How can I pair a Pioneer DEH-P70BT with a phone for handsfree speakerphone use when the radio finds the phone but rejects the pairing code?
Pair the phone from the radio’s own “connect phone” menu and use PIN 1111; the microphone is not needed for pairing, only for making calls [#16832237][#16832436][#16832649] If pairing still fails, check the phone’s Bluetooth settings and try the phone with another Bluetooth device, or try another phone with the radio to isolate the problem [#16832436] For audio playback, select BT Audio from the SOURCE button if that source is available [#16832766][#16832795] One user reported only Aux, Tuner, CD, and Phone sources on their unit, so BT Audio may not be available on every setup [#16833233]
Hello. I have a radio as in the subject but I can not connect it to the phone. The radio recognizes the phone and the phone, but the radio code does not accept. Are there any ways to set this radio as a speakerphone?
Thanks buddy for the link, but English is not on my way. I am looking for this option for my motorola so much that then an error pops up and the attempt to pair the device via the phone is rejected by the radio, when it finds the phone by giving the right arrow a combination of numbers and letters pops up but if it is entered in the phone then the radio rejects the connection. Do I need to connect a microphone to the radio to connect?
Microphone only needed for calls over the phone - not needed for setup. Check in the phone if there are any options regarding BT, check the phone with another device (computer second phone) if it connects correctly. Check another radio phone.
I reviewed the volume of instructions and this radio has quite a few possibilities, e.g. some DVD player as I understand after connecting a screen to this radio. And what is BT Audio set up in?
Added after 35 [seconds]:
The discussion revolves around issues connecting the Pioneer DEH-P70BT radio to a phone for speakerphone functionality. The user initially struggles with pairing the devices due to a rejected connection code. Suggestions include checking the "connect phone" option on the radio, ensuring Bluetooth settings on the phone are correct, and testing the phone with other devices. It is clarified that a microphone is not necessary for setup but is required for phone calls. The user successfully pairs the devices using a PIN and inquires about using the radio for audio playback, to which it is advised to set BT Audio as the audio source. However, the user later notes that their radio lacks the BT Audio option, only having Aux, Tuner, CD, and Phone settings. AI summary based on the discussion. May contain errors.
