Pioneer 50Wx4 USB Radio - Issues with Station Memory and Ignition Dependency in Renault Master
marat18pias 6336 1
  • #1 16424615
    marat18pias
    Rate: 18
    Hello, I recently purchased a Pioneer 50Wx4 USB radio. And I have the following problems with it:
    1.the radio can not be turned on without the car ignition (the car key must be turned, otherwise the radio does not work)
    2.The radio, after turning on the tuner, I set, for example, wave 88.20, save by pressing, for example, No. 1 for a few seconds until it clicks and the radio remembers the saved station, but when I remove the key from the ignition for more than 10 seconds, the radio turns on and there is no saved wave. How to fix this so that the radio remembers saved stations?
    I have a radio in Renault Master diesel and it was postponed from Renault Megane gasoline.
  • #2 16424625
    SERVICE-AV
    Help: 728
    Rate: 899
    You need to translate yellow to red in the radio's power harness.
