addition, new radios can make the player sound from the phone in the car system (music, Spotify, youtube, navigation without additional cables).
    And as for your first question, whether the radio itself will turn on as it will be a conversation, no. Anyway, what for? For example, you will be under tents, the car will be very close and then all calls will be received from the radio, not the phone (on your phone you will have to turn off bt every time). I have a radio connected so that when I enter the car it turns on the radio and automatically connects with the phone.
  • #5 16421351
    Marian B
    Help: 392
    Rate: 1161
    Now I know everything, thank you very much.
  • #6 16421352
  • #7 16421371
    Marian B
    Help: 392
    Rate: 1161
    This "first" action, switching on the ignition, is basically non-existent, because the hands-free system is so that you can safely talk on the phone while driving, so the ignition will surely always be on for example before an hour.
    I do not deny the advantages of the radio from bt, and I think I will buy one, I just did not know how it behaves when it is turned off when the phone call arrives.
    Of course, you can set the radio to turn on automatically when the ignition is turned on, only not everyone wants it, hence the dilemma.
  • #8 16421510
    adam_1991r
    Help: 83
    Rate: 153
    If you want, I can check later if the radio will turn on when talking, how it's turned off :) because I have never checked because I have switched on the radio all the time, but the ignition must definitely be (unless the radio is permanently connected)
    edit:
    I was in the car and checked it and the case is as follows. If you have a radio connected permanently (that is, a radio works when you want without a key), if you get a call or call yourself, the radio will turn on itself, as it is turned off. However, after the conversation the radio will go out.
    I checked Alpine cde-195bt on Alpine, so all new alpes from bt should work like that. I do not know how other companies.
  • #9 16422628
    Marian B
    Help: 392
    Rate: 1161
    That's what it was about, now I really know everything about it. I suppose it will be similar in other receivers. Thanks a lot.
    The next problem arises with the replacement of the radio, but I can handle it. My radio (Blaupunkt) has steering control via infrared. Not all receivers use this control method, and without "steering" the steering wheel. Another modification is waiting.
  • #10 16422673
    adam_1991r
    Help: 83
    Rate: 153
    What car is it and is there original steering control? Because as it is original and not dorabianie it is possible to buy a steering module from the steering wheel to any radio, the choice of cars is also huge. You can ask on piloty.pl but first you need to know the radio model you will have.
  • #11 16422723
    Marian B
    Help: 392
    Rate: 1161
    This is Octavia from 2000, I made the control myself in the form of a joystick under the steering wheel. In my opinion, such a lever (four positivi) is a better solution than buttons, more convenient. It's on the right side, under the wiper lever. With this no problem, if necessary, it can be converted to the required way, eg. By means of switched resistors.
✨ The discussion revolves around the choice between purchasing a Bluetooth radio or a separate speakerphone for handling phone calls in a car. Users highlight that a Bluetooth radio offers integrated features such as music streaming, direct access to the phone's address book, and the ability to see incoming calls without removing the phone from a pocket. However, it is clarified that Bluetooth radios do not automatically turn on for incoming calls; they require the ignition to be on and the radio to be in standby mode. Users express concerns about the need for manual activation and the complexity of installation. The conversation also touches on the compatibility of steering controls with new radios, emphasizing the importance of ensuring that the new device can work with existing car controls.
