Delonghi ESAM 4500 Milk Frothing Issues: Nozzle & Tube Troubleshooting, Heater Replacement
lukasz_s8 11544 10
Why does my DeLonghi ESAM 4500 stop drawing milk into the frothing tube and only blow steam from the nozzle, and what should I check or replace?
The most likely fault is the frother clutch, and the two solenoid valves should also be checked [#16426836] Replacing the foamer clutch restored normal milk frothing in one case, with the machine then working better than before [#16454203] If the problem returns after a clutch replacement, the clutch may be getting damaged by excessively high steam outlet temperature [#16724168] In that case, the likely causes are the heater, solenoid valve, NTC sensor, or a blockage in the system [#16724168] Replacing only the clutch may work temporarily, but the fault will come back if the underlying temperature or flow problem is not fixed [#16724168]
  • #1 16426772
    lukasz_s8
    Rate: 20
    The problem is that the coffee machine has stopped frothing milk. In fact, it doesn’t even draw milk from the container; the milk rises to halfway up the tube, and only steam comes out of the frothing nozzle into the cup – not a single drop of milk. According to my wife, the machine has been frothing less and less milk recently, but she didn’t pay much attention to it (I drink black coffee, so I had no idea). Does anyone have any suggestions as to what to check or replace? I should also add that I recently replaced the main heating element – the double one.
    I’d be grateful for any suggestions.
    Thank you and best regards.
    robsons10
    Help: 73
    Rate: 401
    Hello. As in the Delonghi solenoid valves (2 pcs) and the frother clutch to be checked. rarely covers the jug.
  • #3 16429171
    lukasz_s8
    Rate: 20
    Robsons10, can you write for a layman how to check it.
    I have read on the forum that similar symptoms happen when the steam nozzle is damaged
  • #4 16454203
    lukasz_s8
    Rate: 20
    Today I replaced the foamer clutch and everything is back to normal, I will say more is even better than it was. Perfectly frothed milk does not splash, my wife is delighted
    Thank you for the hint
    Closing topic
  • Recurring milk and hot water failure after clutch replacement
    #5 16723845
    lukasz_s8
    Rate: 20
    Hello again, as it turns out, the problem is back. After replacing the clutch, it was good for about 2 months, then the machine was not used, after starting it again it did not foam the milk, re-exchange the clutch, after 4 days the same again, or even worse. Now he doesn't even serve hot water, I wonder what that might be? something clogged, maybe some solenoid valve clutched again, although I do not believe it myself. Anyone have any clues or suspicions?
  • #6 16724168
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    The frother clutch is usually damaged by excessively high steam outlet temperature.
    Reason as above - heater, solenoid valve, ntc sensor ..
    There may be system obstruction itself ..
    Another clutch replacement will work again for a short period of time and the problem will return.
    Kawa i Naprawa - Serwis AGD
  • Overheating likely damages the frother clutch
    #7 16724215
    lukasz_s8
    Rate: 20
    Post Posted: 27 Sep 2017 15:57 Post subject: Re: Delonghi ESAM 4500 does not take milk
    What are you betting / suggesting?
  • #8 16727190
    nioop
    Help: 503
    Rate: 3337
    lukasz_s8 wrote:
    (...) What are you betting / suggesting?
    And what will I write that you will replace? ;)
    Seriously speaking - complete and then you can be sure.
  • #9 16727231
    lukasz_s8
    Rate: 20
    Due to where I am, I can't really have the device serviced.
    So it remains to replace the parts one by one, please write what you mean by the set. I will add that the thermoblock was replaced about a year ago
  • Disconnected internal tube causing steam leak and milk system fault
    #10 18390430
    Ewenk
    I'm new here, from yesterday I became the owner of a used ESAM4500.
    1. The coffee is brewing, but the milk-hot water system does not work. Nothing is flying from the front and after some time you can hear and see a STEAM BUCH (it even threw a differential in the apartment), a small water puddle under the coffee machine and a transparent tube disconnected from the valve inside.
    3. The message "insert water spout and press OK" is displayed virtually non-stop while the spout is attached (or alternatively the milk container).
    Where to look for the cause?
    Paul
  • #11 18392818
    lukasz_s8
    Rate: 20
    This tube cannot be disconnected, which is why you have a puddle under express.
The Delonghi ESAM 4500 has been experiencing milk frothing issues, with the machine failing to draw milk from the container and only producing steam. Initial troubleshooting suggested checking the solenoid valves and frother clutch. After replacing the frother clutch, the problem temporarily resolved, but it recurred after a few months, leading to further concerns about potential clogs or damage to the heater and solenoid valves. Users noted that high steam outlet temperatures could damage the frother clutch, and some suggested that repeated replacements might not provide a long-term solution. Additional issues included a malfunctioning hot water system and persistent error messages related to the water spout.
