Calculating Rectifier Diode Voltage in Forward Direction for E=0.3V: Comparing Multisim Results
elektraelektra 10512 9
How do I calculate the forward voltage across a rectifier diode when the source is only E = 0.3 V, and why does Multisim show a different result?
For the idealized constant-threshold model, a rectifier diode with UT = 0.7 V does not conduct at E = 0.3 V, so the diode voltage is Ud = 0.3 V and the current is zero [#16425640] Only when the source voltage exceeds 0.7 V does current flow, and then the diode voltage is taken as a constant 0.7 V in that simplified model [#16425640] Multisim likely shows a different result because it uses a real diode model with a non-linear current-voltage characteristic, not the simple threshold approximation [#16425640][#16426116] If you need the current exactly, use the Shockley equation [#16430870]
  • #1 16422809
    elektraelektra
    Hello :)
    I fight this task in different ways and the results do not match the simulations in Multisim.
    Let's say I want to calculate the diode voltage in the forward direction for the value E = 0.3 V. In the circuit the current will not flow while multisim shows the voltage drop across the diode. How to calculate for such a task?
    From the second Kirchoff's law I make the equation E-IR - Ud = 0, but what next?
    Greetings!
  • #2 16424668
  • #3 16424706
  • #4 16424802
  • #5 16425308
    Piecewise constant-voltage model explains Multisim differences
    #6 16425640
  • #7 16426116
  • #8 16427180
  • #9 16427330
The discussion revolves around calculating the forward voltage drop across a rectifier diode when the applied voltage (E) is 0.3V. The user notes discrepancies between their calculations and the results from Multisim simulations. Responses highlight that for voltages less than or equal to the diode's forward voltage (typically 0.7V), the diode does not conduct, and thus the voltage drop across it equals the applied voltage (UD = E). When the voltage exceeds 0.7V, the diode behaves as a constant voltage drop of 0.7V. The conversation also touches on the non-linear characteristics of diodes and suggests that Multisim likely uses a real diode model, which may account for the differences observed. The Shockley equation is recommended for precise current calculations.
