Pioneer DEH-p55bt - The phone does not play music, but calls are working.
DamianS20171 11547 5
  • #1 16688122
    DamianS20171
    Hello, my problem is I don't know if the connection is wrong or there is a defect in the radio. Well, I have a Pioneer DEH-p55bt radio, to which I have a phone connected via bluetooth. I tried different phones and with android and ios. The radio says connected and I can easily make phone calls using this radio and a separate microphone. The phone clearly shows that it is connected to the radio, but when I try to play some music, it comes from the phone, not from the car speakers. I have a portable bluetooth speaker and it is enough to connect to it as simply as possible via bluetooth and everything works. The music is playing. I can't make the music play from the car speakers. I've tried different ways and it fails. I am asking for help and thank you in advance.
  • #2 16695104
    DamianS20171
    Nobody knows anything that can help?
    Moderated By damiancz:
    3.1.11. Don't post messages that add nothing to the discussion.
  • #3 16696531
    Cyczki
    Welcome. On your Android phone, go to settings> bluetooth, find this Pioneer in the list of paired devices, click and hold, or click the option icon next to the device name and select the "multimedia sound" option. Should help.
  • #4 16713345
    DamianS20171
    This option was checked from the beginning. Unfortunately, this is not the problem here.
  • #5 18919847
    arekar1
    I have the same you solved this problem?
  • #6 18922448
    DamianS20171
    Unfortunately not. I dealt with the topic a long time ago, but from what I remember it turned out that simply connecting to the radio allows only conversations, not listening to music.
    Greetings
