Windows 10 Accessibility - How to remove Accessibility from the login window
aspeedy5 5775 2
  • #1 16422066
    aspeedy5
    Anyone know how to remove accessibility from the system login position from the 10? At work, I set up a password so that others would not fumble in the computer when I was not there, and from this anger someone turns on all possible narrators, magnifiers and other trifles that can be turned on from the login position. Puki what I have not found anywhere on the net, how to remove it ...
    Help !!!
  • #2 16423448
    WojtasJD
    Help: 2919
    Rate: 1586
    There is such a method of changing permissions to utilman.exe - taking permissions from Everyone
    or maybe the user NT AUTHORITY \ SYSTEM is enough
    takeown / f% WinDir% \ system32 \ utilman.exe
    cacls% WinDir% \ system32 \ utilman.exe / e / p SYSTEM: N
    It works under W8.1 - I mean, clicking on the accessibility icon on the login screen doesn't do anything.
  • #3 16434891
    aspeedy5
    It worked, I entered, as my colleague wojtas suggested in system32, I found utilman.exe, then the permissions properties after changing the file management to myself, I set everything to refuse and it does not go to these annoying narrators, magnifiers, etc.
