Re: Zener Diode Comprehension Issue: DZ=3V9, Voltage Drop, YouTube Instructional Videos
Dracov76 5124 9
How does a 3.9V Zener diode behave in a circuit, and when should I expect 3.9V versus the remaining supply voltage?
A 3.9V Zener diode does not magically subtract 3.9V from the supply; in reverse bias it clamps the voltage across itself to about 3.9V, and the rest of the supply voltage appears across the series resistor or load. If you connect it in series in reverse, the diode itself will have about 3.9V across it and the remaining voltage, e.g. 12V - 3.9V = 8.1V, is dropped elsewhere in the series path [#16921012][#16921023] If you connect it in parallel with a current-limiting resistor, the output node is held near 3.9V while the resistor takes the rest of the voltage drop [#16921023] In forward direction it behaves like an ordinary diode and drops about 0.6V [#16921012] You must also respect current and power limits, because at higher currents the Zener can dissipate a lot of power, e.g. 24V down to 8V at 1A would mean 16W in the Zener path [#16921413] For larger power levels, a step-down converter or proper regulator is better [#16921413]
  • #1 16920291
    Dracov76
    Gentlemen and maybe ladies, on YouTube I watch instructional videos about the zener diode and when they connect it (e.g. DZ = 3V9) to a voltage of 1-12V, nothing appears behind the diode, and after exceeding 3.9V, the voltage does not increase any more despite giving more and more voltage, and the current flows nice .. I understand it because it results from the characteristics ...
    But again elsewhere it says that such a diode causes a voltage drop, e.g. 3.9V for our 3V9 diode, so it follows that there should be a voltage behind it (for 12V supplied). Equal to 12-3.9 = 8.1V and not constantly around 3.9V ...
    It logically makes no sense so I get something wrong somewhere ..
    brofran
    Help: 650
    Rate: 1407
    It all depends on the configuration in which such a diode works (voltage and current distribution).
    In general, the principle of its operation is such that after exceeding the rated voltage (3.9V in your case), such a diode begins to conduct current.
  • #3 16920997
    Dracov76
    But I still do not know what voltage to expect, I think E20 for a long time, I am well prepared despite the lack of practice, but it dawned on me that I do not know what voltage to expect for a zener diode in the system ... taking into account the voltage drop or stabilization: /
    japycz321
    Help: 92
    Rate: 141
    Ehh, from the beginning. If the diode is turned on in the forward direction, the drop on it is 0.6V. The charm of zenera is to use it in a negative direction. Its operation can be briefly described as follows: After exceeding the zener voltage, a breakdown occurs (it does not damage it by itself, of course) and the voltage on it no longer increases. If you turn it on in series with the resistor, then you will have a maximum of 3.9V on the diode. The rest will be lost on the resistor. And these 3.9V depends on the diode rating and will be constant regardless of the supply voltage, as long as it is higher than the 3.9V. It does not matter if you power such a 5V or 35 error, the diode will be 3.9V. Of course, you also have to watch over the current flowing through such a diode.
  • #6 16921328
    Dracov76
    Aaa ... now I think I understand
    So in this diagram
    Re: Zener Diode Comprehension Issue: DZ=3V9, Voltage Drop, YouTube Instructional VideosD6AF369E-D...28458.jpeg (37.2 kB)You must be logged in to download this attachment.
    If the power source was 24V and the diode was, for example, 7.9V, then the resistor should be selected so that for a given current the voltage drop would be equal to about 16.1V. Okay, and the Voltmeter will show me 7.9V, because these are the zener diode terminals, so its voltage drop is probably correct ... I think I understand correctly ... such a large resistor), I can connect two zener diodes Dz = 5.9V + a resistor limiting the diode current On which voltage drop is 4V and behind this system I can connect something powered by 8V?
    I think I understood, I hope I think well.
    Andrzej42
    Level 32  
    Help: 178
    Rate: 322
    You think well, but in addition to voltage, you also have electricity and power. If you have a 24V power supply and 8V reception but let's say 1A, 1A will also flow from the 24V power supply, so the zener diodes will be 16V x 1A = 16W.
    With low currents, you can lower the voltage with zener diodes or resistors, but with a certain power it is worth using step-down converters, especially as they are more and more available and cheap.
  • #8 16921466
    japycz321
    Help: 92
    Rate: 141
    With the difference you gave, i.e. from these 24 to 8, only a step down. Even a linear regulator wouldn't work. Zener diodes are not suitable for lowering the voltage, but only for "stabilizing" it at a certain level.
  • #9 16921608
  • #10 16921647
    japycz321
    Help: 92
    Rate: 141
    trymer01 wrote:
    It is suitable, but for small currents, because it results from its power - currently there are no zener diodes with a (real) power greater than about 1W, with a heat sink - several W, which means max current (for Uz = 8V) = approx. 0.5A.
    Yes, only the maximum power that can be released on it is a problem and excludes it from many applications. Most often it can be done better. The higher the current, the less chance of using a zener diode
    Moderated By trymer01:
    Regulations, point 3.1.11. Publishing entries repeating information from the discussion.
The discussion revolves around the operation of a Zener diode, specifically one rated at 3.9V (DZ=3V9). Users express confusion regarding the expected voltage drop across the diode when connected to a higher voltage source (e.g., 12V). It is clarified that when the Zener diode is reverse-biased and exceeds its rated voltage, it stabilizes the voltage at 3.9V, with the remaining voltage drop occurring across a series resistor. The importance of current limiting to prevent diode damage is emphasized, along with the distinction between using Zener diodes for voltage stabilization versus voltage reduction. The conversation also touches on the limitations of Zener diodes in high-current applications and suggests alternatives like step-down converters for better efficiency.
