Adding Bluetooth to Peugeot 307 cc 2005's RD4 Radio Without Changing Display or Controls
_maziech_ 13917 2
  • #1 16599891
    _maziech_
    Rate: 10
    I have a PUG 307 cc pre-lift, there sits a serial radio RD4 without bluetooth and USB support. The AUX output can optionally be added.
    I can only play CDs and radio, and I would like to hook up with a telephone, for example, to listen to my music. Therefore, I am interested in whether there is any possibility of painless adding Bluetooth to this radio without having to replace the display and the radio?
    I am only interested in listening to music, I do not need a speakerphone, etc. But I also do not want to lose the ability to control the radio from the steering wheel.
    Is anyone oriented, or can it be done on this radio?
    If not, is it possible to replace the radio with a newer one in general? What would you need to buy then? (for now it seems to me that the BT + rd45 radio + display?). Or maybe you just can't do it without proper gymnastics?
  • #2 16602980
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    Like pre-lift, there is no RD4 option.
    RD4 is on the can and pre-lift is on the van.
  • AUX input may be unlockable in radio settings
    #3 16604002
    _maziech_
    Rate: 10
    I think it's RD4, but I might be wrong ...
    The front panel looks exactly the same as the one with alledrogo:
    http://allegro.pl/peugeot-307-radio-zmieniarka-i6903393808.html#imglayer
    Added after 17 [hours] 49 [minutes]:
    Maybe I can ask you something else:
    I came up with the idea that the least invasive procedure would be to connect AUX for this radio and connect an external Bluetooth module with AUX input.
    1. Does the radio for this car have AUX output?
    (If it's not RD4, I don't know what model it is ...)
    2. In the radio options I do not have AUX support as an input source - only CD and Tuner support. Can you unlock the support for this output on your computer?
